Hercpilot 10 Posted June 5, 2008 I admit to being electrically handicapped! Hence this question. Can I use a simple potentiometer to control instrument lighting or do I need a dimmer? Quote Justin http://web.me.com/hercpilot/Justins_Website/Welcome.html Share this post Link to post Share on other sites
raiki 10 Posted June 5, 2008 A potentiometer will work however it will be quite hot, depending on current. Also, again depending on current, it will need to be quite large. A PWM type dimmer is a much better solution. Quote Adrian Smart Cozy IV #1453 Share this post Link to post Share on other sites
Waiter 20 Posted June 5, 2008 Heres a nice little circuit and description: http://www.electronics-lab.com/projects/power/026/ Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Share this post Link to post Share on other sites
argoldman 14 Posted June 5, 2008 Heres a nice little circuit and description: http://www.electronics-lab.com/projects/power/026/ Waiter Wait, Waiter---(couldn't resist) What are the possibilities of noise coming from this circuit? does the unit have to be shielded (or would that help)? Quote I Canardly contain myself! Rich Share this post Link to post Share on other sites
Waiter 20 Posted June 5, 2008 I think the unit in the diagram runs at about 80 hz. It wouldn't hurt to shield the unit in a box Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Share this post Link to post Share on other sites
Hercpilot 10 Posted June 5, 2008 Thanks again for the input fellas! As usual, you guys deliver! Quote Justin http://web.me.com/hercpilot/Justins_Website/Welcome.html Share this post Link to post Share on other sites
Hercpilot 10 Posted June 16, 2008 Waiter, Would this kit work? http://www.electronickits.com/kit/complete/motor/ck1400.htm Quote Justin http://web.me.com/hercpilot/Justins_Website/Welcome.html Share this post Link to post Share on other sites
raiki 10 Posted June 16, 2008 Yes indeed that will work, however DC motors are generally switched very rapidy. This high frequency switching may cause noise in your COM. Being that it is only 410Hz I think it will be fine. I am used to motor speed controllers in the kHz range. It's basically the same as Waiters suggested circuit (A couple of 555 timers firing a driver). Fixed Freq (astable 555), varied Duty Cycle (monostable 555). Try it, and if it is noisy swap out a few components to bring the Freq down. It's pretty simple. Another addition I would make is a switch to go full brightness (even a pot with an internal switch). That way you get 100% DC as opposed to the circuits max of 99%. Now you could have the switch power the MOSFET permanently or you could have the switch carry the lamp current, effectively 'shorting out' the dimmer. That approach would extend the life of the MOSFET, as it wouldn't be running at 100% load when not required to dim. Quote Adrian Smart Cozy IV #1453 Share this post Link to post Share on other sites
Hercpilot 10 Posted June 16, 2008 Thanks Adrian! Quote Justin http://web.me.com/hercpilot/Justins_Website/Welcome.html Share this post Link to post Share on other sites
raiki 10 Posted June 16, 2008 Here is a screen capture of that circuit in a simulator (with my added switch). Gets about 7A max on the dimmer into 100 watts of globes, and 8A with the switch closed. Controls down to about 3A so you have a brightness range of about 40% to 90% with the dimmer. You'll get 100% with the switch. With some mods you should be able to get <40% if you so require. Quote Adrian Smart Cozy IV #1453 Share this post Link to post Share on other sites
raiki 10 Posted June 16, 2008 Controls down to about 3A. Whoops made a mistake. Create the connection from R7 to Q2 emitter and it controls down to 850mA. Much better. Top end no change. Quote Adrian Smart Cozy IV #1453 Share this post Link to post Share on other sites
Hercpilot 10 Posted June 16, 2008 Adrian, Since I am no good at reading circuits, which switch did you add? Do you think the board that comes with the kit can be modified to accept your switch design? Justin Quote Justin http://web.me.com/hercpilot/Justins_Website/Welcome.html Share this post Link to post Share on other sites
raiki 10 Posted June 16, 2008 My added switch is labelled J1 in the simulator. It connects the lamps to ground in place of the MOSFET. This could be added to the circuit quite easily (even externally). Quote Adrian Smart Cozy IV #1453 Share this post Link to post Share on other sites
