Wankel Super-Tec (diesel ?)
JCPJCP
Has anybody seen this engine ?
Poking about for new "Wankel" patents, found these two from Wankel Super-Tec.
Then searching further using "Wankel Super-Tec", found the photo on a German language newspaper web page.
But nothing new on Wankel Super-Tec's own web page.
Obvious it is a turbocharged two rotor design.
What is the red object, a diesel injection pump ?
Appears to be a double ended ignition coil on top of the engine.
Perhaps a drone engine ?
JCP
us007234374-001.tif
us007264454-001.tif
Photo at top of attached PDF shows both spark plugs and diesel injectors.
Engine needs spark plugs to start due to maximum compression of a Wankel.
Once hot and running, it may run as a pure diesel.
Assuming a two stage compression/expansion due to the turbo, overall compression could well be over 20:1 once the turbo spins up.
Note no intercooler, hence the hot boosted turbo output raises temperature at TDC high enough for diesel ignition.
Are they trading off the cooler exhaust temperatures of a diesel for higher inlet air temperatures to the Wankel.
Also note, rotors turn in the opposite direction from a Mazda.
Article talks about "very light" aircraft, hence engine may be only 100 HP or less.
Date on article is May 2008.......
BIEMCB_LR_080524.pdf
Call me crazy but as far as I know (or knew) diesel is a compression ignition fuel and won't ignite via a spark. The closest reference I could find on the subject was this, where they run a gas engine in "diesel" mode to increase efficiency...once it's running. http://www.edmunds.com/insideline/do/Features/articleId=123274
Maybe they know something the rest of us don't??? Anyone else heard of spark igniting diesel?
**edited cause I don't know how to spell**
My diesel tractor has glow plugs - maybe that's what was meant.
I suppose it's possible, hopefully someone that speak german can confirm or deny that though. I believe all (at least most) high-compression diesel engines have glowplugs to help with cold weather starting. I probably shouldn't say "all" though, if you know otherwise please feel free to correct me.:rolleyes:
They indeed use spark plugs since the compression isn't high enough for self-ignition of the diesel. They claim the engine can be adapted to other fuels, like gasoline, alcohol, vegetable oil, kerosene etc. They will build a few prototypes, further development and production needs to be financed by investors.
There is an American investor who financed part of the development and wants to use the engine for generators for military purposes. They also mention converting the engine for light aircraft use, but apparently that's not their main priority (ultralight aircraft in Europe are comparable to LSA aircraft in the US, so I assume that would be a 100-150HP version).
i had my 57 t-bird filled from dead empty to about 1/3 full (we ran out of gas in a farm land) and it started, and ran, as we got to the interstate it seamed as if it were running like a diesel (low power and sound) so i asked are grate host and he said that he was a farmer and always got gas from the diesel pump. so we filled it up the rest of the way with 92 and drove 100 miles home .
Steve M. Parkins
My understanding is not that a 100 LL engine won't burn jet (diesel) and that the problem with mixing the fuels with a mistake at the pump is not that the engine will just stop, but is the fact that there is more energy available from the jet and at high power will destroy the engine because of this increased energy.
But then I could be wrong, this is an election year.
I Canardly contain myself!
Rich :D
Yes, exhaust is pointed aft for a pusher!
Poor photo on second article shows injectors replacing leading sparkplugs.
Believe it runs as a pure diesel, once the turbo spins up to about 2:1 pressure ratio.
At that point, the inlet air temperature to Wankel would be about 300F and the combined compression ratio in the range of a normal diesel.
Perhaps they are trading the high inlet air temperatue against the lower exhaust temperature of a diesel (Zoche claims 700F lower).
The two stage compression (Turbo then Wankel) and two stage expansion (Wankel then Turbo) may yield efficiencies approaching a true diesel.
Something to watch, but like most engine guys they are short of money and afraid of aviation related lawsuits.
JCP
One simply has to acheive the temps for ignition. A intake heater, glow plug, blower/turbo, then go boom. High compression rotors? I would think Jet-A as a fuel source...........then metering the fuel correctly. (Hey, I could toss
my ecm and not sigh if the alternator puked!):P
