killerb1971 Posted May 25, 2008 Posted May 25, 2008 Made some more progress today. Making good use of my extended weekend to play catch-up from my 2 months of not doing anything. Anyways...., it always feels good to be moving forward. Quote Rob Wiehl COZY MKIV #1521
Kent Ashton Posted May 26, 2008 Posted May 26, 2008 Nice work. If you're going to use fuel sight gauges, I would make the depressions around the gauges flat areas about 4.5 inches wide or more. The gauges themselves are about 3 inches wide and might make it a little easier to install them on a wider flat area but it depends on what your plan is there. I've installed these gauges on three airplanes. I found I needed to remove the white contouring foam (clark?) just below the longeron where the gauge is to be installed, otherwise you can't install the gauge high enough to show the top two or three inches of fuel when the tanks are topped-off. -Kent Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold
killerb1971 Posted May 26, 2008 Author Posted May 26, 2008 Plans say if using the Vance Atkinson gauges, make a 2" flat rectangle depression and make it 7" long from the base of the spacer foam (end of the taper). I have read that I should make the depression a little longer than the 7" so I can set the hole at the bottom right at the base of the tank. I went about 7 5/8" deep just in case. All of my edges are tapered so the uni will lay in good. All surfaces are sanded and corners rounded for the uni to lay correctly. Before doing the uni layup, I just want to verify with the group that the measurements on the fuel gauge depressions are correct, or will I run into problems? Better to know now while it is easier to fix. Quote Rob Wiehl COZY MKIV #1521
macleodm3 Posted May 27, 2008 Posted May 27, 2008 Like Kent said, some of the spacer foam has to be removed. Now is easier, but if you follow the plans, you may need to fix it later. Quote Andrew Anunson I work underground and I play in the sky... no problem
killerb1971 Posted May 28, 2008 Author Posted May 28, 2008 The photo you included looks exactly like what I have. I am getting ready to do the layup this week. I marked out my 30 degree angle lines on the foam as a guide. Quote Rob Wiehl COZY MKIV #1521
