Sign in to follow this
mfryer
mfryer's ride
There are hundreds of Eze/Cozy Urethane noses FLYING out there FOR YEARS....without one complaint about what their noses are made of.
YMMV. I really enjoyed sculpting the urethane, and with agood micro coat prior to glassing, felt/feel it matches the design need.
Self confessed Wingnut.
Get up off that couch!!! =)
Share this post
Link to post
I just placed my first order with Aircraft Spruce. :D
Its just a composite practice kit, but I think I can officially say that I have started chapter 3.
I also spent the last few days cleaning up the "shop" and today I installed some florescent lighting, seems about 10 times as bright in there.
Tomorrow my brother is headed over to help me build a work table and spruce up the shop some more.
Also I started a blog to track my progress. I don't know how often I will update it but if anyone is interested in checking it out goto:
http://flyingbackward.blogspot.com/
If anyone has any suggestions about the blog or my progress please please feel free to let me know what you think.
Martin
i wish it were mine:bad:
Share this post
Link to post
The main reason some folks are staying away from this foam is that in the event of an electrical fire, you get bad gas (and Beano won't help you.)
Share this post
Link to post
Over the last month, between Arlington, checking out Steve Parkins Cozy project and other things, I have have nearly completed construction of the canopy (not counting hinging and latch hardware, etc.)
Wow, so much more time consuming than I would have thought. I suppose I should be getting used to the fact that everything really takes two to three times as long as the plans say, or what I should expect, which ever is greater.
The nose is also nearly done, I have just completed cutting out the nose access hatch and finished the 4 ply canard attachment renenforcement layups.
I also have picked up a mickey mouse oxy/acetylene setup and practiced some welding in preparation for fabrication of the rudder pedals. All I will say is that much more practice is in order.
Posted Image
Of course more photos and discussion at:
http://www.flyingbackward.blogspot.com/
Share this post
Link to post
Good to see that you are making constant progress. I recently started following your blog and had to catch up from day one to present. I am starting to do some research and have contacted a few people about taking over their projects. I am just learning the ins and outs of the LongEZ and what kinds of things I would like to have on my particular plan. There are still some things I am confused about but, I will get them sorted out in time. Thanks for creating a blog where folks like myself can follow along.
Share this post
Link to post
Hey Martin - if your mickey mouse torches don't work out I've got a real set you can use.
Marc
Well the mickey mouse setup seems to work ok, however even with the little practice I have done, I don't.
I have ordered a smaller size nozzle to see if that helps.
Do you have any experience with gass welding? If so and if you have some timer perhaps you can tell me what I am doing wrong.
Share this post
Link to post
#0 tip came arrived yesterday and I managed to make a couple good welds. Not pretty, but the weld penetrated withough burning through. Tried what I could to break the parts appart and the welds and they held pretty good..
More practice and I will try to make up a rudder pedal.
Share this post
Link to post
Cool - I'd grab some mild steel from Capitol Industrial (its pretty cheap right now) and some steel welding rod or even coat hanger and practice welding.
It won't be too long before you're good at it.
Will do, good idea to do more practice on cheap stuff first. I burned through my first order of 4130 tubing practicing on the bigger tip.
I have more 4130 now, and its tempting to start working with it.
Share this post
Link to post
you get the spendy rod to go with that 4130 ? like metals weld better and crack less. :P
Share this post
Link to post
Yes, I purchased some filler rod from ACS. I do want to do this right. I suppose hiring the job out would be the right way to go, but the whole idea of building the plane for me is to pick up a skill or two allong the way.
Coat hangers, maybie, for practice, but I have plenty of filler rod to last a while.
Share this post
Link to post
Recently I have worked a little more on the canopy frame and some work around the nose. I have also nearly finished the rudder pedals.
Not pretty, but I think they should work out ok. Im not super proud of them, but I think they are all right considering they are the first parts I have welded myself.
I still need to work out some sort of attachement for the master cylinders. Some recent posts by others have given me some good information, however if anyone has some additional ideas on front mounted master cylinders I would appreciate the input.
Posted Image
Posted Image
Posted Image
as usual, more and larger images at:
Share this post
Link to post
I expect a package of hardware from ACS to arrive tomorrow that will allow me to complete the installation of the rudder/brake pedals.
Here are some photos of my brake setup:
Posted ImagePosted ImagePosted Image
Hire resolution images are available at:
Share this post
Link to post
Looks like things are coming together nicely. I'd like to come take a gander again in the not too distant future, if possible.
I'm up in Victoria right now with a fishing boat in the drydock but I'll be out of here toward the end of next week.
I'll give you a shout when I get back.
Keep up the good work.
Share this post
Link to post
It's been a little too cold here until just lately, so progress has been slow.
Its been a tad warmer over the last few day so I managed to complete the center section spar shear web last evening.
Posted Image
More photos of my center section spar progress are at:
Share this post
Link to post
Nice job on the spar. If you work on it over the holiday's it will be done by New Years!
I hope to get some work done, but I have been digging out of the 20" of snow around my place....
Cheers!
Jeff
Share this post
Link to post
Well, I didn't complete the spar by new years. But it is done now..
The Long-EZ plans now call for the spar to be permenantly installed in the fuselage. I think however that I will hold off on that for now. With the spar and canard installed, my EZ takes up a huge amount of space in the shop.
Instead I am considering skipping ahead and constructing the wings. With those out of the way I think I will cut down the size of the work table.
Also I see some cozy and other long-ez folks are aligning the wings to the center spar before mounting it to the fuse.
Any thoughts on this strategy?
Posted Image
Posted Image
more photos at...
Share this post
Link to post
... Also I see some cozy and other long-ez folks are aligning the wings to the center spar before mounting it to the fuse.
I can't speak for the two place canards, but leveling the spar and two wings is a whole lot less 'space intensive' than leveling the fuse, spar, and two wings on a Cozy.
Once (when) I match drill everything, I only have to worry (if at all) about keeping leveling boards on the spar.
Besides, a pix of your spar and wings being leveled and match drilled in your kitchen/dining/living room is always a conversation starter :)
Rick
Share this post
Link to post
FWIW, I will join my wings and center spar and THEN mount them into the fuselage. There seems to be a number of advantages to doing this. One, for me, is that I still need to get my parts out of the basement, so the landing gear, wings, canard, spar and headrests will all have to go as separate pieces. I'll assemble them out in the barn.
Phil Kriley
Cozy #1460
Chapter 13 - nose
Share this post
Link to post
