bmckinney10 15 Posted December 17, 2019 I have purchased N40LC, originally built by Lynn Coltharp from Oklahoma. Lynn finished the VE in 1980 and put 569 hours on it over the next 29 years. He flew it out of his airpark home with a 2500' runway. He sold it in November of 2018, and it was resold again earlier in this year (2019). The last owner repainted it and added a nice interior. He decided he would not be able to finish his PPL anytime soon and did not want the VE to sit idle for several years. I started looking for a VE/LE in August and came across N40LC on Barnstormers. I inspected it in October. Everything seemed tight and clean, and the O-200 ran smooth. I bought it and picked it up (by trailer) two weekends ago. Lynn, the original builder, (now 79 yrs old) was the last to fly it and I had a lengthy discussion with him last month, going over his build process and experiences with N40LC. I was able to get all of his build logs, pictures, receipts, and documentation. It appears to have been meticulously built and well maintained. It was well kept during its years of non-flying. It needs some updating and small changes that I have started to work on. I will provide updates along the way as I progress. Here are some of the tasks I will be doing: - Re-balance all control surfaces - Change springs on elev. trim system and rudders - Add a starter - Add a an oil filter adapter (maybe) - Replace most of the wiring - Remove Garmin 250XL - New comm radio - ADS-B out (uAvionix) - New tires/tubes - Swap out pushrod nose gear with wormgear - New canopy seals - New ELT - Rewrap exhaust - New W&B I attached a picture of it when it was new in 1980, and a few recent pictures of it after I acquired it. I had two of my daughters help put the wings back on this past weekend. Note that it has the wing cuffs, not the vortilons, which was the initial suggested wing improvement from the CP's. I appreciate all of the knowledge on this site and the help I have received so far. I am looking forward to being a VariEze owner! 1 Quote Share this post Link to post Share on other sites
Kent Ashton 239 Posted December 17, 2019 That looks nice! I have never seen that pushrod gear mechanism--weird. The usual elevator trim springs on the EZs are a poor design IMO. It takes high friction to hold a trim setting which makes it hard to move the trim and one spring is pulling against the other . You might like the idea in this picture. It uses a "Davenport" fiberglass trim spring and the lever adjustment. https://www.canardzone.com/forums/topic/18661-kents-long-ez-project/?do=findComment&comment=61752 Starter: When I see people start those Varis, it looks like all it takes is a casual flip or two and they're going. If you install a starter (heavy) you might need heavy cables from a battery in the nose to the starter and extra relay. One of the attractions of the Vari is the ease of hand-propping. I hand propped my O-320 Cozy for a while and finally installed a starter when all I really needed was a primer mounted on the baffles so I could give it a shot or two of prime and flip it (I had a pumper carb at that time--not a good priming method). Plus it looks cool. :-) Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Share this post Link to post Share on other sites
2High2Fast 4 Posted December 17, 2019 Oh, the "Ferrari!" It was interesting that he originally posted a $25k price, then removed the price entirely. I'm guessing you got a good deal. Removing the Ferrari logos would have been near the top of my to-do list, too! Congrats! Quote Share this post Link to post Share on other sites
jridge 6 Posted December 17, 2019 Will be interesting to read about the updates you do to it. Jeff Quote Share this post Link to post Share on other sites
Marc Zeitlin 77 Posted December 17, 2019 18 hours ago, bmckinney10 said: I inspected it in October... Note that it has the wing cuffs, not the vortilons, which was the initial suggested wing improvement from the CP's. Who did the pre-buy examination, and how much does it weigh as-is? Are you going to switch from cuffs to vortilons? Quote Marc J. ZeitlinBurnside Aerospacemarc_zeitlin@alum.mit.eduwww.cozybuilders.org copyright © 2020 Share this post Link to post Share on other sites
