Hercpilot Posted July 4, 2008 Share Posted July 4, 2008 For those of you who are using a blade-type transponder antenna, where are you mounting the antenna? My aircraft is setup for NACA cooling. I was wandering if the antenna would affect airflow through the scoop if I positioned the antenna just prior to start of the scoop. Justin Quote Justin http://web.me.com/hercpilot/Justins_Website/Welcome.html Link to comment Share on other sites More sharing options...
Drew Swenson Posted July 4, 2008 Share Posted July 4, 2008 Putting things in the scoop will adversely effect the cooling. I have the normal "stick with a ball" antenna mounted to an appropriately sized groundplane---and the whole thing is mounted in the nose of my Cozy (interior sidewall----completely internal----works great----nothing hanging in the breeze). If you have a long nose, it should not be a problem. Quote Link to comment Share on other sites More sharing options...
Hercpilot Posted July 4, 2008 Author Share Posted July 4, 2008 Thanks Drew! So when you say "appropriately sized" what does that mean for the ball and stick type antennas? Justin Quote Justin http://web.me.com/hercpilot/Justins_Website/Welcome.html Link to comment Share on other sites More sharing options...
TMann Posted July 4, 2008 Share Posted July 4, 2008 Thanks Drew! So when you say "appropriately sized" what does that mean for the ball and stick type antennas? Justin See page 3 of : http://www.cozybuilders.org/ref_info/RST_82704.pdf Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Hercpilot Posted July 4, 2008 Author Share Posted July 4, 2008 Thanks T Mann! Exactly what I needed! Justin Quote Justin http://web.me.com/hercpilot/Justins_Website/Welcome.html Link to comment Share on other sites More sharing options...
epicez Posted November 19, 2009 Share Posted November 19, 2009 This helped me too, however, if you put the antennae under the pilot leg rest, where do you run the cable from the top side of the exit hole (assuming under the leg) without kinking the cable? And, is there any other common places for installation/fabricate a bracket in the nose etc...? Quote Ben Winner Grand Forks, ND 503.580.3573 Link to comment Share on other sites More sharing options...
epicez Posted November 19, 2009 Share Posted November 19, 2009 Some of the confusion comes from the fact that you are supposed to orient the antenna down (I have the T.E.D., realizing now that a bolt would have sufficed) But, why the downward orientation? There are many more installation options if I can mount it horizontally. Quote Ben Winner Grand Forks, ND 503.580.3573 Link to comment Share on other sites More sharing options...
longezdave Posted November 19, 2009 Share Posted November 19, 2009 But, why the downward orientation? There are many more installation options if I can mount it horizontally. The ground based antennas, that your transponder antenna is going to communicate with, are vertically oriented. If you orient your antenna horizontally, you will loose (a ballpark of) about 20 db of signal. This will result in less range, but it will still work. I would not recommend going horizontal. Quote Dave Adams Long EZ N83DT Race 83 Link to comment Share on other sites More sharing options...
