KB2QQM Posted February 11, 2005 Share Posted February 11, 2005 I find it sort of funny that the nose gear section...is section 13.... (rub the rabbits foot) I am seeking info on the nose gear...as I have not yet bought plans and have been reading the NTSB files on the Cozy aircraft, for prebuilding questions. There are numerous references to gear up/nose down landings. How can you tell if the nose gear is down and locked, is there a light? or a cockpit indication of gear down...? Greg Quote Link to comment Share on other sites More sharing options...
Jerry Schneider Posted February 11, 2005 Share Posted February 11, 2005 How can you tell if the nose gear is down and locked, is there a light? or a cockpit indication of gear down...? Greg The plans call for a little window in the wheel well which you can look thru and see if the gear is up or not. Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Jon Matcho Posted February 11, 2005 Share Posted February 11, 2005 How can you tell if the nose gear is down and locked, is there a light? or a cockpit indication of gear down...?There's a view hole in the wheel well for you to see that the wheel/gear is not there (down). Some builders have put in warning lights and audible alarms as well. For more information, try searching through this forum. Here's a link to a gear-up incident: http://www.canardzone.com/forum/showthread.php?t=448 Also, try searching at this link: http://www.maddyhome.com/cozysrch/index.jsp, which searches messages exchanged as part of the mailing list available at www.cozybuilders.org Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Waiter Posted February 11, 2005 Share Posted February 11, 2005 Here we go again! Put in the loudest, most obnotious horn you can find. Install a switch on the throttle so it activates whenever the throttle is at idle. Wire another switch so it opens only when the nose gear is down, locked, and overcenter. Now wire these switches into the LOUD horn. The horn will go off whenever the throttle is at idle, and the gear is not down and locked. A light is not enough, and small buzzer is not enough. You'll be looking at the light, kind of wondering why its on, just as the nose settles to the runway, and skids to a stop. (been there, done that, got a "T" shirt) The sound of the horn must override everything else, I could be on fire, or have a passanger screaming and puking, but when that horn goes off, It gets my immediate attention. Oh yah, Did I mention that the horn needs to be VERY LOUD. If you do not install this type of warning system, I am so convinced that you'll do a gear up within the first 1000 hours, I'll put $100 on it. Ok, All those that "HAVE" send me my money. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
