tdale4 Posted January 30, 2004 Share Posted January 30, 2004 Is anyone planning on using a Mazda rotary engine with an electrical in-flight adjustable prop....like the IVO model? Tim Quote Link to comment Share on other sites More sharing options...
dust Posted February 2, 2004 Share Posted February 2, 2004 i think some are, but are afraid to speak because of problems that have ocurred with ivo props on 4 cylender AC engines, and they don't want to be told how stupid they are. enjoy the build dust Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
cncdoc Posted February 2, 2004 Share Posted February 2, 2004 I would like to use a CS prop, but I'm hoping a year or so from now the other shoe will drop (instead of other airplanes) and there will have been advancement made in the semi-non-FAA-certified CS prop arena. I'd like to think that the term "experimental", referring to the Cozy, is just a technicality. When it comes to a propeller (air slicing device), I want someone else to get all the experimenting out of the way before I lash it to my backside and point myself in harm's way (anywhere from up is down). There is enough trouble with known good prop systems. I am keeping an eye out for changes though. CS propeller equipment would complete the rotary ensemble, especially if it is as light as they say it is... If you change your mind, it's one of the last things to do and a retrofit is not that big of a deal... Quote Back to building... #618 Cozy MK IV My Cozy web pages, courtesy: Rick Maddy... WN9G Link to comment Share on other sites More sharing options...
John Slade Posted February 3, 2004 Share Posted February 3, 2004 Paul Lamar and a few others from the ACRE list have been working on an adjustable prop design. I think they have the prototype ready for testing on the dyno. It's taking a long time, but it might bear fruit eventually. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Jim Sower Posted February 3, 2004 Share Posted February 3, 2004 Trouble with CS props on pushers is the extra loads on the hub and blade base. Nobody knows for sure just HOW much more stressful it is, and it probably varies substantially from one plane to another. ALL CS props are designed for tractors, and the manufacturers who have what they feel is a stout enough design allow it to be used on pushers. I'm afraid I'll have to stay with fixed pitch for the forseeable future. Besides, I couldn't afford a CS prop even if I had a tractor. Quote ...Destiny's Plaything... Link to comment Share on other sites More sharing options...
HM Andersen Posted February 3, 2004 Share Posted February 3, 2004 Variable pitch has been used by Uli Wolters in Germany where a lot of nice props are being manufactured. Hope this works 1. time tried Helgeusers.sisna.com/dbmonk/nl24.htm Quote Plane will be called `Hugin` After Odins raven Link to comment Share on other sites More sharing options...
HM Andersen Posted February 3, 2004 Share Posted February 3, 2004 You can find more on MT props on:www.mt-propeller.com Helge Quote Plane will be called `Hugin` After Odins raven Link to comment Share on other sites More sharing options...
dust Posted February 3, 2004 Share Posted February 3, 2004 Well, you answerred my question for those who need an elec prop, i have already decided on an oil cs mt prop, just didn't realize that they had elec also enjoy the build dust Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
PeteK Posted June 12, 2005 Share Posted June 12, 2005 My understanding is that there some laminated wood props that are "semi-constant speed". In other words, they flex to kinda sorta maintain a narrow speed range. Maybe this is something to look at? Quote Link to comment Share on other sites More sharing options...
Waiter Posted June 12, 2005 Share Posted June 12, 2005 Prince Prop did this a little. This was the best fixed pitch prop I had on my EZ, that is until an exhaust valve took off the outer 8 inches on one blade. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
deronjthomas Posted June 14, 2005 Share Posted June 14, 2005 until an exhaust valve took off the outer 8 inches on one blade. Waiter That got to hurt! Where you in mid air at the time? Quote Link to comment Share on other sites More sharing options...
Waiter Posted June 14, 2005 Share Posted June 14, 2005 Lycoming running on 3 cylinders sure do shake, bad. Cruising along at 5500 ft, Pop, mild vibration, then BANG. Violent shaking, Pulled the power back to a very rough idle. Declared an emergency with Bay Approach (San Francisco), Advised them I had enough altitude to dead stick to Reid Hillview Airport (about 4 miles away). Turned the fuel valve OFF. High overhead approach for a high key entry, made it at about 2,500 ft. Entered low key right on the money at 1,000 ft, Continued the turn to base, check gear down, around to final. Using the speed brake for energy. Landed a little long. Had enough energy on the roll out to clear the runway. Stopped the plane, breathed again, Then I started shaking more violently then the plane. Training pays off POSTMORTEM - Big chunk missing out of the cylinder. Evidently when the valve broke, it rattled around inside the cylinder,for a couple milliseconds, punched a hole in the top of the cylinder, then went out through the exhaust pipe. The timing was absolutely perfect, as the prop blade and the valve collided. The valve won, taking off the outer 8 inches of the blade. Damn that was a good prop. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
PeteK Posted June 16, 2005 Share Posted June 16, 2005 Lycoming running on 3 cylinders sure do shake, bad. Cruising along at 5500 ft, Pop, mild vibration, then BANG. Violent shaking, Pulled the power back to a very rough idle. Declared an emergency with Bay Approach (San Francisco), Advised them I had enough altitude to dead stick to Reid Hillview Airport (about 4 miles away). Turned the fuel valve OFF. High overhead approach for a high key entry, made it at about 2,500 ft. Entered low key right on the money at 1,000 ft, Continued the turn to base, check gear down, around to final. Using the speed brake for energy. Landed a little long. Had enough energy on the roll out to clear the runway. Stopped the plane, breathed again, Then I started shaking more violently then the plane. Training pays off POSTMORTEM - Big chunk missing out of the cylinder. Evidently when the valve broke, it rattled around inside the cylinder,for a couple milliseconds, punched a hole in the top of the cylinder, then went out through the exhaust pipe. The timing was absolutely perfect, as the prop blade and the valve collided. The valve won, taking off the outer 8 inches of the blade. Damn that was a good prop. Waiter POS Lycoming......shoulda had a rotary <ducking> Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted June 16, 2005 Share Posted June 16, 2005 Lycoming running on 3 cylinders sure do shake, bad.I think we should qualify this -- a Lycoming running on 3.5 physical cylinders will vibrate, BUT a Lycoming firing on 3 of 4 cylinders will not vibrate. I just wanted to be clear that a Lycoming with a dead cylinder will just be a less powerful engine. Correct me if I'm wrong. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Waiter Posted June 16, 2005 Share Posted June 16, 2005 A 3 cylinder Lycoming, with 8 inches missing off a prop blade, will shake so bad, you'll wonder how it even stays on the airplane. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
Jon Matcho Posted June 16, 2005 Share Posted June 16, 2005 No doubt that has to be on the top 10 scary list. What do you mean by "Using the speed brake for energy." Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
bferrell Posted June 16, 2005 Share Posted June 16, 2005 I think we should qualify this -- a Lycoming running on 3.5 physical cylinders will vibrate, BUT a Lycoming firing on 3 of 4 cylinders will not vibrate. I just wanted to be clear that a Lycoming with a dead cylinder will just be a less powerful engine. Correct me if I'm wrong. That's great - the assumptions you make, when I read that, I thought he'd lost a mag, as I was thinking, 'man it would suck to lose half of your cylinders!'.... Brett Quote --- Brett Ferrell Velocity XL/FG Cincinnati, OH http://www.velocityxl.com Link to comment Share on other sites More sharing options...
Waiter Posted June 16, 2005 Share Posted June 16, 2005 What do you mean by "Using the speed brake for energy."I arrived at High Key with more energy than I needed, so I use the drag device to get rid of that energy. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
