bigboy3178 Posted December 24, 2008 Share Posted December 24, 2008 Just a question i've been pondering, but , i was wondering if it would be possible to have a lifting canard and an engine in the front that pulls. What would be the aerodynamic problems and complexities with this? Again just wonderin!! thnxz!! Quote Link to comment Share on other sites More sharing options...
Drew Swenson Posted December 24, 2008 Share Posted December 24, 2008 Like a Defiant? http://www.utility-aircraft.com/gallery/rutan%20defi/delivery%20Defiant.htm Quote Link to comment Share on other sites More sharing options...
krwalsh Posted December 24, 2008 Share Posted December 24, 2008 Or the Voyager? Or the Quickie/Q2/Dragonfly? Quote Kevin R. Walsh & Michael Antares Cozy Mk-IV #413 N753CZ Link to comment Share on other sites More sharing options...
bigboy3178 Posted December 25, 2008 Author Share Posted December 25, 2008 no, not any tandem aircraft or a defiant, but one that has a tractor propeller and a main wing, yet still a canard like a velocity or ez Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted December 25, 2008 Share Posted December 25, 2008 A problem with this idea (there are probably others), is that the canard has to lift the weight of the engine and the front seat pilot(s) in order to rotate the airplane for takeoff. That'd be a rather large load to lift. Either the canard would have to be consideraby larger than the usual EZ/Cozy canard or takeoff roll would be unacceptably long. -Kent Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Lynn Erickson Posted December 25, 2008 Share Posted December 25, 2008 no, not any tandem aircraft or a defiant, but one that has a tractor propeller and a main wing, yet still a canard like a velocity or ezit does not matter where the power plant is located as long as the weight and balance is correct. does not matter where the power plant is located it is where the prop is located that makes it a pusher or puller Quote Evolultion Eze RG -a two place side by side-200 Knots on 200 HP. A&P / pilot for over 30 years Link to comment Share on other sites More sharing options...
bigboy3178 Posted December 25, 2008 Author Share Posted December 25, 2008 yes i considered that, i don't know much about structure and aerodynamics but what if you shifted the wing back and the pilot seat to reduce forward weight , i've also heard the prop would interfere with the stall advantages of a normal canard plane by locking it into a deep stall with the prop wash or something crazy like that!!! Quote Link to comment Share on other sites More sharing options...
bigboy3178 Posted December 25, 2008 Author Share Posted December 25, 2008 lynn, so your saying to maybe accomplish this you could move the engine back and connect it to the prop in the front. that would be kinda hard though! Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted December 25, 2008 Share Posted December 25, 2008 Just a question i've been pondering, but , i was wondering if it would be possible to have a lifting canard and an engine in the front that pulls. What would be the aerodynamic problems and complexities with this? Again just wonderin!! thnxz!! See NASA Technical Memorandum 85760 for an analysis of a front-engined canard aircraft, and the stability differences between it and the more common rear engine version. Especially see pages 42 onward. Quote Marc J. ZeitlinBurnside Aerospacemarc_zeitlin@alum.mit.eduwww.cozybuilders.org copyright © 2023 Link to comment Share on other sites More sharing options...
bigboy3178 Posted December 25, 2008 Author Share Posted December 25, 2008 can you post a link i can't find it Quote Link to comment Share on other sites More sharing options...
Vortal Posted December 25, 2008 Share Posted December 25, 2008 http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19840013471_1984013471.pdf Quote Link to comment Share on other sites More sharing options...
bigboy3178 Posted December 25, 2008 Author Share Posted December 25, 2008 thanks!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Vortal Posted December 25, 2008 Share Posted December 25, 2008 No problem Quote Link to comment Share on other sites More sharing options...
