Light Speed Control Module Location
Cmead
9 hours ago, Canardale said:
Kent, you should consider modeling up a flux capacitor and installing it in there for giggles.
Ha!  I presume you are mocking my wiring.   🙂  Ya know, you start off with good intentions to make everything as neat as a pin and then it goes downhill.
On 11/19/2020 at 12:42 PM, Cmead said:
Where are you all mounting the control module for the LSI ignition system?
Depends on the type of plane. As Kent indicated, in COZY's and LE's, they generally go on the firewall above the spar. On VE's, that's not available, so they tend to go in the hellhole (which is a nightmare, unless you've got a hellhole access cover underneath the landing gear, and even then...
Some VE's have an enlarged hellhole access hole in the rear seat seatback, and mount the box on the back of a cover for the hole, with service loops for the wiring.