bmckinney10 15 Posted December 18, 2019 12 hours ago, Kent Ashton said: That looks nice! I have never seen that pushrod gear mechanism--weird. The usual elevator trim springs on the EZs are a poor design IMO. It takes high friction to hold a trim setting which makes it hard to move the trim and one spring is pulling against the other . You might like the idea in this picture. It uses a "Davenport" fiberglass trim spring and the lever adjustment. https://www.canardzone.com/forums/topic/18661-kents-long-ez-project/?do=findComment&comment=61752 Starter: When I see people start those Varis, it looks like all it takes is a casual flip or two and they're going. If you install a starter (heavy) you might need heavy cables from a battery in the nose to the starter and extra relay. One of the attractions of the Vari is the ease of hand-propping. I hand propped my O-320 Cozy for a while and finally installed a starter when all I really needed was a primer mounted on the baffles so I could give it a shot or two of prime and flip it (I had a pumper carb at that time--not a good priming method). Plus it looks cool. :-) The pushrod was the original design in the plans. The builder had planned to install the worm gear, but decided it was fine. I am 50/50 on the starter. I already have a Skytec for the O-200. I’ll try the hand prop and see. Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted December 18, 2019 10 hours ago, 2High2Fast said: Oh, the "Ferrari!" It was interesting that he originally posted a $25k price, then removed the price entirely. I'm guessing you got a good deal. Removing the Ferrari logos would have been near the top of my to-do list, too! Congrats! The emblems popped right off with a few seconds of heat gun. Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted December 18, 2019 6 hours ago, Marc Zeitlin said: Who did the pre-buy examination, and how much does it weigh as-is? Are you going to switch from cuffs to vortilons? Me Rough weight was 690. Not many accessories.. Not planning to switch. Builder had no concerns during his flight time and kept the cuffs. Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted December 18, 2019 (edited) 21 hours ago, Kent Ashton said: That looks nice! I have never seen that pushrod gear mechanism--weird. The usual elevator trim springs on the EZs are a poor design IMO. It takes high friction to hold a trim setting which makes it hard to move the trim and one spring is pulling against the other . You might like the idea in this picture. It uses a "Davenport" fiberglass trim spring and the lever adjustment. https://www.canardzone.com/forums/topic/18661-kents-long-ez-project/?do=findComment&comment=61752 Starter: When I see people start those Varis, it looks like all it takes is a casual flip or two and they're going. If you install a starter (heavy) you might need heavy cables from a battery in the nose to the starter and extra relay. One of the attractions of the Vari is the ease of hand-propping. I hand propped my O-320 Cozy for a while and finally installed a starter when all I really needed was a primer mounted on the baffles so I could give it a shot or two of prime and flip it (I had a pumper carb at that time--not a good priming method). Plus it looks cool. 🙂 Here's the clip from the manual for the original nose gear control. Simple system, but the pushrod is a bit uncomfortable against your right leg when retracted. The graphic shows the pushrod in the extended position, but shows the gear retracted. In reality, when the gear is retracted, it is sticking out about 12" into the seating area (see picture above). Edited December 18, 2019 by bmckinney10 Quote Share this post Link to post Share on other sites
Kent Ashton 239 Posted December 18, 2019 Good 'ol Burt. You couldn't get a much lighter mechanism that that. Here are some Variezes being propped. Personally, I would put the primer back on the baffles. Electronic ignition also helps. I had an airplane that primed via an accelerator pump in the carb but it was problematic and can cause an engine fire if the engine backfires. A dedicated 2-cylinder primer is better. Have fun! https://youtu.be/okakTWbYPV4 https://youtu.be/r5mrYjWEVEA Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Share this post Link to post Share on other sites
macleodm3 65 Posted December 18, 2019 7 hours ago, Kent Ashton said: Here are some Variezes being propped. Can't forget this one! https://www.youtube.com/watch?v=dU-zw5k2I-I 1 Quote Andrew Anunson I work underground and I play in the sky... no problem Share this post Link to post Share on other sites
bmckinney10 15 Posted December 19, 2019 18 hours ago, macleodm3 said: Can't forget this one! https://www.youtube.com/watch?v=dU-zw5k2I-I Great video, never saw this before. It shows the nose-gear pushrod system that I currently have... 1 Quote Share this post Link to post Share on other sites
