velocity center spar
airnico
hello canardians,
I found this picture somewhere on the web and was attracted by the center section spar shape: it's not a box shaped spar like the long-Ez's, but it's a C section.
I did not know this before so it was a surprise for me.
do you know if this kind of center spar(C section) is used only on the velocity or if some other models have it?
looking at it I can see the brown colour of foam(I suppose it's the foam's colour) so it should be a glass fiber/foam sandwich structure: am I right?
do you know if it's a moulded part that comes prebuilt in the kit or is a home builded part???
so there is foam inside....
the horizontal faces look to be very thin: is there foam only in the vertical part or is all the structure a sandwich?
do you know exactly how it is made?how many layers and what kind of fiber?
I know they use biax fiber for the fuselage and not a lot of layers, can you give me more info about the velocity structure please?
the way they build the center spar is attractive, it's of course easier and faster to be built and it gives more space for fuel: it would be really interesting to make a load capabilities comparison between this one and the Long-Ez's
I don't know the details of the construction of the spar. I received it as part of the kit. Yes there is foam inside. I think they use this as a base for layering the glass. velocity uses Triax extensively for wings and structures, so I would assume it is several layers of Triax, but I've never seen it built.
Jack
I took a tour of their factory in February... I don't recall specifics of what was built with what, but I do recall being told that in some places, they used a fibre product that was sort of a glass rope, rather than the usual cloth. If I recall correctly, the spars were one place. I wish I could remember the name of the glass rope-like stuff for you. As I recall, they said they used it because it make it faster and cheaper to make those parts that way, it wasnt an appropriate technique for thin/short shapes, and I don't think he commented on if it made for a lighter,heavier,stronger or weaker product. (I wish I'd thought to ask at time, but I'd guess its strength neutral or stronger, but heavier)
You wouldn't want a thinner spar for more fuel. Any extra fuel gained would be behind the CG, we don't like that.
yes, we actually do not like that so much. I think it would be more or less 5 gallons each tank: may be it could be acceptable if you don't have already a lot of ballast in the nose.....
I suppose it was a glass roving used as a reinforcement with who knows how many layers of glass cloth....
it would be actually very interesting to know it: does anybody know it??
does anybody know if this kind of center section spar has been already installed in a Long?
No, it's not.
The spar on the Long-EZ is plans built.
06-20-2008 10:57 PM
yes, ok the spar on Long_Ez is plans built, but there are some guys out there building something that is not strictly per plans, may be one of those bad guys have already done this mod and it could be just another to add to the mods list....
.....what I mean by 'Plans built' is that these are wet layups done in your garage/shop.
Example: The Berkut spar is pre-preg Carbon Fiber layered into a mold and autoclaved to high temperatures. Now you could try and do that but most of us do not have those types of facilities available to us.
Also, what limitations would you acquire as a result. I'm building with the Infinity retracts ......... which I couldn't do if I deviated from the plans built spar.
it would not be difficult to build a molded C-section spar and autoclave it, something else would be to build a box shaped spar: it would be difficult and very expensive.
I like the solution they have found to produce an easier(and so cheaper) molded spar and the added fuel capacity resulting from it could be also a good thing.
If you are not concerned with CG- just put some holes in the front of the spar and partition it off, so as to hold fuel, and let it function as another fuel area in the strake/cell. Hey- its just experimental aviation! Just dont freak as you auger in...
Self confessed Wingnut.
Get up off that couch!!! =)
If you are following Daves lead you can't go wrong. the micro shelf must be a Berkut specific method. on the berkut the forward spar face is set into the spar about even with the sparcaps and on the long /cozy it is 2" forward of the spar caps. I believe that is how Dave got back some of the fuel capacity and space taken up by the gear leg wells
searching on the forum I've found this: is it not something like the mod I was talking about??
