Karmutzen Posted May 27, 2020 Share Posted May 27, 2020 I have a bumper on top of the nose gear spring. Do I need another between the nose gear opening and the nose (only about 5 inches)? CP said “bumper directly under the NG31 bulkhead”, but I don’t know where that is or how to attach a hockey puck. glue? one two or three bolts? Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted May 27, 2020 Share Posted May 27, 2020 The bumper should be placed where the nose would touch the ground, like so: https://ez.canardaircraft.com/www.ez.org/pages/waynehicks/chapter_13_8.html Personally, I use a hockey puck or other hard rubber, cut it to a pleasing shape and glue it to the nose with micro or contact cement, then run a small rim of BID around it. Pic below is one on a Long-EZ. I used a boat trailer bumper and cut a piece off. No need to bolt it, it will disappear with a nosegear-up landing. I like the rubber bumper but there are many ideas such as the one above. https://www.etrailer.com/Boat-Trailer-Parts/Yates-Rubber/YR400BLK.html Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Karmutzen Posted May 27, 2020 Author Share Posted May 27, 2020 (edited) Existing bumper, maybe you can’t see it in the previous gear down photo. Question is do I mount a second one in front of it on the fibreglass nose. Edited May 27, 2020 by Karmutzen Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted May 28, 2020 Share Posted May 28, 2020 A bumper serves as something on which to rest the nose without screwing up the paint. Can you rest the nose on yours? It looks like you might have scraped the last one off. If so, repair/repaint the scrape and consider relocating the bumper. generally, bumpers do not protect against damage from nosegear-up landings. There is usually a repair needed but it’s pretty simple. A PIA but simple. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
