using peel ply
jpolenek
Differenct schools of thought on that.
It is considered sufficient to apply new glass over a surface that has been peel ply'd.
I usually wait as long as possible before removing the peel ply and then sand to get the best bond.
I read somewhere that when they built the Voyager they used peel ply and sand blasted prior to bonding.
After removing peel ply, is it necessary (or even desirable) to give the area a light sanding (followed by vacuuming, of course), or is the freshly peeled surface ready to make a good bond as is?
If you remove the peel ply within a short period of time (where "short" is a function of which epoxy you're using, and I have no idea what it is for any particular epoxy, but is measured in minutes to hours at the most) then the surface energy is high and in theory no further preparation is necessary.
It's almost always a good idea to sand as well as peel ply, however, for grandma.
The "Abaris" presentation on the cozybuilders web site under OSH presentations has some good info on the matter. Site seems to be down right now, but I assume it'll be up soon (ISP issues, I imagine).
I used acetone on polyvinyl esther resin, when fixing some swimming pool chairs.
But with epoxy is that good too?
Be really careful with the acetone (spelled don't use it!!!!)
Almost all of the lay-ups are over foam of some sort. Although we like to think that all of our lay-ups are impermeable to any outside influences, many are permeable and the small amount of air inclusions will wick any fluid to the foam which underlays.
Put a little acetone on some polystyrene and see the results. PVC etc may not react the same way, but if you dissolve the foam from under the layup you have squat!! You may never know it until the part fails, or a careful inspection shows what will seem like a delam.
Use clean water after sanding to get the sanding dust off. Peel ply is good. Jeff Russell suggested to always lightly sand the peelply (my guess is to activate the surface electrically. In the dragonfly world, we just wiped it off and bonded to it. I am not aware of any separations that were the result of that.
Don't use acetone....:mad:
I Canardly contain myself!
Rich :D
Unless I read the research wrong, which is possible as I skimmed it,
The testing was on the bond between glass stuff and aluminum. In our birds this type of bond happens, for example in the aileron and elevator control tubes, but unlike many bonds in our aircraft, that bond is over a very large surface area. Perhaps that is why we don't see the tremendous problem which those data may suggest in terms of weak bonding. I seem to remember, that there is a specific anodization process which greatly increases the epoxy-aluminum bonding strength (I'm sure that it is used in many places in the aerospace industry (the Yankee(Grumman) series were totally bonded aluminum. They had some problems with this in the beginning, but that seems to have been solved before they stopped production))
There are few other places in our birds, if any, where we depend on glass to aluminum bond as a primary bond. When we sandwich a layup between a piece of aluminum (or wood) (even though we bond the aluminum (or wood) to the understructure) and a piece that gets bolted to the sandwich, ( ie seatbelt attachment on the seat-back bulkhead) we actually don't depend much on the aluminum (or wood) bond to the substrate as we count on the aluminum (or wood) to serve as a big washer transferring the stresses to the overlying glass (the PB&J of the sandwich) and where it sheds it's load.
Is anybody aware of delaminations happening in the control surface/torque tube interface????
Rich :D
Unless I read the research wrong, which is possible as I skimmed it,.....The testing was on the bond between glass stuff and aluminum.
This one is from the FAA and is cited in the Abaris training that Marc pointed to and has more to do with peel ply than peel strength in glass to aluminum bonding.
http://www.tc.faa.gov/its/worldpac/techrpt/ar06-28.pdf
Regards,
Jason T Heath
MarkIV #1418
heathjasont@yahoo.com
Steve_Innova: said
The wing & canard foam is the only material especially susceptible to acetone.
Acetone is fine for working on the fuselage.
Acetone is for cleaning up tools after a layup. It does not get close to anything used in building a flying airplane in my shop.
After all the sanding and prep work who the heck has any grease on there fingers? build on STeve
Steve Harmon
Lovin Life in Idaho
Cozy IV Plans #1466 N232CZ
Working on Chapter 19,21
Do you have research to back up the anti-acetone claims w/regards to damaging Divincell foam & fiberglass layups?
Who cares? Our shops have a tendancy to get crowded quick.
I don't need to bait my own traps.
If it works for you, that's great but advice like that is going to cost another builder ...... guaranteed.
Regardless of superstitions, cleaning with acetone is an accepted technique for preparing / repairing fiberglass laminates on PVC foam (e.g. Divincell H45/H100). Here's the Exra 300's tech manual (lots of good info on composites there. Go to Chapt 51, pg 21: http://www.extraaircraft.com/Tech-Manuals/MM300SC/CH51.pdf
If builders can't distinguish between their Styrofoam wings and the PVC fuselage, strakes, and spar, then maybe they ought to select a hobby better suited to their lack of attention to detail.
That said, it's not bad advice at all, that once the wings are on (or exposed) don't use acetone around them.
