gullikson Posted December 26, 2008 Share Posted December 26, 2008 Is a Nav antenna still needed now with all of the really good GPS systems out there? I am getting ready to start the canard in the next couple of months and don't want to install a Nav antenna if I really don't need it. I am not currently flying so I'm not up to speed on the requirements or desirements;) Quote Link to comment Share on other sites More sharing options...
TMann Posted December 26, 2008 Share Posted December 26, 2008 I put two in my canard. One in case I need a backup. It's for more than just VOR. You get weather there as well. Don't make yourself solely dependent on GPS alone. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
gullikson Posted December 27, 2008 Author Share Posted December 27, 2008 Thanks T Mann. I appreciate your insight. I guess it won't hurt to put it in regardless, that way I have options. Just looking for ways to save weight and didn't know in this case. Thanks again. Greg Quote Link to comment Share on other sites More sharing options...
JTest Posted December 28, 2008 Share Posted December 28, 2008 G'day If you plan to use ILS or LOC approaches you will need a Nav antenna. Jeff Quote Link to comment Share on other sites More sharing options...
steve Posted October 17, 2009 Share Posted October 17, 2009 what ant will go in the winglet left and in the right ? com,vor,elt,gps ? Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
Kent Ashton Posted October 17, 2009 Share Posted October 17, 2009 A nav antenna will also do well for an AM/FM radio if you want one. I installed two; one to the nav radio and I use the spare one with an AM/FM radio. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Waiter Posted October 18, 2009 Share Posted October 18, 2009 Winglets - Vertically Oriented, VHF Comm. Put one in each winglet, that way your covered for Comm1 and Comm2 (Comm transmitters cannot share same antenna) Canard - Horizontally Oriented - Nav, is best, but, this will also work as a Comm. Your range will be significantly reduced because of the orientiation. It will work, I use it for my comm2 (I didn't install antennas in both winglets, and I no longer have a Nav). it works OK for ATIS, ground control, anything that is close. Gear leg - Loran (No longer used, but connects to my AM/FM radio. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
steve Posted October 18, 2009 Share Posted October 18, 2009 Winglets - Vertically Oriented, VHF Comm. Put one in each winglet, that way your covered for Comm1 and Comm2 (Comm transmitters cannot share same antenna) Canard - Horizontally Oriented - Nav, is best, but, this will also work as a Comm. Your range will be significantly reduced because of the orientiation. It will work, I use it for my comm2 (I didn't install antennas in both winglets, and I no longer have a Nav). it works OK for ATIS, ground control, anything that is close. Gear leg - Loran (No longer used, but connects to my AM/FM radio. Waiter thanks , i'll follow your lead ! Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
