BrianHalstrom Posted April 16, 2020 Posted April 16, 2020 I'm a 42 year old mechanical design student from Spokane, Washington. I'm in the process of getting my Mechanical Engineering Technology degree from Spokane Community College. As a project for my Technical Applications class I am designing an aircraft based on the Rutan Quickie. My plan is to build a 1/4 scale model for the class, as a proof of concept, with plans to build a full scale model at a later date. Quote
Kent Ashton Posted April 17, 2020 Posted April 17, 2020 Good luck. Have you ever seen flying model Quickies? I imagine there are some Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold
macleodm3 Posted April 17, 2020 Posted April 17, 2020 How will your design differ from the Quickie? Quote Andrew Anunson I work underground and I play in the sky... no problem
BrianHalstrom Posted April 17, 2020 Author Posted April 17, 2020 This is just a couple hour rough draft but something like this Quote
Kent Ashton Posted April 17, 2020 Posted April 17, 2020 (edited) Some thoughts from a non-engineer: That swoopiness looks very hard to build. You have added surface area and intersections that will increase surface area drag and interference drag, as well as extra structure that adds weight. A normal quickie has a vertical tail set well aft of the aerodynamic center that promotes yaw stability. I am guessing your large verticals could be forward of the aerodynamic center of the aircraft and might be destabilizing in yaw. The verticals are large; probably 3-4 times the size of a Quickie V.S and thus with 3-4 times the drag and weight. The small angled verticals are not as far aft as a normal Quickie vertical stabilizer and because they are set at an angle, they likely wouldn't be as effective in yaw. Nice ideas though. Burt knew what he was doing. I imagine if your features had made the Quickie lighter, faster or more stable, he might have used them. Yeah a flying model would be a good idea 🙂 You might be interested in the Commuter Craft design and crash. It sort of worked, then they changed the design without doing more model testing. Couple of posts here. Edited April 17, 2020 by Kent Ashton Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold
BrianHalstrom Posted April 17, 2020 Author Posted April 17, 2020 I appreciate your feedback Kent. I am an aspiring designer and I could use all the feedback I can get. I am planning on adding a rear stabilizer to the design but that was just the start of a rough draft. While I am starting with the Quickie, and I don't plan on renaming it the slowpoke for its slow speed handling, I am not actually looking to build a Quickie Clone. I want to add leading-edge slats, lengthen the cord of the wings, add flaperons, as well as a belly flap. I plan on incorporating other design mods to reduce the stall speed considerably. I agree this design will have increase drag from the surface area but I am hoping to make some of that back by utilizing the canard to wing tip connector as a Winglet, not to mention the Winglet itself (I just haven't trimmed it or actually shaped it until I actually run a aerodynamic study). I also agree that the extension bracket under the nose of fuselage could create interference drag but I haven't done an aerodynamic study of it yet. I disagree with there being an interference drag with the canard to wing connector. If designed correctly the connection will actually reduce drag by reducing wingtip vortices. As the wingtip vortex rotates around from below the wing it will strikes the cambered surface of the canard to wind connector, thereby generating a force that angles inward and slightly forward. The winglet converts some of the otherwise-wasted energy in the wingtip vortex to an apparent thrust. Either way I like the feedback because it forces me to reconsider design choices. I have never even attempted to design an aircraft before, except maybe in my imagination. Thanks Quote
Kent Ashton Posted April 17, 2020 Posted April 17, 2020 Brian, it seems like you are just adding features just because they are in the design books. For example, leading edge slats and flaperons are put on airplanes to allow them to land slower but they are complex and slats are draggy. Both add weight for the mechanism. The planes that use them are intended to fly slow at high AOA and land in very short airstrips. Is that your mission, to deliver bibles in the Congo? 🙂 A good plane to study is Mike Arnold’s amazing AR-5. https://youtu.be/rxvoDbZpoY8 Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold
BrianHalstrom Posted April 18, 2020 Author Posted April 18, 2020 (edited) Kent- Like I said, I am not building a Quickie replica. I am building my aircraft using design similarities to the Quickie. I am building something I can fly off of private grass strips that are extremely short. There are campgrounds in my area that can be reached by aircraft at high altitude but the approach is through a canyon and the approach is best done slow. You are exactly right that features add complexity but that is besides the point. If done correctly the weight gain will be minimal and with modern construction the weight gain should be offset through better materials and internal design. You are talking about a 1970's design vs a 2020's design. In the last 40 years materials have reach a price and availability that Burt Rutan could only dream about in the 70's. I would like to state unequivocally that I am no Burt Rutan. However, I am using every trick I know to reduce stall speed. The video you linked to is literally titled "Why it goes so Fast". The video I hope somebody would make about my plane would be titled "Why it goes so Slow". While I study anything I can get my hands on, I am more interested in taking this design slower not faster. If I can do both that will be great, but I have the opportunity to fly in mountain ranges that are routinely at the 9,000 ft range. There are 15 mountains in Washington 9,000 ft or higher, there are 100 over 8,000 ft in elevation. In Idaho there are 15 mountains above 11,000 feet and 40 above 9,000 feet. Large portions of idaho are above 8,000 feet so they don't really list them. The highest peak in North Carolina is around 6700 which describes most of the valleys and hills I grew up around. If you are interested in what I am talking about I suggest any of the video's from the "Flying Cowboys". I have seen videos of Trent Palmer, Steve Henry, Mike Patey, Mark Patey, and Scott Palmer that get me excited. They (specifically the Patey twins) do build fast aircraft, but what I am most interested in is there slow ones. Like I said I love feedback but I am starting to think that because you want to go faster, so should I. Your dig about delivering bibles in the Congo seemed especially juvenile. There are so many reason to go slow I don't want to list them. I posted on this forum to find helpful suggestions about my design, not what others would want it to be. I would love input that is more geared to helping my goals, not hindering them. Once again thanks for your input Edited April 18, 2020 by BrianHalstrom Quote
BrianHalstrom Posted April 19, 2020 Author Posted April 19, 2020 Kent- The "Why it goes Fast" is an excellent video. I'll definitely use its resources for my build. Quote
Marc Zeitlin Posted April 19, 2020 Posted April 19, 2020 On 4/17/2020 at 2:37 PM, BrianHalstrom said: I am planning on adding a rear stabilizer to the design ... Are you talking about a horizontal stabilizer or a vertical stabilizer? On 4/17/2020 at 2:37 PM, BrianHalstrom said: I agree this design will have increase drag from the surface area but I am hoping to make some of that back by utilizing the canard to wing tip connector as a Winglet, not to mention the Winglet itself (I just haven't trimmed it or actually shaped it until I actually run a aerodynamic study). Vertical surfaces forward of the CG (as any vertical surface attached to the canard will be) are destabilizing in yaw, and would require substantially larger tail vertical surfaces to offset. The vertical (or at least partially vertical) surfaces attached to the wing tips are not far aft of the CG, and will have only a very weak stabilizing effect, particularly due to their small size and cant angle. While interesting looking, this configuration, even with a vertical tail at the aft end of the fuselage, would have poor directional stability at best, and be directionally unstable at worst. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2025
BrianHalstrom Posted April 19, 2020 Author Posted April 19, 2020 (edited) 55 minutes ago, Marc Zeitlin said: Are you talking about a horizontal stabilizer or a vertical stabilizer? Vertical Stabilizer with ruder 55 minutes ago, Marc Zeitlin said: Vertical surfaces forward of the CG (as any vertical surface attached to the canard will be) are destabilizing in yaw, and would require substantially larger tail vertical surfaces to offset. The vertical (or at least partially vertical) surfaces attached to the wing tips are not far aft of the CG, and will have only a very weak stabilizing effect, particularly due to their small size and cant angle. While interesting looking, this configuration, even with a vertical tail at the aft end of the fuselage, would have poor directional stability at best, and be directionally unstable at worst. So what you are saying is to move the fuselage forward (wing backwards) to shift the CG forward to resolve that right? Edited April 19, 2020 by BrianHalstrom Quote