Ron Springer 16 Posted December 19, 2019 Mine was modified with a spring-loaded locking mechanism so that the rod didn't have to be swung to the right and interfere with your right leg, as shown below. Quote Share this post Link to post Share on other sites
vezePilot 4 Posted December 27, 2019 (edited) On 12/17/2019 at 9:21 PM, bmckinney10 said: Me Rough weight was 690. Not many accessories.. Not planning to switch. Builder had no concerns during his flight time and kept the cuffs. VariEze N111JK (built by Joe Kendrick, Grand Junction, CO) weighed 695 when we bought it in 2004. It's a little heavier now, with Becker COM & XPDR, nicer seat cushions & wheel pants. What approach and landing speeds did the original builder mention? One Juliet Kilo also still had the LE Cuffs, and it would dutch roll on approach at less than 100 MPH. Adding the LE Vortilons and TE Fences were great and very worthwhile additions. VariEze N111JK "Dreamland" at Yankton, SD 2017; And "Dreamland" at home base Longmont, CO just last week, preparing for ADS-B qualification flight: Edited December 27, 2019 by vezePilot Quote Share this post Link to post Share on other sites
vezePilot 4 Posted December 27, 2019 On 12/16/2019 at 8:27 PM, bmckinney10 said: I have purchased N40LC, originally built by Lynn Coltharp from Oklahoma. ... I appreciate all of the knowledge on this site and the help I have received so far. I am looking forward to being a VariEze owner! I plan to update the flight models for canard homebuilts for the X-Plane flight simulator. Our VariEze in X-Plane was extremely helpful when my wife and I each did our first Solo flights. Our very first approaches resulted in good landings, after flying the plane in the simulator. We felt familiar with and comfortable, flying the plane for the first time. Legacy flight models for X-Plane v9 and v10 are available (free) here: http://vigilanceaero.com/X-Plane/Flight_Models/Flight_Models.html And updates for X-Plane version 11 are planned for the next few months. Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted December 27, 2019 Very nice Curt! He didn't mention anything negative in regards to the handling with the cuffs. He put almost 600 hours on it in this configuration. He lived on a 2500' airpark strip and said he regularly flew himself and a neighbor (near/at) max gross. I am planning to visit the RAFE guys in TN at some point to get canard training time prior to flying my VE. I will look into the X-Plane sims. Thanks! Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted December 27, 2019 Self-inflicted fuselage damage... We were working through the re-wiring job today and noticed that we have a crack on the left side just under the canard area. I believe this was due to our ratchet strap being tightened a bit too much during shipping and causing an inward flex on the thinner part. The inside shows no cracks, but the outside has the crack and flex that should not be there. Noticed that that the right side seems a bit thicker in this same area. We will have to strip off the paint a see what is behind it. It sounds from tapping to be roughly a 6" x 6" area heading down and aft that was affected. Quote Share this post Link to post Share on other sites
Kent Ashton 239 Posted December 27, 2019 The canard lift tabs bolt to the F22 (in an EZ). IMO, if all your layups around the F22 and inside the fuselage that tie the F22 to the fuselage seem undamaged it is probably just a matter of repairing the filling on the outside and repainting. Yeah, you probably flexed the side of the fuselage inward with your straps but if it did not distort the fuselage it is probably OK. I have a crack in the leading edge of my Cozy strake where I bumped against a hangar support. Never fixed it. I think the filler is rather brittle and will crack before there is much other damage. When you tear the fiberglass, that's when it's a big repair. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Share this post Link to post Share on other sites
