minimum required tools
dust
Evan,
You'll need that laser level too, or at least loan of one for a day. It's the VERY best way to install the spar. You'll use the smart level EVERY day for the first few months.
Don't you just hate it when you ask a store assistant for help and the best they can do is help you look on the shelves with less understanding than you of what they're looking for. Its rare these days to find someone who actually KNOWS the stock and what it's for.
Speaking of required tools you can get at Home Depot....
I highly recommend the $29 Black & Decker dremel knock-off. It has more power than the original dremel and can't be beat for the price. All the original dremel parts fit both tools. Also, while you're there, pick up some clear 4ml plastic for "poor man's vacuum bagging".
John
Mike,
How does the smart level stay attached to the cheap level if something like velcro is not used? I found them on the web for around $90 for the 7" module. Also saw this posting the other day(the rest has been copied and pasted).....
Frank Armbruster out of Colorado has the original Wedge Innovations
levels cheaper than current market.
SmartLevel modules - $40
2 ft. extension - $20
4 ft. extensions are available but I didn't need one.
Shipping is quoted as $5 even to the East Coast.
Nice guy to deal with.
Oh, these are still in the box, unused, needs a new 9 volt battery,
complete with the instruction booklets.
Seems he used to be a dealer before Wedge got bought out.
His cell phone is 720-363-0303.
And , yes, he does like airplane builders. Only asks that you let him
know when the first flight occurs.
Richard Crapse
Textron LCM Team
Andrew Anunson
well, rarely do you not use it in the level position, it just sits there happy as can be, with a 0.0 smile on it's face.
I have the 2 foot wedge and dave has the 4 footer that the module doesn't come out of, the level has to be re zeroed when the module is removed or reinstalled. The only time I can remember using the module not in the frame was on canard jig leveling and canard incidence setting. It was handy then
i can be reached at
  • 2 weeks later...
OK, Now I'm planning on the firewall backward items and I figure I need some tools.
Ifin I go with an aircraft engine, as all the regulars know I will, is there anything under the cowl that might be metric?
I figure ifin I buy all tools known to mechanics in inch and just "many" tools known to mechanics in metric I should be ok
What say youns(pronounced Uuns)
i can be reached at
  • 2 months later...
YEP, in my humble opinion. In order to overt exotherm, you mix many small batches, easy and fast with a pump. Two reasons epoxy doesn't cure right, bad ratio or incomplete mixing, we have not had a single bad mix, using pump AND large second hand on clock to insure at least 1 min through mixing.
i can be reached at
Hey clifford answer this one would you on the brand, the pump has operated flawlessly, even allows for partial pumps.
Every few years we check the ratio and it is always right on the money. It has required a through cleaning twice in 5 years with weekly use.
Do keep it heated at all times, stops crystallation.
i can be reached at
This seems to be a really personal issue. I've heard a lot of balance people rave about the accuracy. I don't think they've used a pump. Me - I'm a pumper, and to me that pump was the best investment of all the tools I bought for the project.
Mike's right about the small batches - much better to get a good wet out. Also, on a big layup where you "get a bit busy" the time it takes to refill the cup and be back wetting out the cloth becomes critical. The pump is FAST. I think Mike's going overboard with a 60 second mix. I've cut it down to maybe 20 seconds on less critical stuff and never had a problem.
All this checking the ratio doesnt make sense to me - the pump has two cylinders of different sizes. If it pumps, and you dont see air, then it pretty much HAS to be right. When there's something wrong - like a blocked inlet or level too low and air in the system, then you spot it immediately.
>overboard?? twice in 5 years?
OK, overboard was a bit strong.
>and always 60 to 75 seconds, of course I don't mix any fast hardener >in, just the sloooooooooooow stuff
I know it says "slow" on the can, but that refers to the reaction time. It has nothing to do with how fast (or slow) you're supposed to mix it :D
  • 2 months later...
I have a great band saw for my woodworking hobby, i regularly make my own veneer up to 10" thick hard maple cut to 5/32 or less sheets.
I would never use this machine on fiberglass, it would make me feel like i was tearing it up, fiberglass is one hell of an abrasive. when using a band saw blade it immediatly takes the set off of the teeth and makes that blade worthless for wood or metal.
My advice, if you buy one, buy a cheep import and abuse it, i mean use it with reckless abandon.
Enjoy the build
i can be reached at
I agree. Fiberglass is hell on cutting tools. When I see what it does to a blade it is a great reminder that the big white roll of fabric is GLASS and not cloth. No wonder it kills metal.....and it is a great way to remember to wear goggles, mask and longsleeve (ok, in Houston more use of barrier cream....gotta love that stuff). FWIW.
All the best,
Chris
Christopher Barber
www.LoneStarVelocity.com
Live with Passion...
  • 6 months later...
