Eccentric Posted July 22, 2009 Posted July 22, 2009 7-22-2009 My rotary Long-EZ has been flying for 10 years. 720 hours TT Zero glider time http://www.mickaircraft.com/duckt.htm Quote
TMann Posted July 22, 2009 Posted July 22, 2009 You're my hero, Perry! Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done
longez360 Posted July 22, 2009 Posted July 22, 2009 Congrulations Perry. Great to see a designer implement a successful powerplant alternative. Gary Spencer must be another who's close with his V8 installation? Quote Cheers, Wayne Blackler IO-360 Long EZ VH-WEZ (N360WZ) Melbourne, AUSTRALIA http://v2.ez.org/feature/F0411-1/F0411-1.htm
goatherder Posted July 22, 2009 Posted July 22, 2009 V8 ???? in a Long EZ ??? Where can I see some pictures of this one? Quote Marc Oppelt Olympia, WA http://picasaweb.google.com/oh.u8it2
TMann Posted July 22, 2009 Posted July 22, 2009 V8 ???? in a Long EZ ??? Where can I see some pictures of this one?The aluminum block, Buick V-8 was the powerplant that the original eRacer was designed around. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done
Eccentric Posted July 22, 2009 Author Posted July 22, 2009 The aluminum block, Buick V-8 was the powerplant that the original eRacer was designed around.I think Spencer's is based on a Ford engine. Direct drive. Don't remember the details on the Buick eRacer except he had a lot of issues. Quote
Jack Morrison Posted July 22, 2009 Posted July 22, 2009 I think Spencer's is based on a Ford engine. Direct drive. Don't remember the details on the Buick eRacer except he had a lot of issues.Sencer's Ford is a 351 cu in direct drive V8. Shirls aluminum buick V8 had to the best of my knowlege 750 hrs on the engine. the only mechanical problems were a broken rocker and a rod, neither contributed to a glider situation. That being said, he had a cowl fire because of the exhaust exiting the side of the cowl and almost lost the AC. Jack Quote
Bruce Posted July 23, 2009 Posted July 23, 2009 Sencer's Ford is a 351 cu in direct drive V8. Shirls aluminum buick V8 had to the best of my knowlege 750 hrs on the engine. the only mechanical problems were a broken rocker and a rod, neither contributed to a glider situation. That being said, he had a cowl fire because of the exhaust exiting the side of the cowl and almost lost the AC. Jack Good thing he had the forward titling canopy. He also had a female passenger with him. Was it Jeanna Yeager? Quote Best regards, Bruce Sturgill http://www.pursuitofflight.com
TMann Posted July 24, 2009 Posted July 24, 2009 Perry ..... what prop are you turning now. In looking on your site it appears you have gone to an adjustable pitch. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done
Eccentric Posted July 24, 2009 Author Posted July 24, 2009 Perry ..... what prop are you turning now. In looking on your site it appears you have gone to an adjustable pitch. I'm still using the fixed pitch. The Vari-Prop is a true variable pitch prop with it's own hydraulic control system independent of the engine. That makes it good for use with the rotary engine. I did a couple test flights over a year ago. It weighs over 50 lbs. so I'm currently waiting for a lighter hub they are building for me. Quote
Jack Morrison Posted July 25, 2009 Posted July 25, 2009 Good thing he had the forward titling canopy. He also had a female passenger with him. Was it Jeanna Yeager? Your absolutely correct Bruce. Shirl was in a air race at the time with Yeager as his passinger, very close call. Another possive for the forward hinged canopy. Jack Quote
TMann Posted July 25, 2009 Posted July 25, 2009 Shirl (The designer an pilot) was able to release the canopy latch which resulted in the canopy popping up 3-5 inches. The result was it cleared most of the smoke from the cockpit. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done
