SpaceShipOne Posted August 27, 2005 Share Posted August 27, 2005 Hey! ... I'm a new comer here, studying the option to go for an Aerocanard FG. I was just wondering, in the building process, what kind of parts can be ordered already assembled? Apparently on the aerocad.com, you can get the wings / canard assembled. Thanks, Tony Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted September 12, 2005 Share Posted September 12, 2005 Tony, www.aerocad.com is your best source for information, but you should be able to get just about everything prefab. Fuselage, strakes, turtledeck, wings, and rudders? Check w/AeroCad for the details. Jon Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
SpaceShipOne Posted September 13, 2005 Author Share Posted September 13, 2005 Thanks! Well Al from Aerocad gave me all infos I needed. Really appreciated his help. Now it's time to think about the project... Tony Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted September 14, 2005 Share Posted September 14, 2005 So what did you find out from Al? What's for sale from them these days? Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
SpaceShipOne Posted September 14, 2005 Author Share Posted September 14, 2005 If we consider an AeroCanard FG, here are all assembled parts you may purchase: - FUSELAGE: Upper & Lower Half (Kits): $7950.00 Molded PVC /Vacuum bagged composite shell with Epoxy primer outer coat, pre-marked for all cutouts (TOP) Nose, Canard cover, Turtle-Back, Upper Cowling $4322.50 (BOTTOM) Lower nose $383.50, Fuselage tub with Longerons $3380.00, Lower Cowling $390.00 - FUEL/BAGGAGE STRAKES: Kits: $2372.50 2 Upper, 2 Lower, Molded PVC /Vacuum bagged composite shell with Epoxy primer outer coat - SPAR SECTIONS: Spars are match-drilled for bolt bushings $455.00 Main Wing Spar (Kits): 2 pre-molded $1592.50 Center Section Spar (Kit): pre-molded box spar $2535.00 Canard Spar (Kit): 1 pre-molded $643.50 - FOAM CORES: All foam cores are precut with level lines in place for proper alignment Wing Cores (Kits): 2 leading edge, 3 trailing edge - both wings. $1163.50 Winglet Cores (Kits): 2 uppers, 2 lowers for both wings $474.50 Canard Cores (Kits): 4 leading edge, 4 trailing edge, 2 ends $279.50 Elevators (Kits): 4 cores $58.50 And the molded fairing set ($1,892.80), landing gear options, windows, engine mounts... I was pleased to know that Aerocad has also some parts for Long-EZE and Cozy / Cozy MKIV! Cozy Approved Parts Fuselage parts: Upper nose with canard cover for the MKIV $357.50 Lower nose for the MKIV $383.50 Top and bottom cowling for the IO-360 MKIV $780.00 Turtleback for the MKIV $546.00 Nose cone with door for the MKIV $97.50 Molded Strakes shells for the MKIV $2,372.50 Molded Arm rest front and back for the MKIV $237.90 Molded Arm rest front and back for the Cozy $237.90 Molded Thigh Supports for the MKIV $231.40 Molded Thigh Supports for the Cozy $231.40 Molded Nose wheel cover for the MKIV $55.90 Molded Map pockets for the MKIV $55.90 Molded Map pockets for the Cozy $55.90 Molded fresh air NACA inlets for the MKIV $28.60 Molded fresh air NACA inlets for the Cozy $28.60 Molded center section spar for the MKIV $2,535.00 Molded Main Gear fairings for the MKIV $87.10 Airfoil parts: R1145MS Canard Spar for the MKIV $643.50 R1145MS Canard cores for the MKIV $279.50 R1145MS Canard elevator cores for the MKIV $58.50 Wing cores for the MKIV less spar area $1,163.50 Winglet cores for the MKIV less spar area $474.50 Wing cores for the Cozy less spar area $1,163.50 Winglet cores for the Cozy less spar area $474.50 Molded upper skin R1145MS canard for the MKIV $2,529.80 Molded R1145MS canard tips for the MKIV $58.50 Skinned wings for the MKIV $5,453.50 Skinned wings for the Cozy $5,453.50 *Complete wings and Canard with ailerons, rudders and elevators in primmer $19,479.20 Molded wing spars for the MKIV $1,592.50 Molded wing spars for the Cozy $1,592.50 Looks like an extensive list of molded materials which can help to save time. While I'm looking at all options (Aerocanard, Cozy MKIV...), I'm still in the fog and I really don't know which route I should take. Basically my project was defined as a Long-EZE project: I was looking for a canard based on the Lyc. O 235 engine... I found a set of plans which should arrive at home soon. I like the way the LE is! But I'm aware that most of the LE builders are flying rather than building so it doesn't help to take a decision ! Good luck Jon with your project anyway Tony Quote Link to comment Share on other sites More sharing options...
Jerry Schneider Posted September 14, 2005 Share Posted September 14, 2005 Preamble: I'm building a Cozy MKIV using the AeroCanard upper firewall profile. I just HAD to have more headroom in the back seat. Friendly caveat to AeroCanard Shoppers: Make sure you DO NOT use the prices you see on the AeroCad website. They are woefully out of date. They will gladly send you an updated price list. Example: Upper/Lower Cowling (Website) $350 Upper/Lower Cowling (Actual) $455 PLUS $100 shipping est. Hopefully, the shipping will come in a little less. I just ordered the upper cowling and learned the hard way Al Aldrich (Owner) says he'll have it to me in 30 days. (Tick Tick Tick...) I'll post an update regarding quality/timeliness when the product is delivered. I've bought other stuff when Jeff Russell was producing, so, I have a pretty good idea of the baseline. I hope things work well, as I really like the AeroCanard and would like to see it succeed. Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
SpaceShipOne Posted September 16, 2005 Author Share Posted September 16, 2005 Yes Jerry keep us informed once you've got the product... Good to know if it's worth it to spend $$$ on parts in order to save time! Quote Link to comment Share on other sites More sharing options...
