Edge 513 Posted August 3, 2009 Share Posted August 3, 2009 So..... Now that all of you are basking in the the afterglow of OSH 09....smoking your cigarettes and recovering from the exquisite enjoyment... ...reports Pleeeaze!!! Fav photo's encouraged. Quote Self confessed Wingnut. Now think about it...wouldn't you rather LIVE your life, rather than watch someone else's, on Reality T.V.? Get up off that couch!!! =) Progress; Fuselage on all three, with outside and inside nearly complete. 8 inch extended nose. FHC done. Canard finished. ERacer wings done with blended winglets. IO540 starting rebuild. Mounting Spar. Starting strake ribs. Link to comment Share on other sites More sharing options...
bferrell Posted August 3, 2009 Share Posted August 3, 2009 Here are a couple to wet your appetite. Esstelyn Cozy 540 Brett n44vf.com Quote --- Brett Ferrell Velocity XL/FG Cincinnati, OH http://www.velocityxl.com Link to comment Share on other sites More sharing options...
TMann Posted August 3, 2009 Share Posted August 3, 2009 Cool stuff. For those that have not done the wings chapter yet, you should check out James Redmon's tiedown points. Un the Berkut, there are two metal plates with a threaded bushing that are attached to the shear web prior to attaching the leading edge of the wing. Those are later opened up from the under side and used to screw in an eyebolt for your tiedown. A better effect than the eyebolt all the way through the wing. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Edge 513 Posted August 3, 2009 Author Share Posted August 3, 2009 Good pics, keep themcoming. Cant get any simpler than an eyebolt. But does that get your foam interior funky? How about stress on the skins? I would put a rubber sided pan washer against the 'glass. The tie downs that Marc has on his website are pretty cool. They drop down out of the spar ends if I recall right. Nice easy design. Polish that aluminum= Classy solution. Quote Self confessed Wingnut. Now think about it...wouldn't you rather LIVE your life, rather than watch someone else's, on Reality T.V.? Get up off that couch!!! =) Progress; Fuselage on all three, with outside and inside nearly complete. 8 inch extended nose. FHC done. Canard finished. ERacer wings done with blended winglets. IO540 starting rebuild. Mounting Spar. Starting strake ribs. Link to comment Share on other sites More sharing options...
mcjon77 Posted August 3, 2009 Share Posted August 3, 2009 I'm surprised no one has mentioned the "Xtra EZ". It is a modified cozy MKIV with an IO-540 velocity retracts and staggered seating. There are only 2 seats, as opposed to 3 in the stagger-ez. It won reserve grand champion ant OSH this year. Here are some pics. Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted August 3, 2009 Share Posted August 3, 2009 I'm surprised no one has mentioned the "Xtra EZ". It is a modified cozy MKIV with an IO-540 velocity retracts and staggered seating. There are only 2 seats, as opposed to 3 in the stagger-ez.There are only two seats because the rear seats (two of them, as in a standard COZY) have not been installed yet. They will be. Quote Marc J. ZeitlinBurnside Aerospacemarc_zeitlin@alum.mit.eduwww.cozybuilders.org copyright © 2023 Link to comment Share on other sites More sharing options...
Sydmoe Posted August 3, 2009 Share Posted August 3, 2009 Here are some pics in no particular order. Also, I sat in on Mark Z forum. Excellent job Mark! Quote Link to comment Share on other sites More sharing options...
Sydmoe Posted August 3, 2009 Share Posted August 3, 2009 few more....................... Quote Link to comment Share on other sites More sharing options...
Sydmoe Posted August 3, 2009 Share Posted August 3, 2009 ............................... Quote Link to comment Share on other sites More sharing options...
Sydmoe Posted August 3, 2009 Share Posted August 3, 2009 ................................ Quote Link to comment Share on other sites More sharing options...
Sydmoe Posted August 3, 2009 Share Posted August 3, 2009 .......................... Quote Link to comment Share on other sites More sharing options...
Sydmoe Posted August 3, 2009 Share Posted August 3, 2009 ............................ Quote Link to comment Share on other sites More sharing options...
ZUCZZ Posted August 4, 2009 Share Posted August 4, 2009 Thanks for sharing your photos! Quote I live in my own little world! but its OK, they know me here! Chris Van Hoof, Johannesburg, South Africa operate from FASY (Baragwanath) Cozy Mk IV, ZU-CZZ, IO-360 (200hp) 70x80 prop Link to comment Share on other sites More sharing options...
Sydmoe Posted August 4, 2009 Share Posted August 4, 2009 Btw, who is the guy sitting next to Burt Rutan? Quote Link to comment Share on other sites More sharing options...
