MarkMS Posted August 21, 2016 Share Posted August 21, 2016 I'm new to the forum and have always been interested in the Vari and Long EZ. Right now I'm more interested in the VariEze since it doesn't require a high HP Lycoming, but still seems like a fast efficient XC plane. I was wondering where I would be able to find plans for the VariEze? Do builders usually go with an O-200 or VW engine? Thanks -Mark Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted August 21, 2016 Share Posted August 21, 2016 Variezes are fine if you are not such a big guy but i could not fit in one. It was Burt's first attempt at a composite airplane and i think most people will say the Long-ez is just a better design, although there are fellows who fly the heck out their Variezes. I have 46 hours on my Long-ez now. Never owned a Vari. Varis have a history of wing attachment corrosion that the Longs don't have--better way of mounting the wings in the Long. Most people put O-320s on the Long-ezs these days. It's one of the most common engine, parts are cheap. I don't think the engine cost differential is very significant. A nice Long-ez fuselage just sold on ebay for $2125. It was on the gear, nice canopy and strakes. It probably had $10K worth of parts and labor in it. Buy a project. The market is depressed and there are some great deals out there. There's where you can save some big bucks! Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Kent Ashton Posted August 21, 2016 Share Posted August 21, 2016 This one http://www.ebay.com/itm/Long-EZ-Experimental-Aircraft-Airplane-Project-Canopy-Fuselage-Landing-Gear-/201644759557?forcerrptr=true&hash=item2ef2f6da05:g:bW4AAOSwHoFXrhZp&item=201644759557 Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
MarkMS Posted August 22, 2016 Author Share Posted August 22, 2016 Thanks for the advice. Hoping for a deal like the one you posted. I think I would still need the plans tho. -Mark Quote Link to comment Share on other sites More sharing options...
MarkMS Posted September 15, 2016 Author Share Posted September 15, 2016 I found a deal on a varieze not to far from where I live, everything is done except that it doesn't have an engine or instruments. I did a quick search for an o-200B for sale and I can find the A models all over the place, but no B's does the vari require that it have the B version. Or doe the B just mean that it doesn't have the starter. I think in the future I would put the lightweight C&B starter on it. I guess what I'm asking is could I buy an O-200A and take the starter off? Wanted to get your thoughts, what about an O-235? It's a bit heavy but could it work to haul two people around and a duffel bag without being at gross? Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted September 16, 2016 Share Posted September 16, 2016 (edited) See this. http://www.bowersflybaby.com/tech/o-200a.b.pdf Suggest you take some pics and the builders log to your FAA FSDO and see if it meets the "major portion" rule and you could get the Repairman's certificate for it. Alternatively, a DAR could probably tell you. Best to have that confirmed before laying down cash. Edited September 16, 2016 by Kent Ashton Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted September 16, 2016 Share Posted September 16, 2016 I found a deal on a varieze not to far from where I live, everything is done except that it doesn't have an engine or instruments. I did a quick search for an o-200B for sale and I can find the A models all over the place, but no B's does the vari require that it have the B version. Or doe the B just mean that it doesn't have the starter. I think in the future I would put the lightweight C&B starter on it. I guess what I'm asking is could I buy an O-200A and take the starter off? Wanted to get your thoughts, what about an O-235? It's a bit heavy but could it work to haul two people around and a duffel bag without being at gross? You are aware of the wing fitting corrosion issue on Variezes, yes? And you've had a Pre-Buy examination by a competent and canard knowledgeable examiner, yes? There are numerous VE's flying with all types of O-200's, O-235's, and even a few O-320's. Most of them are flying well over the MGW from the POH. That in no way is an endorsement of doing so, merely a statement of fact. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
MarkMS Posted September 16, 2016 Author Share Posted September 16, 2016 I'm going to go look at it on Saturday. The gentleman that is selling has owned 5 canard aircrafts. He bought it for a winter project and says the build quality is excellent. I'm aware about the corrosion issue that will be the first thing I check. I'll be sure to get a pre buy inspection before deciding to purchase. I appreciate everyone's help on this. Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted September 16, 2016 Share Posted September 16, 2016 I'm going to go look at it on Saturday. The gentleman that is selling has owned 5 canard aircrafts. He bought it for a winter project and says the build quality is excellent. I'm aware about the corrosion issue that will be the first thing I check. Except that you CAN'T check the wing attach fittings for corrosion without taking the metal fittings off of the wing/center spar, in which case you're into it for 40-80 hours of work to remove/replace them. That's the problem here - the stuff you can see isn't the stuff that will kill you if it corrodes - it's the stuff you can't see. So his sayso on the quality of the build might be useful for everything else, but ANYONE's opinion on the state of the wing attach fittings is meaningless. I'll be sure to get a pre buy inspection before deciding to purchase. I appreciate everyone's help on this. Good. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
borrisl Posted June 4, 2018 Share Posted June 4, 2018 I went with a C-85 stroker from http://www.aerotecengines.ca/. 105 hp in a light engine. Total weight of my Varieze is 610lbs. I had the original build manual but no templates. So I found some pdf scans and scaled them to size. Quote Link to comment Share on other sites More sharing options...
Jack Newberry Posted November 2, 2021 Share Posted November 2, 2021 I have a low time varieze ready to fly but the air brake cables are broken. does anyone have a diagram how they are routed and attached? Any help would be greatly appreciated. Jack Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted November 3, 2021 Share Posted November 3, 2021 21 hours ago, Jack Newberry said: I have a low time varieze ready to fly but the air brake cables are broken. does anyone have a diagram how they are routed and attached? Any help would be greatly appreciated. I'd guess they are similar to those in the Long-EZ and the Long-EZ plans are in the Open-EZ topic on this website. Search for Open-Ez Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
