455 -
Posts posted by steve
then i got it backwards, i do know that the plane was regestered as Cozy out of spite to Nat becase Nat said he could not call it a cozy, so he did..SQ2000 is not a Cozy IV.
in all fairness, his neck was damage when he hit a pole. the house looked a lot more uninviting: the tb was still holding strong
sq2000 is a cozy right ? flipped over onto its top (total-loss) and c6 incomplete for the pic ( didnt read the post on johnson)Has there ever been an accident in a Cozy IV where it rolled over and came to rest upside down? Or within the accidents ground speed bleed off, flipped and had to withstand deceleration upside down?
and a c6 is by all means a snaped neck but with long pins to hold it together. 30% lose of body movement with high hopes and a cane.
winglet blend looks like 4.5, can you go 10 ?
i found the answer on a different forum..nn.
i still see a few mistakes in the 3rd planes. are we calling up spruce to have them fixed or would that be a waist of time ?
Nat emailed me and said there were no mistakes that he was a were of:irked:
i just found one in the wing layup.
" #1 layup is a 2 bid liner......
next is layup #1 the first of many sheer web......
just do 1, 2 times.....and lwa6 is 2 by 2.3 not 2 x 2 easy to miss.
could you plz tell me how to lay out the foam to do the psi test?I am going to perform tests myself with the plans foam and my local foam. Will test both peel-strength and compression. I have already tested that the plans foam are much more brittle and will break off / snap with less pressure than my local foam. If I press with a finger on the plans foam the cells will chrush leaving a big indentation while the same pressure on my local foam will result in a much smaller indentation as the cells will decompress slightly when the pressure is gone.
What I need to know is the compressive-strength on the plans foam. This value is not mentioned anywhere as far as I have managed to search. I have found tech-specs of the Dow Styrofoam FB - but this is the small-cell foam as far as I know. Does anyone have the brand-name of the large-cell-foam? Or even better - does anyone know the values of the compressive-strength? My local foam - with the same density as the plans foam (2lbs/cu.feet) has a compressive-strength at 300kN/m2 (43.5 PSI). Styrofoam FB has a compressive-strength at 200kN/m2 (29 PSI) at the same density.
i have both foams and can do it tonight.
i have the matco 2 puck, what master cyl. do i want ?is this the one? some people have had the clear plastic one crack. I have been using them for 5 years with no problem
http://www.aircraftspruce.com/catalog/lgpages/reservoirs.php
Some of the master cylinder have different bore and stroke. Give Matco a call they will know which one goes on the cozy. I have the Matco triple brake with 1.5" pistons and I use the MC 4 with the longest stroke
thanks, but you need to thank the guy that told me ...(dust)Steve, That is an excellent builder's tip.
Tip of the year to you. Sam
Nat messed up a wing core then added 1" to the center and recut it and it was like newFor someone with prior skills, that may be true.
But you left out the time and money to build the hot wire tool, for one thing. And the fact that you need TWO people to do the cutting.
I bought the cores and am very glad I did. The way I work, it saved me WEEKS. The idea of cutting all that foam, with the likelyhood that I'd mess up at least one part and have to order replacement foam and do it over again, and the effort of cutting a second set of parts backwards...and the skills needed to get the shape just right with no twist...
Not for me. I bought the CNC cut parts, checked them against the plans, and started assembly. No time spent sanding the wire marks - there were none. No worries as to the shape or making a mistake in aligning a template...
I'd say it was a very good investment!
i loved the kr2 as a kid, was looking at his web site and he had build a tank for his plane but was useing a car tubing flar tool:confused: 45 deg and an aircraft fittings 37 deg..........has he still alive ? or can he just smell lots of gas on long trips ? hope he can read this and change out the linesFor the Aussie builders - just thought Id pass on this info.
I have not purchased anything from him, just passing on the details - might be handy for sourcing the odd bolt etc, other than waiting a week or two for stuff from the US.
Regards,
Andrew
AN Hardware
Looking for AN Bolts here is another source you may not have tried. See email below.
Hi Everyone especially the Aussies.
I have been busy over the last 4-5 months setting up a new business dedicated to Australian aircraft builders.
It's called AN-BOLTS www.an-bolts.com.au
I have built the site myself and so can easily make additions and changes at the drop of a hat so let me know what you think. Stock is arriving on a regular basis and am looking to expand the range so if you are after something not listed on the site, shoot me an email.
Add it to favourites and give it a try next time you are ordering hardware.
All the best.
