jany77 Posted December 21, 2007 Share Posted December 21, 2007 i have question have i can remove the old ply from wing atch fittings ,i saved set from my project i want replace spar but save the fittings Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted December 21, 2007 Share Posted December 21, 2007 i have question have i can remove the old ply from wing atch fittings ,i saved set from my project i want replace spar but save the fittingsIn theory, yes. Quote Marc J. ZeitlinBurnside Aerospacemarc_zeitlin@alum.mit.eduwww.cozybuilders.org copyright © 2023 Link to comment Share on other sites More sharing options...
jany77 Posted December 21, 2007 Author Share Posted December 21, 2007 i know in theory but how i can remove the epoxy lay up from fittings without destroing them Quote Link to comment Share on other sites More sharing options...
TMann Posted December 21, 2007 Share Posted December 21, 2007 I think you can do it by applying heat but the downside is you will destroy the temper/hardness of the fittings. I'm not the person to advise you on this. I only point out that I believe there is a significant downside. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
jany77 Posted December 21, 2007 Author Share Posted December 21, 2007 i also readed about aplying heat about 200 f to it but what about some epoxy striper or remover ill alodine the fitings after that Quote Link to comment Share on other sites More sharing options...
