Upali Posted May 7, 2021 Share Posted May 7, 2021 Quick question: What is everyone using as sanding blocks for flat surfaces like wings or canards? Can I adopt an aluminum tube similar to the one below? I can make sure it will be flat enough and I am looking for about 36" block. https://www.ebay.com/itm/284030303143?hash=item4221867ba7:g:1UYAAOSwN2RfdQ6Y Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted May 7, 2021 Share Posted May 7, 2021 Serveral discussions on this page https://www.canardzone.com/forums/topic/18661-kents-long-ez-project/page/13/?tab=comments#comment-62441 IMO 36" is unwieldy and you have to glue long sandpaper to it. I use pieces of 2X4 about 18" long, round the ends slightly and staple or tack belt-sander belts to them. However, an aluminum bar is useful as described above. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Upali Posted May 8, 2021 Author Share Posted May 8, 2021 Thanks for the tips Kent. I will see if I can use a 2X4 piece. Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted May 8, 2021 Share Posted May 8, 2021 9 hours ago, Upali said: Can I adopt an aluminum tube similar to the one below? I can make sure it will be flat enough and I am looking for about 36" block. Yes, that would work, _IF_ the extrusion is perfectly straight and flat. There are few 2x4's on the planet that are flat/straight enough to use for a sanding block - you'd never get a really good contour. 3" is a bit narrow, although it would take a 3" roll of paper. I used a 1/2" thick piece of plexiglass as large as 3 sheets of 3M wetordry sandpaper, and glued a 2" x 2" AL extrusion to the back to keep it straight. With 3 sheets of paper on it, being about 33' - 36" long, you get really good coverage and straightness/flatness on your contours. 18" is marginal for wing/canard contouring, IMO. The larger the sanding block, the better your contour will be. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
Kent Ashton Posted May 8, 2021 Share Posted May 8, 2021 11 hours ago, Marc Zeitlin said: Yes, that would work, _IF_ the extrusion is perfectly straight and flat. There are few 2x4's on the planet that are flat/straight enough to use for a sanding block - you'd never get a really good contour. 3" is a bit narrow, Well, whatever floats your boat but this block (16") and aluminum bar have finished three airplanes. "The poor carpenter blames his tools." 🙂 1 Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted May 8, 2021 Share Posted May 8, 2021 1 hour ago, Kent Ashton said: Well, whatever floats your boat but this block (16") and aluminum bar have finished three airplanes. "The poor carpenter blames his tools." 🙂 Well, yeah, I could wrap a piece of 80 grit around a ball-peen hammer and contour a plane, but it wouldn't be pretty :-). I'm shooting for optimal, not adequate here :-). Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
Upali Posted May 8, 2021 Author Share Posted May 8, 2021 Thanks guys! I already bought duragold 2-3/4" (width) sandpaper rolls. Should I go for larger width or will this work? Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted May 8, 2021 Share Posted May 8, 2021 2 hours ago, Marc Zeitlin said: Well, yeah, I could wrap a piece of 80 grit around a ball-peen hammer and contour a plane, but it wouldn't be pretty :-). I'm shooting for optimal, not adequate here :-). Pissch! I can contour an award-winner with a concrete block! Usually start with a regular block, then go to a red stepping stone for a finer finish. Next airplanes we build, we will have to hold a contest 🙂 49 minutes ago, Upali said: I already bought duragold 2-3/4" (width) sandpaper rolls. Should I go for larger width or will this work? Those should work but 20 yards is enough for 4 airplanes. You need various grits though. 36 to get started, then finer. 220-240, 320 Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Countach74 Posted May 8, 2021 Share Posted May 8, 2021 I use a 48" Great Planes Easy Touch aluminum extrusion. They are discontinued at this length, but are found used on EBay or rc airplane classifieds. Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted May 8, 2021 Share Posted May 8, 2021 3 hours ago, Kent Ashton said: Pissch! I can contour an award-winner with a concrete block! Usually start with a regular block, then go to a red stepping stone for a finer finish. Next airplanes we build, we will have to hold a contest 🙂 Hah! When I was a boy, we'd contour sand with a wet strand of spaghetti, wrapped with hot gravel. You try to tell kids these days, and they won't believe you. In any case, it'll be a cold day in hell before I build myself another airplane, so this contest will have to occur in another lifetime... 2 Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
Upali Posted May 8, 2021 Author Share Posted May 8, 2021 Thanks guys for all the insight! Will be back with tons of questions once I start the project. Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted August 9, 2021 Share Posted August 9, 2021 From Nick Ugolini's blog, he builds a copy of an off-the-shelf tool that I'd want to use for long sanding. Nick Ugolini's Blog » Search Results » flexisander Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
