Test Ez project Chapter 7
Jeff
I dont mean to worry you but do you have F22 around the wrong way ? Shouldn't the doubler be on the back ? :confused:
G'day
Good eye. I wished I would have seen that about four weeks ago....
Yes, I have a doubler on both sides of F22 now. I will trim the corners of the forward one down for the canard. :o
I sniffed a few to many fumes that day and mis-read (Doh!) the plans. Mid-week after the cure I noticed the problem (Doh doh doh...). :confused:
I made another doubler per earlier chapter; glassed and installed on the back (correct side) of F22. I then restrapped with BID. I wrapped the mess with plastic wrap, epoxy, and Flox. I then used clamps to install the second F22 doubler on the correct side. My bulkhead now has two doublers (tripler). As I said, I will need to trim the forward doubler to install the canard later. Microsoft calls this a service pack for an undocumented feature.:o
I will have a weight penalty in the nose area. I will have to start drinking diet beer.;)
Thanks for your comments and good eye. I didn't get the feedback for several days and the whole thing had cured. I would have damanged F22 in the removal and re-install process.
Jeff
:( ..... did the same thing myself. Got distracted and put it on backwards. Even with the Fein, there is no graceful way to remove it. I ended up using my skill saw with a carbide blade to get a clean edge again and made a new bulkhead. It was worth the effort.
What is with the foam spacer between the fuse bottom and the nose gear cover? I do not recall that in the plans?
That is a mod to allow extra room for gear doors to close all the way. My advisor told me to not add more than 1 inch to the bottom because of the nose gear crank clearance. He said it was easier to correct now than wait until I discovered that when the nose wheel was retracted the doors didn't have room to close. I added some spare .999 inch foam.
I hope this helps.
Jeff :D
I hope this helps.
Jeff :D
Understood. Except for how someone can measure and cuts foam to .001 precision! :)
G'day
I use a simple seven step process that I have perfected.
Step 1 Measure with micrometer.
Step 2 Mark with a fine calk.
Step 3 Cut with a sharp axe.
Step 4 Beat or Sand to fit.
Step 5 Flox the gaps.
Step 6 Paint to match.
(Optional) Step 7(a) Determine it is backwards. Yell "F**K ME TO TEARS!"
Step 7 Drink a Beer. Think what to do next.
Hope this helps. Feel free to use the system anytime.
Jeff
I can now say I'm an experienced builder so I'll give some good advice....
Step 5 in some cases micro can be used as a lighter alternative to flox. You can also use a precision Sharpie pen for step 2 and a precision hand saw for step 3.
There are no mistakes in composite building, only delays. :D
