cs 131
steve
You might find it in the Cozy CPs. In the Long-EZ plans it's listed as 4130 3/8th tube with .065 wall.
Apparantly they didn't copy everything over when they made the Cozy plans.
AeroCanard plans have the same error.
I'm working from memory here, (Plans are at the hangar), but aren't those the little 1/8"-1/4"spacers made from tubing and go up against the canard push rod/canard attach point?
If so, use 4130.
I remember having a dickens of a time finding the drawing on them as well.
Of course, I could be totally wrong.....:o
"I run with scissors."
Cozy MKIV N85TT
Phase One Testing
If so, use 4130.
it holds the "L" in the root of the wing
the two thin al bkts that bolt to the rear of the wing have a bolt(an4) that holds the bearing. this spacer is inside the bkts.
mud,clear as
Steve M. Parkins
thx greg,
that jerry guy just cant be trusted, did you know he lives in a tent ?
Not anymore. I now live in a hangar. Just part time. The rest is in the sky. I flew her myself yesterday.:banana: :banana: :banana: :banana:
You can trust me, just not my memory. (Got the 4130 part right, though.:) )
Cozy MKIV N85TT
Phase One Testing
Well that was a pretty sneaky way to slip that news to us! A big CONGRATS Jerry!!!! I was wondering when that step would be. I am sure others were also. Please give us your impressions!!! VERY GOOD.:D
Self confessed Wingnut.
Get up off that couch!!! =)
What great news, Jerry. I'll bet you have a smile a mile wide right now. Good for you!!!
Kraig
P.S. Now how about a report.
Kraig
See the thread "Web-Slinger LIVES" on this forum, if you already haven't. The only thing to report at present, is I'm looking at doing some moderate re-working of the downdraft plenum on top fo the engine. Some silly theory about "expansion".:irked: That will happen over the next 2 weeks. Cooling continues to haunt me.
Cozy MKIV N85TT
Phase One Testing
Jerry. have you taken any pressure differential readings? the manometer does not lie. you need at least 4" WC of differential pressure to cool a lycoming. making changes on theory is a waste of time. I have seen many plenum designs that work and most of the time it is the duct and inlet design that is the problem. if the duct is to long or to small the inlet can't let the air in and the backed up air makes like a fence for the air to go around the inlet. a short duct is like an orifice and pressure drop is small but if the duct is long and has bends, it will use up all the available pressure before it can get to the engine. every 90 degree bend is like adding ten feet of duct
Not yet. I have a altimeter setup I will install to check though. Lycoming states 6" of water pressure differential is optimum.The changes I plan to make will be making my system look more like Ken Laundrie's, which has been running very cool indeed. Not really making changes based on theory, but based on copy-cat-ing.:D
Cozy MKIV N85TT
Phase One Testing
was looking for the cs 131 in the book and it said to look on page 16-3, so i did. and there is nothing there:yikes:
is this mistake # 32 or did i miss something ?
CG's can you help me plz:o
is it 2024 ? 0r 4130?
Had to go check our drawing, ours are 4130
CG Products
www.CozyGirrrl.com
Cozy Mk-IV RG 13B Turbo
i was not able to build it the way it is shown in the plans.
the bearing is recessed and will need to be supported on both sides.
girls, do you sell a .2 to go with the .6 spacer ? one for both sides ?
or do you just washer one side ?
(i cant believe jerry tryed to swipe my thread, probably a boring flt anyway:thumbsup: )
Steve M. Parkins
