rnbraud Posted August 8, 2005 Share Posted August 8, 2005 Hello all, I am in the final stages of selecting either the Cozy Mk IV or the Aerocanard. I plan to do a plans build version with only a few pre-maid parts: landing gear and canopy. I was wondering if I choose AeroCad plans, can I use the same building material bundles that Aircraft Spruce and Wicks offer for the Cozy? Thanks. Quote Link to comment Share on other sites More sharing options...
Jerry Schneider Posted August 8, 2005 Share Posted August 8, 2005 I was wondering if I choose AeroCad plans, can I use the same building material bundles that Aircraft Spruce and Wicks offer for the Cozy? Thanks. I would say yes. You may want to check w/ Jeff Russel via AeroCad just to be sure. Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Jon Matcho Posted August 8, 2005 Share Posted August 8, 2005 Definitely 'yes'. The plans-built AeroCanard plans are 99.9% identical to the Cozy Mark IV plans and use the same materials. Buy whatever you like from Aircraft Spruce or Wicks. The kit-built AeroCanard plans are the ones that call for the use of different materials (triax glass for example). Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
rnbraud Posted August 8, 2005 Author Share Posted August 8, 2005 Great, I was hoping that was the case. Now on to the Big Decision! Thanks again. Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted August 9, 2005 Share Posted August 9, 2005 I was wondering if I choose AeroCad plans, can I use the same building material bundles that Aircraft Spruce and Wicks offer for the Cozy? Definitely 'yes'. The plans-built AeroCanard plans are 99.9% identical to the Cozy Mark IV plans and use the same materials.Well, Carlos Fernandez, another AeroCanard plans-builder, pointed out to me that the one part where you'll need additional material is with the firewall. The 2' x 4' sheet is good enough (barely) for the Cozy Mark IV, but you need another 40" x ~4" strip added for the height the AeroCanard FG adds to the rear. I haven't made my permanent firewall yet -- my temporary sheet from Home Depot works just fine so far . Outside of that, you should be able to squeak by without needing extra material, but you'll find out when that happens, and you'll be a pro by then. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Jon Matcho Posted August 10, 2005 Share Posted August 10, 2005 ...you need another 40" x ~4" strip added for the height the AeroCanard FG adds to the rear.Actually, Carlos suggested to me that the top of the firewall is the only spot where you need the extra material and that you DO have enough material to glass on the extra curve. This amounts to something close to a 18" x 3.5" piece of plywood to support the turtleback and engine cowling. So back to the original question... to build the plans-built AeroCanard FG/SB you need to buy the same exact materials as you do for the plans-built Cozy Mark IV. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
