A Bruce Hughes Posted October 14, 2021 Share Posted October 14, 2021 We flew the Longeze for 45 hours, then started improving it; the biggest improvement would be wheel pants but I don't like the only plans that I have been able to find; I think the metal sheet for parts is much too heavy and I am not good at cutting heavy steel. But I do want the attachment to be strong enough. I already have the actual round covers for the wheels and the attachment part to hold it to the wheel axle; I just need parts to hold the pants to the gear legs. Does anyone sell parts ? Please help. Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted October 18, 2021 Share Posted October 18, 2021 Google Images for Wheel Pants Attach or variations on that. You will see many pics. There are a dozen ways to do it but you have to decide what works best for you. I use a wheel nut from Vans and a lengthwise bent strip of 4130 on the inside that accepts two bolts through the two halves of the pant. I put patches of kevlar where the bolts go through. My pants separate front and back. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
A Bruce Hughes Posted October 18, 2021 Author Share Posted October 18, 2021 Thank you VERY much for that mail, Kent. I also have wheel pants that are an inside and an outside. I just have never had the time to work with them. I already have the pair of nuts that go into the axles; got those from Van's 2 or 3 years ago. I have a friend with a good machine shop and have some very heavy 4130. It seems too heavy so I may have to order a lighter piece. I know where to get any thickness and will measure my piece today. Just need correct plans and time. Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted October 18, 2021 Share Posted October 18, 2021 1 hour ago, A Bruce Hughes said: I have a friend with a good machine shop and have some very heavy 4130. It seems too heavy so I may have to order a lighter piece. .050" 4130 works pretty well. Make a pattern for the piece from posterboard or flashing. Drill the wheel pant holes to match the 4130 piece. A strong light on the inside of the pant will show where to drill. I have also seen a small laser sitting on a sandbag off to the side that points to the 4130 hole, then position the wheel pant and drill at the laser spot. Pants are very fiddly to install. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
A Bruce Hughes Posted October 19, 2021 Author Share Posted October 19, 2021 Hi Kent Thank you very much. I can get the right thickness 4130. But why not use aluminum ? I think that would be lighter. Is there some real advantage to 4130 ? I also have a sheet of an alloy of Titanium but no idea of the, type of alloy, the strength (it is thin), and no tools to work Ti. I kinda need a plan but I guess that is obvious. Quote Link to comment Share on other sites More sharing options...
