Evan Posted October 14, 2020 Posted October 14, 2020 Does anyone have a cad file for the panel dimensions on a cozy IV Quote
Evan Posted October 15, 2020 Author Posted October 15, 2020 Will I was wondering you I cold get a copy sent it would be really helpful Quote
macleodm3 Posted October 16, 2020 Posted October 16, 2020 This CAD file has all the bulkheads... C4TMP.dwg Quote Andrew Anunson I work underground and I play in the sky... no problem
Evan Posted October 17, 2020 Author Posted October 17, 2020 That's awesome my friend has a laser cuter and needs the file to cut my panel this is a huge help Quote
macleodm3 Posted October 17, 2020 Posted October 17, 2020 Are you cutting foam for the bulkhead or metal for your final IP overlay? If an overlay, you should plot out a trial run on paper and then cut it out to check for proper fit before sending it off for cutting. Most of our IP’s can be off a little bit... plenty enough to make a difference. 1 Quote Andrew Anunson I work underground and I play in the sky... no problem
