I am missing some parts for my Cozy projekt, the canopi, the stronger pedals, parts for the airbrake Ecc i you Got some parts laying around please let me know
Share this post
Link to post
Kim, you are familiar with the Cozygirrls, yes?  They sell a lot of parts.   http://www.cozygirrrl.com/aircraftparts.htm
Some other parts here  http://www.long-ez.com/custom-parts.html
Not everyone is equipped to make their own parts but many of them are easy to make if you can find a friend with the simple tools.
Some examples:
Bellcranks/CS-128.  Order the bearing from Spruce, cut out the bellcrank on the bandsaw from 2024 stock, file smooth, rivet with a hammer on a block.
Stick Assembly.CZSA ($69)- Cut from raw tube and 4130 sheet, bend on a cheap brake, take to a welder to be TIG'd.
I enjoy the fabrication and have acquired the equipment so I made most of the parts for my airplane.  The only thing that stumped me were the canard torque tube offsets MKNC-12A L/R ($169 each!).  There is a 3/16" hole that needs to be drilled in the inside of surface of a tube that is hard to get right.  I could probably make those too with a little better jigging.
I would also keep an eye on Barnstormers.com for parts and set up an alert here for Cozy/Long-ez parts  http://www.ebay.com/sch/Aviation-Parts-Accessories-/26435/i.html?_dmpt=Motors_Aviation_Parts_Gear&_pcats=6028%2C6000&_rdc=2  You might get lucky.
Share this post
Link to post
If you can't find these parts seondhand, their are other options.
Canopy - Try Airplane plastics...http://www.airplaneplastics.com/
Rudder Pedals - here are the plans.... http://cozybuilders.org/newsletters/news_64.html#IMPROVED_BRAKE_PEDALS  Dennis Oelmann built these for a long time, he may no longer be doing this.  Aerocad may also supply rudder pedals.
Airbrake - the parts in the plans are not sold by anyone that I know of.  Most builders are installing their own electric actuator or purchasing a system here...http://www.long-ez.com/custom-parts.html
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
