TMann Posted October 5, 2007 Share Posted October 5, 2007 I would like to post cure my canard in the jig to insure it stays in the best aligntment possible. I'm figuring I'll need to get it up around 160 degrees. Has anyone found a way to accomplish this (without moving my entire setup outside.) I'm thinking heat lamps maybe? Too bad I can't tap into the water heater as a heat source ....... ......... or maybe I could??? Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Jon Matcho Posted October 6, 2007 Share Posted October 6, 2007 Get hot air in there somehow, safely. I wouldn't do heat lamps because they're hard to evenly distribute the heat. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
rickh Posted October 6, 2007 Share Posted October 6, 2007 I'm thinking heat lamps maybe? Too bad I can't tap into the water heater as a heat source ....... ......... or maybe I could??? Depends... Add a tee to the drain valve on the heater, add a tee to the hot water outlet side, fill the gap with hose and tubing to [under] your table [top]. Convection rulz, no pump needed. If it's close to your table, you'll get some heat. If it's enough though... Toss some poly on a frame over the table. Set a small ceramic fan forced heater at one end of the 'tube', let 'er rip. Vary the temp by setting the heater closer/further from the opening. As in don't tape it to the poly tube/frame. I've seen these heaters advertised as "personal" heaters, like under a desk to warm your tootsies. 500w tops, 250w on low (or thereabouts). YMMV, don't forget to floss. Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
