A-Solution
Bob,
Is your intention to build an aircraft using the same method used by Velocity in which 2 halves are put together ?
The reason I ask is Velocity has a top and bottom mold, the photos you posted makes it look like yours is comprised of 3 or 4 pieces to build the fuselage.
Looks very Berkutish, is the A-Solution going to have a split canopy and be full RG ?
Tony
VariEZe N297TV
Miami, Fl.
Looking back I remember a couple of friends stopping by the hangar one day for lunch. One of them had just sold a Long Eze project. I brought up at lunch the building of the tooling to make a fuselage. I guess that it’s over lunch or out on the golf course that a project like this starts I don’t golf.
Not being computer savvy I built the plug the old fashion way. I wish I was as talented as some of the others posting on this site.
The tooling has been built to make the fuselage in two parts, one upper one lower. The upper tooling had to be made in two halves to get around the draft of the canopy turtle decks. My reasoning for that was to get a better fit for the canopy frame and to do some of the other lay ups in the turtle deck areas. The roll over structure could be laid up in the tooling with know secondary bonding for that part of the lay up. The main tooling has been made to have a split canopy. The canopy frame tooling has been made to produce that style as well as a full tilting frame.
Bob Setzer
  • Like 1
I guess the real motivation to this project was that I wanted one of these. I did not fell I could get there without a molded fuselage. Like all things you think you can get things done a little quicker.
Your friends always challenge you. One of those things was to build a CNC foam cutting machine for the canard and wings. Works great but a lot of work.
The fuselage is going to be able to go as a fixed gear with retracting nose or full RG. The RG is going to that a little thought.
I’ve set aside this Monday and Tuesday to build the left upper side of the tooling. The tooling is going to be made in three parts. Two upper One lower. The two uppers will be used to make One upper piece.
Bob Setzer
  • Like 1
This fuse set-up looks like its going to be lite-lite-lite. Love what you are doing, keep it up!:cool:
Thanks- Here is a photo of the early days of the project.
Note, I bought a canopy for the project to assist in making the canopy frame tooling (that canopy is now lost under fiberglass and filler, my way of lofting the canopy frame tooling). The frame tooling was a separate part but was built with it setting on the fuselage plug. That allowed me to keep W/L 23.0 with the fuselage plug. Even with the use of the canopy (which by the way was really nice) needed a lot of work to get the tooling worked out.
Bob Setzer
  • Like 1
Bob,
I like very much your work and know very well how hard is to build something like that since I've done something similar.
the hardest part for me was to check it for right/left symmetry.
I have built the thing on an automotive frame repairing bench but I found that I could not do better then 1-1,5 millimeter error so at the end I decided to have the whole thing laser scanned and analyse it with a computer software.
How did you solve this problem?
Bob,
Enzo Ferrari " you no-a can-a see-a both-a sides-a at the same-a time-a"
There are thousands of these planes flying and not one of them has both sides the same
Root beer shot outta my nose when I read... thanks Lynn for the classic response.;)
Beautiful work...obviously not essential at our speeds...but beautiful work.
Self confessed Wingnut.
Get up off that couch!!! =)
Bob,
Interesting question, I started the process by making a front and firewall forming bulkhead templates. You can see by the upper post that I made the fuselage (using front and firewall former) just before the nose. The nose is a different story. I have not answered your question yet. I started by cutting matched front bulkhead templates and taking them as far back as I needed before percentage blending into the firewall. Before installing foam and fiberglassing I did my best job checking for high spots with straight edges and flexible steel rulers. I’m hoping you can see now why I did not get involved with the nose at this time. When you cover with fiberglass and start to fill everything starts to change. I had made a center line on the front and rear templates, and after a rough fill of the surface I center line the lower plug. After that I made horizontal templates of the fuselage side. I used these to decide which side needed additional filling. After that it was at the time it took a good eye to look for optical problems with a couple friends and mine. The last template I made for this part of the fuselage was vertical full length, with this template I flip-flop it from one side to the other. Over a 98-inch length I could just see some light coming through the edges. I can not say its perfect, but I’m not either. I did as well as I could. I’m happy with it
Bob Setzer
Lynn it's true!being hand made things I do not see how those aircrafts could all be 100% perfect.
