Quickie drill jig
Big Steve
I thought some of you could use this quickie drill jig idea. I took a chunk of aluminum and squared off the face. Then drilled a hole through it the size of my drill I was going to use. You mate it flush up against the surface you are going to drill and you get a nice straite hole. I used it to pre drill my spar pilot holes. Yes I am back Jon sent me my password. Thanks Jon. Build on STeve
Posted Image
Steve Harmon
Lovin Life in Idaho
Cozy IV Plans #1466 N232CZ
Working on Chapter 19,21
Great youre back! Was wondering about you. I guess a guy could do the same thing with a block of wood. Wouldnt be so robust, but not many have 1-1/2" thick chunks of aluminum sitting around.
Nice construction tip.
Self confessed Wingnut.
Get up off that couch!!! =)
Along these lines, this is the jig I used to drill the holes for the elevator tube.
Quick/dirty on the table saw, blade tilted to 45*, run the block through on both edges/sides ("V" is now perfectly centered). Drill the pilot/guide hole in the jig on the drill press. "V" up, hand rotate the drill bit till the bit touches both edges of the "V", now drill away.
Rick
