From THE CANARD PUSHER NO. 30 Oct 81
The transponder antenna can be mounted under the front seat thigh
support, and this is where quite a lot of builders have located it,
however, Jim Weir of Radio Systems Technology has cautioned that it may
be possible that high powered microwave energy may be radiating in very
close proximity to a rather sensitive part of the pilots anatomy. To
put it bluntly, it may be a little like sticking your fanny into a
microwave oven! In any event, no qualified person to our knowledge has
tested this, so it may be prudent to laminate a sheet of aluminum foil
under the thigh support. Microwave energy will not penetrate the
thinnest of metallic foils.
I think I remember a thread about this but can't find it. Where do you put the tspr antenna? Is there a problem with including Al foil under the paint?
Mark Spedding - Spodman
Darraweit Guim - Australia
Cozy IV #1331 -  Chapter 09
www.mykitlog.com/Spodman
Even Jim Weir has long since decided (after some analysis) that this is an old wive's tale at best, and there is NO evidence that normal transponder energies can be dangerous.
My antenna is up in the nose in front of the rudder pedals, facing downward. Works great. I used 1/32" aluminum as the ground plane.
Marc J. Zeitlin
Burnside Aerospace
[email protected]
www.cozybuilders.org
copyright © 2025
Fairy Nuff. Sorry to be spreading old wive's tails...
While I didn't find anything relevant in a search the "similar posts" thingie down below did. Shame it doesn't appear until I've asked a question for the nth time :cool:
  • 1 year later...
Reminds me of the "turn your cell phones off at gas pumps. It can cause explosions!" dribble... There's a reason why (in places that have caught up) they removed the catch that allows hands-free pumping of gas into yuor car - so you have to pump it, without being able to slide back into the car while it's pumping and cause static discharge. . .
I have a Bill Butters, all internal XPDR antenna in my strake and it works extremely well. Don't be misled by avionics companies, and foam core dielectrics. The antenna does not need to be in the free airstream. This system works very well.
Cheers,
Wayne Blackler
IO-360 Long EZ
VH-WEZ (N360WZ)
Melbourne, AUSTRALIA
Reminds me of the "turn your cell phones off at gas pumps. It can cause explosions!" dribble... There's a reason why (in places that have caught up) they removed the catch that allows hands-free pumping of gas into your car - so you have to pump it, without being able to slide back into the car while it's pumping and cause static discharge. . .
Cheers,
Wayne Blackler
IO-360 Long EZ
VH-WEZ (N360WZ)
The transponder antenna will need a ground plane at its base (the top-- the antenna faces down) this must be approximately 6" in diameter. (not sure of the exact minimum diameter). A suggestion would be to extend it so that your buns or other appendages are shielded by it from the tip of the antenna.
This may alleviate the problem of well done meat.:scared:
I Canardly contain myself!
Rich :D
