It does not really appear to be much more expensive than a Lyc (maybe somewhere between buying a new O360 or buying a new O360 + 1 overhaul).
I did not see what the TBO on this engine was. My swag would be somewhere between twice a Lyc TBO to 5 times---then again, maybe even more than that.----Like I said, I did not see the data posted on the page. If my guess on TBO is somewhere within range, this may be a very good buy.
Pretty cool though!
It's best to keep your $$ in your own pockets on this one guys. Innodyn has taken many deposits and delivered zero engines after many years of advertising and exhibiting that CNC machined chunk of aluminum at shows. You will notice that the website promises future information in January of 2005. They have yet to publish dynomometer information for this engine. With a single stage turbine and a single stage compressor, one would need to discover some new principles of physics to achieve the results they have advertised.
Aubrey
You beat me to it. I was going to say that I am pretty sure no one has hung one of these engines on anything except the prototype and 1 customer installed unit.
Long history of promises and taking money with nothing delivered. Reminds me of Jim Bede.
That said, there might be some CG issues with this engine on a stock Long-EZ. The other problem is that the hot exhaust from the turbine has to go through the prop. It takes some exotic materials, I believe, on the props of the Starship and Piaggio in order to accomplish this.
Rick Pellicciotti
Belle Aire Aviation, Inc.
http://www.belleaireaviation.com
There is no reason to look at the Innodyn until units are delivered and pilots report the performance. Since it is really based on the the Solar T62 turbine, it is a little hard to get excited about it.
Other engines show much more promise: Mistral, Delta Hawk, etc. Some of these are already delivering powerplants.
Nathan Gifford
Tickfaw, LA USA
Cozy Mk IV Plans Set 1330
Better still --> Now at CH 9
I don't have any direct knowledge, but have an authoritive sounding email at home claiming turbine exhaust temperatures aren't much different to what is emitted by a 13B!
Mark Spedding - Spodman
Darraweit Guim - Australia
Cozy IV #1331 -  Chapter 09
www.mykitlog.com/Spodman
I supposed that could be correct especially if the exhaust is brought out well upsteam of the prop. I think Nick U. is pondering a turbine installation (Allison/Rolls Royce) on his project. It will be interesting.
Of course, if turbine exhaust on the prop is a problem, you could always eliminate the prop:
http://www.ezjetinc.com
Rick Pellicciotti
What a better answer! I am a helo mech and use to seeing most turbine shafts coming out of the intake side of an engine connecting to a gear box of some sort. I would think that the issue would be keeping the splines properly lubed with the heat constantly beating at the seals. Someone smarter than me could probably come up with a solution to that but...
Barry Walker
Saving for a set of Cozy MKIV plans/kit and large "shed" (in that order). If I don't have the plans and start building when the "shed" is done, my wife will find another use for the "empty" space!
  • 1 month later...