bmckinney10 15 Posted December 28, 2019 Everything around F22 is good and solid. It is just the outside layer/filler. It would bug me if I left it, so it'll be repairing it. Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted January 1, 2020 What seat harness have most used for the Varieze? Mine still has the 4-point EON E8000 which was suggested in a CP to be replaced due to inadvertent opening with the latch system. Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted January 7, 2020 So we have successfully hand-propped the VE a few times. Fairly easy as we figured out the proper process. But, this ended up being much easier. VariEze Starter.mp4 Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted January 25, 2020 Some updates on N40LC... Completed Work - finished up the starter installation - moved the breather tube to the other end of the engine - pulled new mag wires when pulling the new starter cables - cleaned up the wiring in the engine compartment - removed the GNC-250XL - installed a GTR-200B - CNC/3D print new panel for new mag switches, starter breaker and start button, pilot headphone/mic jacks, USB charging ports (see pic below) - rewired everything behind the panel - changed oil/cleaned screen - new air filter - new quick connect on trim servo - removed unused/old wiring Upcoming - new plugs & new mag harnesses - co-pilot headphone/mic. jack panel & mount - investigate alternator & regulator - new canopy lock - rewire canopy/throttle/gear safety switch circuits - 3D print bezel for GTR-200BFurther Out - fix aforementioned skin crack/delamination below canard - "EXPERIMENTAL" & N-number decal install - new canopy seal - service wheels/brakes - ELT - ADS-B out Quote Share this post Link to post Share on other sites
Kent Ashton 239 Posted January 25, 2020 (edited) Seems a bit unusual to run 40 amps through the cockpit for the starter. Normally one would use a small current from the cockpit button to operate a starter relay. If all the starter current goes through the button, it has to be a pretty stout button to avoid welding the contacts together. Take a look at Bob Nuckolls' diagrams if you are not familiar with them. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/ The usual way is to route the battery and starter currents through the master contactor, then to the starter contactor and starter. The master contactor is not designed to switch starter amperage but after the master is on, it can pass through that amperage. If the starter contactor sticks, you can turn off the master. Those airline-style belt buckles are pretty common. No need to change unless you just want some high-buck belts. Edited January 25, 2020 by Kent Ashton Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Share this post Link to post Share on other sites
A Bruce Hughes 0 Posted January 25, 2020 It is more convenient IMHO to put the headphone and mic jacks behind your left (or right) shoulder so the wires are not always in the way. Bruce Hughes Quote Share this post Link to post Share on other sites
bmckinney10 15 Posted January 26, 2020 13 hours ago, Kent Ashton said: Seems a bit unusual to run 40 amps through the cockpit for the starter. Normally one would use a small current from the cockpit button to operate a starter relay. If all the starter current goes through the button, it has to be a pretty stout button to avoid welding the contacts together. Take a look at Bob Nuckolls' diagrams if you are not familiar with them. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/ The usual way is to route the battery and starter currents through the master contactor, then to the starter contactor and starter. The master contactor is not designed to switch starter amperage but after the master is on, it can pass through that amperage. If the starter contactor sticks, you can turn off the master. Those airline-style belt buckles are pretty common. No need to change unless you just want some high-buck belts. I retained the existing electrical circuit similar to what was specified in the LEZ manuals. It utilizes a 20 amp toggle switch instead of a master relay. I have 5 existing breakers for the radio, elt, instruments, trim servos, etc. that were already in place. There was no room for another breaker in the original location for the starter, so I put it in the new panel I made. The large cable starts at the battery in the nose, runs to the push-pull 40A breaker, then to a start solenoid located behind the panel, then runs to the starter in the back. The small push button only activates the starter contactor, just as a normal start circuit would as you described. If I have a starter stick, I can just pull the breaker which is only is for the new starter. As for the headphone/mic jacks, I considered the behind-the-shoulder setup, but preferred to have them in the front. The are near the center of the panel, so not in the way of the left & right hand controls. Quote Share this post Link to post Share on other sites
