My Quickie Q2 Project
  • Please log in to reply
13 replies to this topic
#1 Jon Matcho
Jon Matcho
    Canard Zone Developer
  • Verified Members
  • 2,454 posts
  • Jon Matcho
  • Martinsville, NJ
Posted 15 October 2014 - 09:04 AM
The Quickie Q2 is a side-by-side canard-type aircraft.  Major differences from the other Rutan EZs are:
  • Tractor (vs. pusher) propeller
  • The Quickie canard provides the majority of the lift
  • The nose gear does not retract in the tri-gear configuration
  • A tail-dragger configuration is also an option
  • VariEze-like performance
I came upon an opportunity to acquire an unstarted Q2 kit that I could not resist.
I will explain my plans for all of this (my Cozy, the Tri-Q, and this Q2 kit) in the near future as I'm still working through some of it.  Until then, here's a picture of me "flying" the Q2.
#2 James Bailey
James Bailey
    Member
  • Verified Members
  • 20 posts
  • James Bailey
  • Murfreesboro, TN USA
Posted 15 October 2014 - 09:09 AM
Why cool Jon,
I can't wait to see your build progress and when you get to your first actual in the pattern flight :-)
  • Jon Matcho likes this
#3 Jon Matcho
Jon Matcho
  • Verified Members
  • 2,454 posts
  • Jon Matcho
  • Martinsville, NJ
Posted 15 October 2014 - 10:06 AM
Why cool Jon,
I assume you meant "way", but at first I saw that as "Why Jon, why?"   :)
Thanks, I aim to have my other plane flying next year.  More to come...
#4 AVI
AVI
    Member
  • Members
  • PipPipPip
  • 48 posts
  • Iceman
  • Banff AB
Posted 15 October 2014 - 07:52 PM
What? Test flight with no parachute?
#5 James Bailey
James Bailey
    Member
  • Verified Members
  • 20 posts
  • James Bailey
Posted 15 October 2014 - 09:27 PM
Yep..typo...should have been way cool
Looks like it was a factory new package,..what a find
#6 Jon Matcho
Jon Matcho
  • Verified Members
  • 2,454 posts
  • Jon Matcho
  • Martinsville, NJ
Posted 16 October 2014 - 05:45 PM
Yes, it does look like a factory crate, but credit goes to the seller on this deal.  He and I were able to come to an arrangement that he would bead-blast all the metal parts, make a crate, and drop off at a freight company for delivery.  After weeks of back and forth with emails and pictures, I have a like-new kit (in New Jersey) without ever having gone to where it was (Texas).
Attached is a pic showing how you can turn rather old metal into beautiful like-new metal parts.
#7 James Bailey
James Bailey
    Member
  • Verified Members
  • 20 posts
  • James Bailey
Posted 16 October 2014 - 05:48 PM
Major difference between the old hardware look and the cleaned up hardware...did he paint it with something after bead blasting
#8 Jon Matcho
Jon Matcho
  • Verified Members
  • 2,454 posts
  • Jon Matcho
  • Martinsville, NJ
Posted 16 October 2014 - 06:05 PM
He just coated it with an oil for the short term.  My first order of business with the aluminum is to clean and prep for a chromate conversion coating that a friend is helping me with.
Not sure what I'm going to do with the steel yet though.
I'm sensing a recommendation... please  :)
#9 quickieaircraft
quickieaircraft
    New Member
  • Members
  • Pip
  • 1 posts
  • IF
  • Baltimore
Posted 17 October 2014 - 03:21 PM
Those must be two different parts.  The hole is bigger on the shiny scratched one.
I have heard good and bad things about shot peening (bead blasting).  It creates a surface layer than has compressive stresses and resists crack propagation (good), but I seem to recall that bead blasting can also hide cracks in aluminum because it can "smoosh" the crack closed (bad).
Some more info in http://www.metalimpr...mplete Book.pdf
-Emron
#10 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 836 posts
  • Kent Ashton
  • Concord, NC
Posted 17 October 2014 - 03:31 PM
There is a difference between shot peening and bead blasting. BB is more of a cleaning process. SP changes the surface of the alloy.
#11 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 836 posts
  • Kent Ashton
  • Concord, NC
Posted 17 October 2014 - 03:42 PM
Not sure what I'm going to do with the steel yet though. )
An epoxy primer and catalyzed topcoat of your choice will hold up well. With an epoxy primer, even a rattle-can topcoat will do well. Powder-coat if you want a more chip-resistant finish.
#12 Jon Matcho
Jon Matcho
  • Verified Members
  • 2,454 posts
  • Jon Matcho
  • Martinsville, NJ
Posted 17 October 2014 - 09:08 PM
Emron!  :)
I thought the same things regarding surface destruction, cracking, etc., but after more research I came to the conclusion that glass bead blasting was non-destructive, especially when done so the beads do not disintegrate.  Attached is a picture of the 'before' piece (the 2nd piece was only shown for contrast, and was done later).
Even with those other arguments until the bead blasting was offered I was close to moving forward with a mild abrasive blasting.  I suspect this is one of those areas we builders talk and worry about that really isn't a concern -- especially when doing a top coat of some sort on the parts.  I could be wrong.
Kent, would you still recommend an epoxy paint over a chromate conversion coating assuming no difference in price (I have a good deal lined up)?
I also thought the welds on all the pieces were very good FWIW.  Thanks for the feedback, appreciated!
#13 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 836 posts
  • Kent Ashton
  • Concord, NC
Posted 18 October 2014 - 09:00 AM
How did you finish the nice-looking ones?
I have only used chromate conversion (Alodine) on aluminum pieces.  Hang them in a jar of Alodine for a few minutes.
For steel, I see that a chromate conversion can be used over zinc plating   http://en.wikipedia....version_coating  but I don't think it does very much on bare steel.  Your pieces, being a little chipped up, I would scotchbrite, sand, or wirewheel them to remove rust, epoxy-prime, and paint.  That's about the easiest thing to do.
Edited by kent ashton, 18 October 2014 - 09:02 AM.
#14 Jon Matcho
Jon Matcho
  • Verified Members
  • 2,454 posts
  • Jon Matcho
  • Martinsville, NJ
Posted 18 October 2014 - 09:39 AM
There's no finish on the nice-looking parts yet. They're just coated with an oil for now, which I'll wash off before treating. All of the parts are now nice-looking (bead blasted).
Thanks for the tips! I don't want to go crazy, just prevent oxidation...
Stats