Tony said that even his berkut was not perfectly straight.
may be I am too manic about it but even if I do not see how a so small error could affect the behaviour of my aircraft nor I can see it looking at the fuselage, when I'm resting in my bed it seems like the error calls me saying "hey, you can't see me but you know I'm here!!".
I did not know it came from Enzo Ferrari but it's a very common way to say here in Italy, anyway it was not enough to put my mind in peace....
but it's true: perfection is not something about humans.
I really like this sentence:"I can not say its perfect, but I’m not either"
wise man!
thank you guys
Again airnico, as I said last year, " Your fuselage you have come up with is absolutely, to my eye, one of the greatest custom shapes for the Long Eze.
I wish you would post a pic here again for everybody to see.
I think its because of your Italian eye!:)
Another big day today. Got five of my friends ( Bill, P.J., Allen, Dennis, Sal and Paul, Paul could not make it today put has been a big help, hope he fells better ) to help in building the left side upper tooling.Twelve hours later and another seven tomorrow. I'm going to let the tool set till Friday or Saturday before pulling both sides. A real step forward in the project. Boys and girls it beat me up, I guess I,m not as young as I used to be.
Airnico
I put the 12inch canard stretch in the plug for the 360 or 540 engines. Did you do the same.
Bob Setzer
  • Like 1
wise man!
thank you guys
I just could not go the sleep without telling a related story. Its just to funny Not to tell.
I my early days of building my Vari Eze I had built the spar, And after it had cured over nigth I took a look at it the next morning a found a small defect in the inspection hole opening (real small defect). I had another Vari Eze builder From are EAA chapter stop by and look at it. Needless to say he thought I did a great job and not to be concerned. You know I was not able to sleep for the next two nights (REALLY). It got so bad that second night at about 2 A.M. in the morning I went downstairs and took a big saw a cut the spar in half and went back to bed (fell right to sleep). Started on the new spar the next day.
We all have a little Superman in us, I know I can see right through my project. So I know right were your coming from.
Hers a couple photo' of my Vari Eze.
Bob Setzer
  • Like 1
Just beautiful lines...friggin beautiful!
Bob Setzer
So you know what I'm talking about.....really funny, may be it could sound even crazy to someone, but when you start building something like that you want to do 110% your best every day, no compromises, otherwise do not start at all.
I did not stretch the fuselage because I actually did not have experience on this mod, there is a guy here in italy who is building a berkut but I was not able to have any collaboration whit him so I preferred to stick to the original canard position, but I have a quite long nose to put ballast in.
I have later met a friendly guy who has built a stratched fuselage and he reported to me that it flys better than his previous per plans Long-Ez: according to his words it has superior stability and can fly to greater angles of attack.
I did not fly with him so I only can report his words, but you can take a look at his work here
http://www.comgz.com/stag-ez.htm
another question:
why did you build a downward(and forward)inclined surface where the canard is supposed to be attached?
Bob Setzer
Did you put the 12" stretch between the canard and main wing or does that include adding to the nose? I was looking at adding 6" between the back seat of the pilot and rear passenger for more leg room and dual controls.
Best regards,
Bruce Sturgill
http://www.pursuitofflight.com
there are no reason for dual rudder pedals in a long ez . the rudders are only used during landing and take off and you can not land one from the back seat. during cruse, turns that can be made safely from the back do not require any rudder to make a coordinated turn.
Bruce
The canard move was taken from the front face of the firewall. it will set a F.S. 10. This move seems to have been proven to work by other flying aircraft.
Bob Setzer
Getting closer to seeing if its going to come together.
Finished the Left upper tooling lay-up today. I've been waiting four weeks to see whats underneath. You cannot remove the right side till the left side has been done. After some trim a clean-up this week hope to see what it looks like this weekend.
Bob setzer
