Kent Ashton Posted August 14, 2008 Share Posted August 14, 2008 Hi Chaps, Rolled my project out this week to flip it in preparation for glassing the strakes. Got the strakes glassed and sumps installed. Found two leaks--the same spot in each tank--at the top of the tanks where the tank bulkhead meets the side of the fuselage near the gauges. Should be an easy fix; I forgot I hadn't taped the upper-inside corners of the storage area. -Kent Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Edge 513 Posted August 14, 2008 Share Posted August 14, 2008 That looks great. You are moving along. I won't have the luxury of sitting it like that,upside down and angled, with my canopy and turtleback finished. =] Your strakes are looking tight and well done! Quote Self confessed Wingnut. Now think about it...wouldn't you rather LIVE your life, rather than watch someone else's, on Reality T.V.? Get up off that couch!!! =) Progress; Fuselage on all three, with outside and inside nearly complete. 8 inch extended nose. FHC done. Canard finished. ERacer wings done with blended winglets. IO540 starting rebuild. Mounting Spar. Starting strake ribs. Link to comment Share on other sites More sharing options...
Big Steve Posted August 14, 2008 Share Posted August 14, 2008 Edge: That is exactly why I am not bonding the turtle back in until the very bitter end. That way I can take it off and not worry about smashing those time comsuming window. Can also set it down closer to the ground to work on. Build on STeve Quote Steve Harmon Lovin Life in Idaho Cozy IV Plans #1466 N232CZ http://websites.expercraft.com/bigsteve/ Working on Chapter 19,21 Link to comment Share on other sites More sharing options...
Edge 513 Posted August 14, 2008 Share Posted August 14, 2008 Thats what I was seeing Steve!!=] Too late for me though. I'm all attached and top firewall connected and plyed. Good for you, you can wait. [thats what you having built a plane already clues you in on...plus a few things- you dog.=]] Quote Self confessed Wingnut. Now think about it...wouldn't you rather LIVE your life, rather than watch someone else's, on Reality T.V.? Get up off that couch!!! =) Progress; Fuselage on all three, with outside and inside nearly complete. 8 inch extended nose. FHC done. Canard finished. ERacer wings done with blended winglets. IO540 starting rebuild. Mounting Spar. Starting strake ribs. Link to comment Share on other sites More sharing options...