Darren Crompton
AUSTRALIA
My web site: www.kr-2s.com
i got a small cheep aircraft flair tool online for 49.00 usd with free shiping.
it feels like a Vega (not that we didnt want them in 1975)
but you have the means to build some thing new and cool
cozy -on-water would be fun;)
if you want good G's on that spar,you'll need mounting taps on the leading face.
think vw on top till it starts to give(plane inverted), two bolts?
not yet but i will.Not me. I don't let that stuff eat at me. I found that it takes less time overall to go back and address the issue. I don't need another thing to think about.
You minimize the risks as much as you can then you go.
Have you minimized the risks?
thats a sticky one, i would(mine, not yours) look at the attach layers to see they were 110%, then lay up 2 bid over the hole and over the tab so the tab would be covering the new lay-up and 2-3" over the side of fuz.As the photo below shows, someone has drilled through the FS-22 bulkhead in order to run lines through. Is this acceptable, and if not how could it be repaired?
(I am leaning toward acceptable )
[ATTACH]2800[/ATTACH]
BUT all bets are off if i could not clean the hole area.i dont like going over crappy bid tapes.
ps. you would need to pad the canard to fit when done.
as marc is a little over the top and im a little under, you have to fly it like tman said. its not my butt on the line.
i have 10 things on my bird i dont like and at some point i said "this will do"
even now as i type i still worry about them.......so keep track of the "O well's"
and add them to your pre-flight check list.
it looks like the N# can go on any plane.......(see 210 below)
Please log in
Email: Password:
Keep me logged in at this computer Forget your password? Click here and we'll email it to you.
UTC(Z)05:13EDT01:13CDT00:13MDT23:13PDT22:13
Home
LoginContact Us
ToolboxForumsMediaUser SettingsReferenceSupport
Search
Quick Track Select Airline, or AirTran Alaska Airlines American Airlines Continental Airlines Delta Airlines JetBlue Airlines Northwest Airlines Southwest Airlines United Airlines US Airways ---------------------- Aer Lingus Aeroflot Air Canada Air France Air Jamaica Air New Zealand Air Pacific Air Transat Air Wisconsin AirTran Alaska Airlines Alitalia Allegiant Air Allegro Airlines Aloha Airlines America West Airlines American Airlines American Eagle American Trans Air AmeriJet Atlantic Coast Airlines (United Express) Atlantic Southeast Airlines Austrian Airlines BigSky Airways British Airways Business Express Canadian Airlines International Casino Express Airlines CCAir Champion Air Chautauqua Comair Commutair Continental Airlines Continental Express Corporate Express Delta Airlines El Al - Israel Airlines ExecJets Frontier Airlines Great Lakes Aviation Gulfstream International Airlines Hawaiian Airlines Horizon Airlines Iceland Air Independence Air Jet Blue Jetstream International Airlines KLM Royal Dutch Airlines Legend Airlines Lifeguard Flights LTU Lufthansa MaxJet Airways Mesa Airlines Mesaba Airlines Miami Air Midway Airlines Midwest Express Airlines National Airlines NetJets Northwest Airlines Northwest Airlink Pace Airlines Pan Am Pennsylvania Airlines (USAir Express) Polar Air Qantas Ram Air Freight Reno Air Sabena Scandanavian Airlines System (SAS) Shuttle America Singapore Airlines Sky King Sky West Airlines Southwest Airlines Spirit Airlines Sun Country Airlines Swissair Trans World Airlines Trans World Express Transmeridian Airlines United Airlines United West Airlines USA 3000 USAirExpress/Shuttle USAirways Vanguard Airlines Virgin America Virgin Atlantic WestJet XL Airways France track
3D Flight Tracking!
As seen on NBC, ABC, CBS & CNN! click!
offline
Flightwise NewsAugust 21, 2009
Flight track for LBQ900, accident near Teterboro August 08, 2009
Hudson River collisions flight tracking information for N71MC August 08, 2009
FAA connectivity restored August 08, 2009
FAA network problems More news
POW! > Home > Flight Tracking > Track Flights
Twitter
this
flight!
What is Twitter?
Username: Password:
Text:
Characters left: empty
Appended to your Tweet:
Enter flight information
Enter the flight ID: Select Airline: Flight #: Search by: Flight ID Airline Advanced Search Options
Origin Airport: (3 or 4 letter identifier)
Destination Airport: (3 or 4 letter identifier)
Aircraft Type: (FAA type code)
General Aviation Commercial Cargo Air Taxi Other (LifeFlights, etc) Search only ACTIVE flights
Select View Mode:
Standard Map
Google Maps
3D/Google Earth
H
E
L
P
N211JP BROOKS JOHN P NEW SEARCH FULL SCREEN VIEW MODE ALERT ME
Location: 43.765, -69.968 Show World Show US Show Full Route
TIMEOUT
This flight stopped sending positional data.
