towplane 1 Posted November 6, 2018 I think most quickie pilots will agree that the plane is fine except for the powerplant. Kohler was the first industrial engine mfgr. to come up with a 90 degree twin, so that's what I used. Midwest Super Cubs (MSC) has a long history of making these engines perform reliably so the basic CH 25 (25 hp) was slightly modified: factory iron flywheel replaced with one duplicated in 6061 Al; crankshaft extension machined from 7071 Al; power take off is from flywheel end in order to keep cooling airflow as designed and reduce torsional harmonics; governor assembly removed; aluminum intake manifold replaced with plastic one from MSC' ground-adjustable main jet from MSC rotating assembly balanced, cam ground, heads ported & matched by MSC; all metal parts except flywheel (has magnets) cryogenically treated by Cryogenics International; Earls Performance oil cooler; CH18 coils substituted for the CH25 Smart Spark so that engine can run without battery; This Quickie had 300 hours with the Onan, and so far has 18 with the CH 25. Climbs 600 fpm @ 69 kias, gets over 100 mpg @ 73kias, goes 103 kias at 3600 rpm using 1.5 gph. the firewall forward weighs 1 pound more than the Onan did, and has an electric starter. Briggs, Honda, Subaru, and now Yamaha all make a similar engine. Kawasaki's is water-cooled. Hopefully folks will use one of these engines and get the Quickie fleet flying again!. 1 Quote Share this post Link to post Share on other sites
Kent Ashton 317 Posted November 6, 2018 13 minutes ago, towplane said: gets over 100 mpg @ 73kias, goes 103 kias at 3600 rpm Nice writeup. I only recall seeing one Quickie here on the east coast with some kind of pull-starter engine. Very interesting to see him get running. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Share this post Link to post Share on other sites
towplane 1 Posted November 16, 2018 On 11/6/2018 at 7:42 AM, Kent Ashton said: Nice writeup. I only recall seeing one Quickie here on the east coast with some kind of pull-starter engine. Very interesting to see him get running. Thanks, Kent. No one's contacted me yet about details as to how to get their quickie going so I have to get the word out better. Maybe should offer it to Kitplanes? Quote Share this post Link to post Share on other sites
Kent Ashton 317 Posted November 16, 2018 You might try this forum http://www.quickheads.com or the Quickie Yahoo group. If you want to sell it, I'd post it on Barnstormers. I suspect there are just not many active Quickie builders these days. Post some flying stories or building experiences. People are interested in those kinds of threads. Nice of you to offer help, though. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Share this post Link to post Share on other sites
Eugen 23 Posted February 6 Hello Chris, nice engine! My engine is on the way 🙂 which prop you did on that engine ? Dia? Pitch? Quote Homebuild Projects ASSO X-RAY 600kg version - still in progress QUICKIE Q1- still in progress WWW: https://aerobase.weebly.com PICTURE: https://www.flickr.com/photos/aerobase/ Share this post Link to post Share on other sites
towplane 1 Posted May 5 On 2/6/2022 at 10:53 AM, Eugen said: Hello Chris, nice engine! My engine is on the way 🙂 which prop you did on that engine ? Dia? Pitch? eugen is that a q2 diagram? mines a Rutan model 54 (quickie) Quote Share this post Link to post Share on other sites
Eugen 23 Posted May 5 18 hours ago, towplane said: eugen is that a q2 diagram? mines a Rutan model 54 (quickie) Yes its a Q2 and comes from Autodesk fusion360. im on my way to build the q1 wing after fuselage is done so far. Would like to share with you details about the engine. I had some questions….. Quote Homebuild Projects ASSO X-RAY 600kg version - still in progress QUICKIE Q1- still in progress WWW: https://aerobase.weebly.com PICTURE: https://www.flickr.com/photos/aerobase/ Share this post Link to post Share on other sites
Eugen 23 Posted May 7 @towplane , I send you a message. Quote Homebuild Projects ASSO X-RAY 600kg version - still in progress QUICKIE Q1- still in progress WWW: https://aerobase.weebly.com PICTURE: https://www.flickr.com/photos/aerobase/ Share this post Link to post Share on other sites
