215 -
1
Posts posted by Jerry Schneider
. It seriously muddies up the thread like mentioning retracts -anywhere- I can predict how that will go and who all will weigh in on both sides, its tiresome and always comes off like a racial/ethnic/or political argument, people entrench in their camps, nobody gives an inch, nobody learns a thing. Its very much like watching a Civil War renactment.
...and its spelled "Chrissi"
Krisssy,
I think the scale is MUCH more betta than the pump.
When donning the right, use a mirror.I was getting ready to start my wings and it turns out that all of the gloves I just got from Aircraft Spruce are all for the left hand.
Now what??????
I ruminated quite a bit over this subject when I was in the finishing stage.
Although many people have used this technique, I just didn't like the idea of possibly messing up the chemical/mechanical properties of the micro.
My technique came down to this:
1) Mix micro to the consistency of thick peanut butter.
2) Smear a big glob/bead on with the heel of my gloved hand.
3) Heat an appropriately sized drywall taping knife with a MAP gas torch and spread micro with firm pressure to eliminate bubbles.
4) Only do 2 strokes over the micro . A third stroke will tend to make the micro lift up behind the blade. You can't put on too much.... Only too little. Then, you'll have to re-apply and get caught in the vicious fill/sand, fill/sand cycle, because as the micro cures, it develops a "hardshell" on itself, making it a pain to re-do. Do your best to fill once, and sand once.
You'll be amazed at how easy the micro spreads and resists peeling off with a hot blade!
Haven't used it, but I heard somewhere it wasn't the easiest stuff to slide down on.
I'm getting ready to do my upholstery with the synthetic leather from CH Draw. They make a product that has good "rub test" numbers (durability) and doesn't mind water.
Now... If I could only fine someone who doesn't want $200 per seat to sew the up.
Here's one.I am looking for an alternative solution to the Brock throttle quadrant for my Long Ez. I would prefer a push pull system and would be interested in any sucessful applications. Thanks.
It's Ken Laundrie's plane. (He states he uses the cup holders all the time.)
I've copied the heck out of his installation, and am in the process of making the throttle/mixture brackets.
I got cables from https://shop.tuthill.com/Cablecraft/
Models: Throttle Friction Lock 565-555 and Mixture Control 565-550-B
Yeah Cupholders!!!!
Sorry my site doesn't go into better detail.
I have the CG strakes. I made the skins in one piece, (I got the foam from a boat supply store.) I glassed the entire under-side of the top skins first.
The dip/gap that forms at the CG Strakes is no big deal because it's a dry area. Just make sure the foam/glass is right at the wet area of R-33 (or is it R-38? I'm going from memory here.) You can easily fix those areas later.
After you glass the bottom side of the top skin, (and it has cured.), place the skin, mark the ribs with a pen, and put box tape to the places where the ribs ride. Epoxy wide peel ply to the box tape, (this makes the top skins pop off the flanges easily.). Then place the skin on, weight it down, layup the t-flanges, and let cure.
Pop the skins off, remove the peel-ply and tape, and you're good to go.
Put the bottom skins on. Then the top skins.
HTH
Tampa is just around the corner from Houston.
But if you want to wimp out.... It's O.K..
Dang!That wasn't your problem, that's the "slow" hardener, which is easier to work than the 9700 "fast" hardener. Here's a views article about it.
I had hoped it would be just that simple.
Whew!
I used Jeffco as well, and was putting off fueling for fear my tanks would get "leprosy" too.
Your discovery makes sense.
Thanks for posting it. (Sigh of relief)
The Proxxon Industrial Drill/Grinder.
Zero to 20,000 rpm variable grinder. German engineering at some of it's best. You try this, you'll start thinking "Dremel" is a foreign word meaning "crap".
About $114, but mine's lasted me 6 years. I've replaced the main bearing once at a cost of $10.
I'd bet money the strakes tend to lock in the main spar to minimize twisting. Therefore, I would do my best to work around the baffles/ribs. (Unless they are different in a Velocity than a Cozy.)I do not know how much structural intergrity the baffles ad and if they would be a factor for metal bladders.
Actually, I was thinking of installing "industrial strength" Silly String dispensers.I am not really sure what he's up to...... but with a plane called 'webslinger' I hope he isnt importing spiders.
jus kiddin'.
No website I could find. Attached is a flyer Gary sent me a couple of days ago regarding the pods. I had to delete one older picture to meet this site's file size limitsWanted some more info of these elements but can't find any links to the Gary Hunter website, nor Featherlite ... any pointers, please.
I use MGS. You don't say what epoxy you're using.
As far as MGS goes:
The resin? Yes.
The hardener? Not unless you're sure the plastic is not permeable to CO2. Some plastics let it through, and it will spoil your hardener.
Better to store it in the can it came in.
I've been pouring from the can for years. I have a dispensing system for the resin, so I set the cup on the scale, zero the scale, pour the hardner first, (as it's difficult to get the exact amount poured), check the excel spreadsheet on the wall to find the requisite amount of resin to dispense, and open the resin valve untill the number is right. Viola'
Yep.Jerry, if you get a cabin, can we sleep in your driveway?... potti priveledges?
Roger that.Seminars? ah no, I'd rather see people out on the ramp talking about canards.
I WAS going to camp. Epoxy Lady chickened out, so here I am.Jerry,
What!? No camping outside with nature? I hope the weather is good - I'll be out there in my tent...
To whom it may concern:
If have a room reserved, and you're not going to be able to attend, I'd be happy to take it off your hands.
Jerry
Did I mention That was ONE WAY!!.... With the Cozy Girrrls in tow?(Ahhh yes. I remember it well. My first RR. Finding out it was a dry county. AND DRIVING 31 MILES FOR BEER!!!! Still a record in my personal log.)
(The horror.... The horror....)
The pizza?
I've had worse.
It's the company that counts..... And the beer.
Those were the days......
Chris,Oh well, out to the hangar with my new batch of fiberglass, EZ-Poxy and Jeffco to rebuild my strake interiors <sigh>.
Did you determine the cause of the Jeffco adhesion problem you had?
Sorry if I missed it.
This was a new on on me as well.
I won't give it a second thought.
Thanks for the comebacks!
Does anyone know about any requirement for a FAR25.853 burn certificate for upholstery in our planes?
I asked for a quote from a fabric company, and they gave me a quote and told me an additional $50 to the FAA for the certificate.
I want the properties, but not the fee....
My guess is it's not required in our planes.
Inquiring minds want to know......
The hub post is hollow. Instead of screwing into the hub, (old-style), the fastener goes thru the hub to a lever which has a cam latch on it, which draws a fastener tight against the hub of the tool from the other side.What's the quick change feature?
Rough River 2009
in Events, Fly-ins, and Trip Reports