Flight Details
Altitude: 11,600 ft Radio Call: N211JP
Speed: 128 kts Aircraft: C210/T Cessna Aircraft Centurion 210
VFR Information
This flight is currently flying under VFR "flight-following" rules and, as such, departure and destination information is not available.
Departure Information
Departed: OPF OPA- LOCKA EXECUTIVE
Departure Time: 08/31/2008 01:38 PM EDT (1738Z)
Air Traffic Summary Air Traffic Map Airport Info
Destination Information
Destination: NAS Unknown Airport
Timed Out At: N/A
Track in Google Earth (more info...)
Flight PlansFixesPast FlightsATC LogTrack LogLive ATC Audio FeedsNotesPhotos No flight plans were found in the database; this generally means the flight has not filed any flight plans within the past 24 hours.Fetching...
Need to see more than just the last few flights? See detailed flight history dating back to November, 2001!
Fetching...
Fetching...
Fetching...
Fetching...
Add notes... Manage notes...
Fetching...
Upload photos... Manage photos...
Fetching...
Image DisplayX
See full-size image
See more images
Still Under DevelopmentX
...the Flight Tracking elves are still at work!
This function has not been implemented yet.
Flight Plan DisplayX<retrieving data>
flightwise.com, © 2009 Aviation Data Systems, Inc
you get the spendy rod to go with that 4130 ? like metals weld better and crack less.Will do, good idea to do more practice on cheap stuff first. I burned through my first order of 4130 tubing practicing on the bigger tip.
I have more 4130 now, and its tempting to start working with it.
my hinges are in the removable dash cover.Thanks, guys.
I've been looking at various solutions on the turtleback but I haven't come so far that I have given it much thought. I have more or less decided to go the FHC-route, I have an E-racer "nearby", and I will study how he have done the hinges.
so i can remove(or install) the fhc with the pull of two piano hing pins
i have both small and large and in the testing i have done, there is nothing that the eye can see. the peel on the small cell seams to hold up better them the large. but it is so close you could change the results with room heat. so i could not find a difference.
i love your drawing ! why the hump (unlike a naca) ?
that is what it looks like on my other wing.Steve there are two types of wing templates. the stock long ez and cozy 3 and 4 have a trailing edge that is bent up at the inboard foam block. the Eracer, aero canard and sq 2000 the trailing edge is straight. the angle on the forward edge of the spar mounting surface does have a slight angle change at the outboard block because the spar is tapered at a different angle then the outboard wing taper. just make sure that both wings have the same angle.
So denice must have the eracer jigs?
i have cut the end block lose and will match it to my other wing.
thanks lynn
ps. will be in your neck of the woods on the 16th to the 29, you boys need help building anything ?
i think because of the way the paper m's are that the jig 5 (the short one) opens up as it gets wet, and some how my box in storage must of got very moist:mad: i put all the wood jigs side by side and that jig is open 1/4" at the top, in short it lets the end foam(next to spar) lift up in comparison to the rest of the wing. easy fix now, not so easy after you skin and then find it.
builder tip, cut the jigs and stack them together, you will see the need to trim just a smidgen off them.
ps. if you look in the back ground you will see the other 1/2 tip setting up.
the wing has bin cut at the sheer web (good eye)
why thanks sir, clear as mud. may all the BW-lets meet at osh in the year 2013 or so..
all that is true, but there is something missing.Steve,
You set up the Vert Stabilizer winglet foam blank on top of the 8" block so that it sights -in line up- with the sightline of the long line of the front wing LE. Then you sand off the front of the 8" block so that the winglet LE and the wing LE meet. First though, the plans vert stabilizer winglet is reduced in size by cutting off the lower 4 to 6 inches. I did 5 I think. .
if you go back to the plans set up and tape out the top of the stab, the tip will be 4" (?) back from where you have yours now because you did away with the setback at the root. so to get a good flow on the LE you will change the angle so the stab is canted rearward more than stock. ill draw it
clear as mud right ?
i just think the winlet with the most set back will have the less drag
we will need to barow some wings to tell..lol marc?
do you think we could get marc to fly are wings on his plane ?
uni wanted
in Materials
i need 60 yards to finish my wings, any body have 20-60 yards for sale ?
