TMann Posted June 19, 2008 Share Posted June 19, 2008 Well I'm getting to the point where I'm going to start on my wings and center section spar. In checking my table out, it has developed a sag in the middle. (I have casters at both ends.) So it's table rebuild time. This time I used the I-Joist method I've seen here from some of the other builder input. I bought 4 12 footers x 9.5 inches. I also bought 4 more casters for a total of 8. There are now two four foot cabinets under the table with casters in the corners. That leaves me with no more than 4ft that is being spanned without support. I replumbed it for my vacuum bagging setup as well as rewired. This time I made sure I had some room for my vacuum resevoir (a propane tank) INSIDE the cabinet vs. hanging off of an eye-bolt on the end. All I have left to do is lay the formica and I'm back in business. I checked it against a 1 x 4 x 144 piece of extruded aluminum last night and it is super straight! The top of the work surface sits about 32 inches high which makes it pretty easy to reach accross. Now, back to that canard! Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Kent Ashton Posted June 20, 2008 Share Posted June 20, 2008 You don't have to rebuild the table. When you set the wing or canard jigs on the table, clamp them in place temporarily and stretch several tight nylon strings or fishing line across the jigs and shim the jigs to the same height. Build aircraft components, not tables! :-) -Kent Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Steve Innova Posted June 20, 2008 Share Posted June 20, 2008 I don't regret one minute I spent building a good table... Quote Link to comment Share on other sites More sharing options...
steve Posted June 20, 2008 Share Posted June 20, 2008 I don't regret one minute I spent building a good table...if you can build a good table then you too can build a good plane.i like the string trick, hope to remember it:o Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
rickh Posted June 20, 2008 Share Posted June 20, 2008 if you can build a good table then you too can build a good plane. i like the string trick, hope to remember it:o I like the build good table trick, hope to remember it. Be inn a karpentur, I kan build lots of good tables. Some don't even make it to the fire pit! Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
