flybeech21 Posted December 22, 2008 Share Posted December 22, 2008 I finished building my table this past weekend. I build the EAA chapter 1000 standard table. here is the link to the plans for the table. http://www.eaa1000.av.org/technicl/worktabl/tablefig.htm I built two of these tables with 3'X6' dimensions instead of the 2'X5' dimensions in the plans. I bolted the ends of the tables together to have a combined 3'X12' table. They are super sturdy. It took me a total of 8 hours to print of the plans, purchase material, transport material, build, and then clean up area. Materials cost was $160 and I still have enough material left to build a hot box. It will be nice to get started on an actual airplane. Kevin Harper Quote Link to comment Share on other sites More sharing options...
TMann Posted December 22, 2008 Share Posted December 22, 2008 Sounds great! You're on your way. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
rickh Posted December 22, 2008 Share Posted December 22, 2008 Nice An early Christmas present Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted December 23, 2008 Share Posted December 23, 2008 Great Start! Hit the ground running in the new year and you can have the tub sitting on 3 wheels by this time next year. ...Chrissi Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
steve Posted December 23, 2008 Share Posted December 23, 2008 gr8 job, i too just built table #2. i hope its the last Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
Big Steve Posted December 23, 2008 Share Posted December 23, 2008 Just remember at the end of your build your table will probably be taking up real-estate that you need so it will probably be cut up and thrown out so dont get to attached unless you have a really big shop to build in. When I cut up the table during my longeze build I knew I was getting close to being done. The table I am using now I can take the legs off of it and hang it against the wall I hope it has a couple more projects in it. Steve build on Quote Steve Harmon Lovin Life in Idaho Cozy IV Plans #1466 N232CZ http://websites.expercraft.com/bigsteve/ Working on Chapter 19,21 Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted December 23, 2008 Share Posted December 23, 2008 Our 42 x 144" table is going nowhere, we are too attached to it. Besides, the base is a 42 x 120" steel welding table, probably in the 400 lbs range, the whole thing is about 600 lbs, we move it with a fork lift But its nice, it stays put Whatever you do, you cannot have enough outlets, there are 3 duplex outlets down each side and one each end and we still run out now and then when the tools are plugged in: -shop vac -dremel -fein tool -drill(s) -goldenrod (heating element for foam cooler where we store resin) -small benchtop drill press -battery charger(s) for cordless drill(s) -charger for Dritz scissors -and many more.... ...Chrissi Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
Big Steve Posted December 24, 2008 Share Posted December 24, 2008 Chrissi said Our 42 x 144" table is going nowhere, we are too attached to it. Besides, the base is a 42 x 120" steel welding table, probably in the 400 lbs range, the whole thing is about 600 lbs, we move it with a fork lift I have a table like that on the other side of my shop. It is a welding table and it is very heavy. Most airplane builders use wood, Plywood, or chip boards for a table to build a plane I never thought about using metal. I think it would be to cold all the time. STeve build on Quote Steve Harmon Lovin Life in Idaho Cozy IV Plans #1466 N232CZ http://websites.expercraft.com/bigsteve/ Working on Chapter 19,21 Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted December 24, 2008 Share Posted December 24, 2008 Chrissi said I have a table like that on the other side of my shop. It is a welding table and it is very heavy. Most airplane builders use wood, Plywood, or chip boards for a table to build a plane I never thought about using metal. I think it would be to cold all the time. STeve build on Steve, the welding table was too low so we built a 10" high box on it all framed in lumber and plywood then clamped that to the steel table. Once in position we shimmed it level with wedges, clamped it in place and locked it with a lot of bondo blobs. It has all heald up over the years. The top is 3/4" MDF with 1/8" hard masonite bonded to it s a sacraficial surface. We covered the whole top with stretch wrap for the major layups so it did not get messed up. From time to time we'd run a belt sander over it to knock off any hardened epoxy drips or to clean up the surface so we could do a layout directly on it with a Sharpy fine line marker. So far we have not had the need to replace the 1/8" masonite. As much as I'd like an indoor parking space when the Cozy is gone, Randi feels we could not live without our bench, hopefully it will migrate to the hanger when we have one. Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
