gianmarko Posted November 17, 2008 Share Posted November 17, 2008 Hello Gentlemen some 15 years ago i was building a long-ez, but then my life took a different direction. after much travelling, i have finally settled down, and i have found out that my old long-ez project is still where i left it. i have a fuselage, left wing, both winglets, main spar, canopy, main gear leg, nose gear leg, and some more bits and pieces do you reckon the construction could be continued? all the stuff was stored in door, and is probably only very dusty. i dont remember the name, but i used a french epoxy that was quite popular in italy at the time. is there any history of longs motorized with rotax 914 or jabiru 3300? i have another airplane now, but a canard has always been my dream. thanks to all who will find the time to answer. Quote Link to comment Share on other sites More sharing options...
TMann Posted November 17, 2008 Share Posted November 17, 2008 Okay ....... break time is over. Get back to work! I sat on my plans for over 20 years. I bought them used and considered myself lucky to get them at the time. I knew I wouldn't be able to start them at that time but kept the dream alive. Get to work! You have a great start on a wonderful aircraft. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Waiter Posted November 17, 2008 Share Posted November 17, 2008 My project sat in storage for almost 5 years when I lived in Japan. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
longez360 Posted November 18, 2008 Share Posted November 18, 2008 Took me 16 years on-an-off to build mine... Add another 18 months for downdraft mods. Never give up hope! It's SO worth it. Quote Cheers, Wayne Blackler IO-360 Long EZ VH-WEZ (N360WZ) Melbourne, AUSTRALIA http://v2.ez.org/feature/F0411-1/F0411-1.htm Link to comment Share on other sites More sharing options...
steve Posted November 18, 2008 Share Posted November 18, 2008 i am moving boxes from in front of mine, and hope to move it from storage to my home shop its been almost a year. blow the dust off and get a building ! Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
gianmarko Posted November 19, 2008 Author Share Posted November 19, 2008 Thanks gentlemen. so no problem with fiberglass and foam cores after so much time sitting in a storage? i happen to have a lot of space and a big, well equipped workshop at the moment :-) with even a lathe and a small vertical mill. just need to heat it. Quote Link to comment Share on other sites More sharing options...
steve Posted November 19, 2008 Share Posted November 19, 2008 Thanks gentlemen. so no problem with fiberglass and foam cores after so much time sitting in a storage? i happen to have a lot of space and a big, well equipped workshop at the moment :-) with even a lathe and a small vertical mill. just need to heat it. just vacuum and look for oil, wax, dead stuff est est.PS. I'm going to get mine this AM but have a problem. there was no tole both at the bridge be for. how wide is it ? can i get my spar though it ? how long is my spar ? Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
sam holman Posted November 19, 2008 Share Posted November 19, 2008 Gianmarko, I went with gas radiant tube to heat a large space here in Canada. You do need ceiling hight I have 15 feet. It is heat on demand takes about 30 minutes to be epoxy warm in January. Sam Quote Link to comment Share on other sites More sharing options...
