Bryan Dover Posted September 6, 2022 Share Posted September 6, 2022 (edited) Kathryn's Report Anyone know who the pilot was? Recent purchase? Edited September 6, 2022 by Bryan Dover Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted September 6, 2022 Share Posted September 6, 2022 11 hours ago, Bryan Dover said: Kathryn's Report Anyone know who the pilot was? Recent purchase? Yes and a bit more than a year ago. I did the last two CIs on the plane. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
slk23 Posted September 6, 2022 Share Posted September 6, 2022 (edited) ADS-B track log:https://flightaware.com/live/flight/N10EZ/history/20220905/1605Z/O22/O22/tracklog Some very high ground speeds (198 knots) toward the end of the flight. However, it took around 15 minutes to descend from 15k' to 2.3k' (ground elevation) which suggests it wasn't major structural failure (e.g. wing attach fitting). Also, there was a climb beginning at 9:41 AM after the long descent (approx. 6 minutes before last ADS-B position) where the groundspeed went down to 106 MPH. Then another high speed descent (219 MPH) followed by a low ground speed descent into the ground (assuming the ADS-B data is reasonably complete). Loss of engine power? Deep stall? Pilot incapacitation? I have no clue. Edited September 6, 2022 by slk23 Quote Link to comment Share on other sites More sharing options...
slk23 Posted September 6, 2022 Share Posted September 6, 2022 Turns out I didn't look closely enough at the flight track; I thought it ended away from the airport but it actually he went down while apparently trying to land on Columbia's runway 17. It doesn't look like he flew a conventional landing pattern, then did a go-around. Pure conjecture on my part: loss of engine power after the go-around followed by an attempt to glide to the runway and impact into some fairly rough terrain. Quote Link to comment Share on other sites More sharing options...
bmckinney10 Posted September 6, 2022 Share Posted September 6, 2022 If you watch the FlightAware trace replay, it shows the plane holding altitude on base to final, with a slight decent on final approach speed around 80mph ground-speed on short final until about about 3/4 mile from runway when the ADSB stopped. News report indicates it came down in a backyard. It appears it was stable just before the ADSB stops recoding Quote Link to comment Share on other sites More sharing options...
