Aaron Posted April 3, 2003 Share Posted April 3, 2003 I'm looking for manufacturer published glass transition temperatures for available epoxies, anyone know of a convenient link? I'm most interested in something with a glass transition temp higher than 250 derees F- I thought I'd play with making a custom intake to replace the aluminum monstrosity sitting on my bench. Any suggestions? Quote Link to comment Share on other sites More sharing options...
John Slade Posted April 3, 2003 Share Posted April 3, 2003 Talk to Bruce Turrentine, See: http://www.rotaryaviation.com/custom_mazda_engines.html Bruce is making an intake system for the Mazda using high temp epoxy. He's at Sun & Fun right now. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Aaron Posted April 8, 2003 Author Share Posted April 8, 2003 Derakane 470-300 data: http://www.dow.com/webapps/lit/litorder.asp?filepath=derakane/pdfs/noreg/125-00271.pdf&pdf=true There is a higher temp version available, but 300 degrees should give me room to spare for an intake. Apparently, more important than the glass transition temp is the heat distortion temp, for this material it's 300F when properly cured. Next steps in the process: 2) Locate a gallon supplier of Derakane 470-300 and appropriate catalyst 3) Create and test tubes Quote Link to comment Share on other sites More sharing options...
CBarber Posted April 11, 2003 Share Posted April 11, 2003 Following....letting you be the guinie pig. Keep us posted. Will be interested in Bruce T's progress as well. Quote Christopher Barber Velocity SE/FG w/yoke. Zoom, zoom, zoom. www.LoneStarVelocity.com Live with Passion... Link to comment Share on other sites More sharing options...
marbleturtle Posted April 11, 2003 Share Posted April 11, 2003 ... yes please let us know the results of your testing. Intake plumbing seems to be the biggest obstacle for automotive conversions. Quote This ain't rocket surgery! Link to comment Share on other sites More sharing options...
Aaron Posted April 28, 2003 Author Share Posted April 28, 2003 ACP (Aerospace Composite Products) e-mail: info@acp-composites.com has a resin they call EZ-LAM HT: E-Z LAM HT High Temperature Epoxy Laminating Resin DESCRIPTION: An ultra high temperature laminating system for the construction of laminated composite parts. E-Z LAM HT has excellent wet-out characteristics, facilitating lay-ups involving compound contours. Its long pot life allows for ease of vacuum bagging . The maximum operating temperature for laminated parts manufactured from E-Z LAM HT is 450 Deg. F. MIX RATIO: 100 parts by weight E-Z LAM HT A 33 parts by weight E-Z LAM HT B POT LIFE: 150 gr. mass 4 HRS. @ 75 F CURE: ROOM TEMP SET FOLLOWED BY 2 HRS. @ 150 F 2 HRS. @ 200 F 2 HRS. @ 250 F 2 HRS. @ 300 F 2 HRS. @ 350 F ALLOW TO COOL IN OVEN PROPERTIES: VISCOSITY, MIXED 5000 CPS DUROMETER D 94 SHORE SPECIFIC GRAVITY 1.19 gm/cc USE TEMP, 400 F FLEXURAL 102,000 PSI COMPRESSION 64,000 PSI TENSILE 57,000 PSI SHELF LIFE: Twelve months when stored in tightly sealed containers at room temperature. SAFETY: Avoid contact of resin or hardener with skin or eyes. Wear disposable gloves and eye protection. Avoid breathing vapors, apply under good ventilation. If contact occurs consult physician. For more details refer to E-Z LAM Safety Sheet. Quote Link to comment Share on other sites More sharing options...
dust Posted April 28, 2003 Share Posted April 28, 2003 Arron, this is great info and I'm sure to use it, tanks Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
Aaron Posted April 28, 2003 Author Share Posted April 28, 2003 Hey dust, what do you need the High-temp stuff for? Quote Link to comment Share on other sites More sharing options...
dust Posted April 28, 2003 Share Posted April 28, 2003 Well, on the turboe i have a convective and a conductive heat problem. need to retain heat to the turboe and disapate it from there on out. I don't know what i will need to fabricate, but knowing about the appropiate materials will give me options. Looking forward with happines and dred Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
Aaron Posted April 28, 2003 Author Share Posted April 28, 2003 I think you mean you need to shield the exhaust half of the turbo and the manifold from everything else. I've seen this done using insulated pads which tie on around the exhaust piping, they're made to withstand 2000F heat. I did see one lancair where the builder used a carbon composite material outside the silica fabric, but I'm not sure it ever flew: http://www.hannestrnka.com/heat_shield.htm It shore is purdy though :0 look at his CF ducts: http://www.hannestrnka.com/cooling_air_ducts.htm Quote Link to comment Share on other sites More sharing options...
Aaron Posted April 30, 2003 Author Share Posted April 30, 2003 http://www.scudc.scu.edu/spec/mcad/analysis/MIL-HDBK-17-2E.pdf 451 pages of composite materials tests. Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 8, 2003 Author Share Posted May 8, 2003 AS&S sells "Promoted Derakane" basically it's resin premixed with promoters, the only thing you have to add is catalyst. How much catalyst is hard to find out. I started with 80g of Derakane 411-350PA, and added 2grams of catalyst, to make a tiny flat layup for testing. resin was originally at 85F Note: all temp readings done with an infared noncontact thermometer. My garage was around 90F, humidity was about normal for Houston. My first impression was "wow, this stuff wets out SO much easier than aeropoxy" My next was "Hmmn, the cup temperature is 110F.. I should hurry up." 30 seconds later the cup was at 140F and had solidified. Total working time was about 10-15 minutes. A few minutes later the cup reached 270F, and eventually it peaked at 280F. Lesson learned-it takes VERY little catalyst to work with Derakane PA. Tonight I'm going to test at 1g catalyst /100g resin too see what kind of working time I can get. My eventual goal is to have several test strips made of 6 layers of BID. I'll post cure them to different degrees to see which ones can retain shape under a fixed load at 300F. This would make a great science fair project for anyone with high school kids... Quote Link to comment Share on other sites More sharing options...
LargePrime Posted May 13, 2003 Share Posted May 13, 2003 dust; You might try ceramic coatings on your exhaust manifold and turbo housing. fellows tell me they keep the heat in the turbo and exhaust. Wraps are good too, but a caution. they retain moisture and have been known to rust out parts. If used with a ceramic coating then you got less rust worry. They also have a tendancy to fall off eventualy. I would guess thats bad for the prop. But i only seen/heard about atuomotive use. perhaps there are aircraft ones that are tuffer, or make it an inspection issue. Quote We know who you are... Link to comment Share on other sites More sharing options...
