No Butcher or Wax Paper, Now what?
Cozy1200
Help,
I've been using plastic to cover my workpieces before weighing them down. The problem is small air pockets are trapping under the plastic and making marks on the part.
I thought, sure I go buy some butcher paper.
WRONG.
Butchers don't use butcher paper here, they put the meat in plastic. Australians call plain newsprint butcher paper, but it doesn't have any coating.
Then I thought, I'll revert back to wax paper.
Wrong again.
I can't track down Wax paper in large enough rolls to make it cost feasable.
SUGGESTIONS???
Brace for impact...
STAY AWAY FROM WAX PAPER, please?
There is stuff on a roll that is white paper and it is plasticized on one side, today that is consdered to be butcher papaer because it is a safe barrier.
They are all gong to trap air. You work the air out as you go along, sort of like applying a huge decal. Work from one end to the other or from the center out. Also make sure whatever you are putting down is not being stretched otherwise it will pucker later.
Regards, Chrissi
CG Products
www.CozyGirrrl.com
Cozy Mk-IV RG 13B Turbo
Yes and no, for some that would be the beginnings of a whole new set of problems... for some.
...Chrissi
I can see the headlines now..."Man found dead in garage with plastic bag taped to his head and strange plastic tubing hooked up to suction pump. Name being held pending toxicology report".:D
Best Regards,
John D. Wages
N694CZ (reserved)
http://www.maddyhome.com/canardpages/pages/johnwages/default.htm
Uh John, yur not right :D
Wrong kind of glue anyway, Chrissi
CG Products
www.CozyGirrrl.com
Whew .... that would suck.
