jany77 Posted August 26, 2006 Share Posted August 26, 2006 hi guys i have guestion about laying the fuselage sides ,the manual say lay on flat table but in next chapter is drawing which shows front and back side narrower than rest of bulkheads so im trying find out what to do with this i bought fuselage with couple of parts from guy next door hanger for free ill use just some parts but want make new fuselage and im not sure is after cure can the sides be bended to proper shape thanks for responses Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted August 26, 2006 Share Posted August 26, 2006 hi guys i have guestion about laying the fuselage sides ,the manual say lay on flat table but in next chapter is drawing which shows front and back side narrower than rest of bulkheads so im trying find out what to do with this i bought fuselage with couple of parts from guy next door hanger for free ill use just some parts but want make new fuselage and im not sure is after cure can the sides be bended to proper shape thanks for responses Why don't you tell us something about yourself and what kind of airplane you're building (there are several canard versions)? If you're building a Long-EZ, the plans call for a simple jig on the work table to give curvature to the sides. If you don't have Long-EZ plans, they're available on a "TERF" CD. Search this site and the site below for TERF or "open EZ". http://canardaviationforum.dmt.net/ Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
jany77 Posted August 26, 2006 Author Share Posted August 26, 2006 hi guys im building long ez from original set of plans ,i was reading the plans months and did not find any simple jig for curvate,if somebody point it where exactly it is in plans ill appreciate it thank you Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted August 27, 2006 Share Posted August 27, 2006 Check out chapter 5 -- anything in there abound the side jigs? I'm out of town, and away from my Long-EZ plans, but chap. 5 should be the one with the jigs. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
jany77 Posted August 27, 2006 Author Share Posted August 27, 2006 thanks but i was going over ch 4,5,6,7 thousands of time and there is none about jigs maybe im dumb but dont see any Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted August 27, 2006 Share Posted August 27, 2006 Could be the case. I'll check when I get back from vacation on Tuesday night. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Kent Ashton Posted August 27, 2006 Share Posted August 27, 2006 I'm a Cozy builder but I looked at my Long-EZ plans and it looks like you're right--I didn't see any jig shown for giving curvature to the sides. But . . . the cozys use a simple jig, two long pieces of particle board cut to the curvature of the sides and bonded to the work table. The foam sides get weighted into the shape of the curve and temporarily hot-glued in place, then the inside glass and longerons are installed. I'm sure you can find some pictures in the builder pages at http://www.maddyhome.com/canardpages/main It'd be easy to take width measurements off the EZ bulkheads and make a similar jig to give shape to the sides. You might want to add a couple inches to the back seat width while you're at it. (Nat added a lot of tips and info in the Mark IV plans.) Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
jany77 Posted August 27, 2006 Author Share Posted August 27, 2006 thank you i figured it out after bulkheads are don ill make measurement and then ill find out how big curvate i need Quote Link to comment Share on other sites More sharing options...
rpellicciotti Posted August 28, 2006 Share Posted August 28, 2006 For the Long-EZ: After laying out the dimensions and sanding the depressions in the side of the fuselage, you glass the inside of the fuselage sides only (chapter 5, steps 1 & 2). With the foam sides glassed on the inside only, you can easily bend them enough to mate up with the bulkheads. Once the sides and bulkheads are bonded together (chapter 6 step 1), you carve the outside of the fuselage to shape and then glass it (chapter 6 steps 2 and 3). The Cozy, E-Racer and other side by side designs use a jig to build in the curvature of the fuselage as it is a more severe curve and some "pre bending" of the foam is desired before glassing the inside. This technique could be used for the Long-EZ but is not required. Quote Rick Pellicciotti Belle Aire Aviation, Inc. http://www.belleaireaviation.com Link to comment Share on other sites More sharing options...
jany77 Posted August 29, 2006 Author Share Posted August 29, 2006 thank you ,that makes life easyier,not spend some extra hours to build jig Quote Link to comment Share on other sites More sharing options...
