gullikson Posted January 20, 2009 Share Posted January 20, 2009 The part of the plans for the wings and canard that is making me scratch my head is where you are putting the trailing edge peel ply on and holding it in place with small brads, tacks, or staples prior to glassing the lower skin. Maybe it's self-evident when you get to the point were you are cutting the fish tail off the upper surface but.... what do you do with the brads, tacks, or nails.... dig them out of the lower skin, shave the pin portion off flush with the fiberglass ply or what? What have you canard and wing veterans done about this? I'm prepping for wings and canards and this has got me wondering. Quote Link to comment Share on other sites More sharing options...
TMann Posted January 20, 2009 Share Posted January 20, 2009 I hardshell so I add the peel-ply at that time and let the micro hold it in place. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted January 20, 2009 Share Posted January 20, 2009 .... what do you do with the brads, tacks, or nails...They come off with the peel ply. Quote Marc J. ZeitlinBurnside Aerospacemarc_zeitlin@alum.mit.eduwww.cozybuilders.org copyright © 2023 Link to comment Share on other sites More sharing options...
gullikson Posted January 20, 2009 Author Share Posted January 20, 2009 They come off with the peel ply. Thanks Marc, of course they come off with the peel ply. This is one of those infrequent(thankfully) situations where I knew exactly how the sequencing worked but for some reason I had the notion that the brads/tacks went through the lower skin, even though I looked at the drawings showing it otherwise, over and over. Boy, it hurts overlooking the plainly obvious! Thanks again, Greg Quote Link to comment Share on other sites More sharing options...
rickh Posted January 21, 2009 Share Posted January 21, 2009 I *just* pulled the peel ply off the trailing edge of my canard last night. I used staples from my desk stapler, inserted them one leg at a time else the foam dented. Try *REAL* hard to have a straight edge on the peel ply, if you cut the strip from a bulk roll (I do). Shoot for no more than 5/8" on the fishtail, else you'll be pulling up a wad of foam, or digging out remaining fuzzies Saw the tail somewhat close (don't sweat this) like just shy of your staple length, then score the foam at the 1/2" mark w/ your knife. Now pull up the peel ply. Umm, I had some micro (from skinning the bottom) ooger down on the trailing edge, and it's somewhat of a pain squeeging the fish tail. I used the top edge of my squeege for this though, it had a nice hefty radius. YMMV... Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
JTest Posted January 21, 2009 Share Posted January 21, 2009 The part of the plans for the wings and canard that is making me scratch my head is where you are putting the trailing edge peel ply on and holding it in place with small brads, tacks, or staples prior to glassing the lower skin. Maybe it's self-evident when you get to the point were you are cutting the fish tail off the upper surface but.... what do you do with the brads, tacks, or nails.... dig them out of the lower skin, shave the pin portion off flush with the fiberglass ply or what? What have you canard and wing veterans done about this? I'm prepping for wings and canards and this has got me wondering. G'day I used strait pins and they didn't all come out when I removed the peel ply. I just sanded them out or pulled them with needle nose. Hope this is some help; Jeff Quote Link to comment Share on other sites More sharing options...
gullikson Posted January 21, 2009 Author Share Posted January 21, 2009 Thanks all for the replies to my quandry. It is very clear now. I don't know what, or why, I was thinkin' what I was. Cheers, Greg Quote Link to comment Share on other sites More sharing options...
dirtdox Posted January 23, 2009 Share Posted January 23, 2009 In the EAA composite workshop that I did we built a canard section. They had us lightly coat the peelply on one side with spray adhesive and stick it on. Quote Link to comment Share on other sites More sharing options...
TMann Posted January 23, 2009 Share Posted January 23, 2009 Glad you posted that. I was kicking that idea around as a possibility. I cut my cores last night with the assistance of another builder who lives 2 doors down from me. Depending on how it goes, I may try this out within the next week. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
