ez poxy hardener
jany77
I have never used ez 83 but have built over half a plane with ez 84 I am using it mainly because it works with my pump and when I started the plane I could not get mgs. I have about 4 hours of working time with the 84 before I am working on cured fiberglass. It is pretty thick stuff and Keeping it hot in a hot box helps. I also carry a heat gun and use it on all layups to help it wet out. It is tough stuff and really hardens up when cured. It is not as pretty a layup as the clear mgs but it is more fuel resistant and I still have almost 9 gallons so I keep using the stuff. I think it is also the least exspensive of the epoxies approved for the eze aircraft. When I run out I am going to try mgs so maybe some of my parts in the end will be pretty. Here is a picture that shows what a part looks like using ez 84 nice dark brown. STeve
Posted Image
Steve Harmon
Lovin Life in Idaho
Cozy IV Plans #1466 N232CZ
Working on Chapter 19,21
hi guys what is the main difference between hardener 83 and 84 for ez poxy what i readed is just cure time ,what ez hardener are you guys using if anyone here still use ez poxy
83 makes thicker epoxy then 84. 84 is a little slower. I use 87 most of the time it is slower and is best for big layups in hot weather
By no means am I an expert on the subject of epoxies, but I've been using EZ Poxy 10 resin and 83 hardener on my Mark IV, and am very pleased with the results so far. I did a "Google" search on EZ Poxy and found numerous links with lots of information to use. I'm not sure what exact information you're looking for, but that's a good place to start. Also, go to http://www.ez.org/nonownerguide.htm Lot's of good info there as well.
Best Regards,
John D. Wages
N694CZ (reserved)
http://www.maddyhome.com/canardpages/pages/johnwages/default.htm
i just found some interesting stuff but i dont understand if the numbers means if its high better visc or low number lower visci dont get the numbers
http://www.cozybuilders.org/Oshkosh_Presentations/2006_EpoxyDoDonts.pdf
Higher viscosity (larger number) means that it's thicker - more like honey than water. Generally, the higher viscosity epoxies are for warmer temperatures, but not always.
The MGS epoxies have particularly low viscosities for laminating resins, which make is easier to wet out the glass. But a hair dryer with the EZ83/84 will do the same thing.