Kent Ashton Posted April 19, 2020 Posted April 19, 2020 Ah, a real engineer (Marc)! I defer. Brian, I suggest the way to look at this project is as if you're designing a new Star Wars X-wing fighter. Professor Darrol Stinton takes 600+ pages in "Design of the Aeroplane" to answer the questions you are asking here and even the esteemed Zeitlin is unlikely to make it flyable in two pages of internet chat. Just draw it as you would draw a Star Wars "Box Wing". Add some guns to the verticals. 🙂 Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold
Marc Zeitlin Posted April 20, 2020 Posted April 20, 2020 23 hours ago, BrianHalstrom said: So what you are saying is to move the fuselage forward (wing backwards) to shift the CG forward to resolve that right? No, that's not at all what I'm saying. You have a horizontal surface relationship to CG that needs to be maintained (CG forward of Aerodynamic Center) in order to have static longitudinal stability. However it can't be TOO far forward, or else the airplane becomes unable to rotate for takeoff, and TOO stable in pitch to the point that you lose maneuverability. You also need to have an equivalent vertical surface relationship to the CG in order to have lateral stability. Read up on aircraft stability requirements and calculations. Moving CG forward might address the lateral stability issue, but completely screw up the ability of the aircraft to get off the ground and be maneuverable once it does. Everything is a balance, but having as much vertical area at or forward of the CG position (about where the pilot is going to be in one of these planes) is going to make the plane want to fly sideways or backwards, or at least be happy to do so if it happens to be perturbed in that direction. I suggest googling "aircraft design book" and purchasing a number of the ones that come up - Raymer's is good, as is Roskam, just for starters. Also "Perkins and Hage" for "Stability and Control". You cannot design anything other than a standard looking aircraft (think C-172 or Piper Warrior) using "that looks about right" techniques. Particularly with canards and/or tandem wing aircraft. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2025
BrianHalstrom Posted April 20, 2020 Author Posted April 20, 2020 1 hour ago, Marc Zeitlin said: No, that's not at all what I'm saying. Sorry, I was trying to be a little funny and also just simplifying it way too much. I understand if it was simple and easy everyone would do it. 2 hours ago, Marc Zeitlin said: You have a horizontal surface relationship to CG that needs to be maintained (CG forward of Aerodynamic Center) in order to have static longitudinal stability. However it can't be TOO far forward, or else the airplane becomes unable to rotate for takeoff, and TOO stable in pitch to the point that you lose maneuverability. You also need to have an equivalent vertical surface relationship to the CG in order to have lateral stability. Read up on aircraft stability requirements and calculations. Moving CG forward might address the lateral stability issue, but completely screw up the ability of the aircraft to get off the ground and be maneuverable once it does. Everything is a balance, but having as much vertical area at or forward of the CG position (about where the pilot is going to be in one of these planes) is going to make the plane want to fly sideways or backwards, or at least be happy to do so if it happens to be perturbed in that direction. I appreciate this kind of input. It's the questions I don't know to ask that I can't do any research on. 2 hours ago, Marc Zeitlin said: I suggest googling "aircraft design book" and purchasing a number of the ones that come up - Raymer's is good, as is Roskam, just for starters. Also "Perkins and Hage" for "Stability and Control". You cannot design anything other than a standard looking aircraft (think C-172 or Piper Warrior) using "that looks about right" techniques. Particularly with canards and/or tandem wing aircraft. Speaking of research I appreciate the source material. I'll definitely be doing some more reading, so it's good to know what I should be reading. 🙂 Quote
Jon Matcho Posted April 24, 2020 Posted April 24, 2020 On 4/17/2020 at 2:58 PM, BrianHalstrom said: This is just a couple hour rough draft but something like this... Your drawing is similar to the Ligeti Stratos, which did fly. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV
