dust Posted March 19, 2003 Share Posted March 19, 2003 Can you burn jet fuel?? or avgas?? You know john, get all of the bugs worked out and fly it for a while and then when I build a hunting and fishing plane, I'll put one in, but really, what about the gas? Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
Rui Posted March 19, 2003 Share Posted March 19, 2003 Avgas is OK as long as you get rid of the oxygen sensor. Tracy Crook's EFI system does not depend on the O2 sensor, so if you go that route there is no problem with either avgas or mogas. Jet fuel, I don't think so, but if there were a diesel rotary..... Quote Rui Lopes Cozy MkIV S/N: 1121 Link to comment Share on other sites More sharing options...
John Slade Posted March 20, 2003 Share Posted March 20, 2003 Fuel will be regular gas with 125:1 mix of 2 stroke oil. You need the oil because lubrication of the seals in the car is done with engine oil from the sump squirted by a small pump. [poets - have at it]. This causes a coke build up in the engine. Most 13B racers and flyers remove the pump and use 2 stroke oil mixed with the gas. >when I build a hunting and fishing plane You're going to build a plane that can hunt and fish? Cool. How's it gonna work? A really long sharp pitot head, perhaps? Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
marbleturtle Posted March 20, 2003 Share Posted March 20, 2003 ... french wine! Quote This ain't rocket surgery! Link to comment Share on other sites More sharing options...
dust Posted March 21, 2003 Author Share Posted March 21, 2003 John, you know i couldn't use a pitot for hunting and fishing, the salmon would throw off the cg, let alone a moose. I'll just attach a drag line at the cg and snag them up. Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
dust Posted March 21, 2003 Author Share Posted March 21, 2003 is that regular gas from the airport or the corner? Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
John Slade Posted March 21, 2003 Share Posted March 21, 2003 Mount the pitot under the belly. Regular gas from the corner gas station pumped into my saab, then pumped into the plane via a switched pump and pipe in the trunk when I get to the airport. I can carry about 23 gals per trip. When travelling I'll take whatever gas I can get at the airport. Avgas works fine, apparantly. Just costs more. I gather that someone is working on a diesel rotary, but I've got enough problems trying to figure out an intake system as it is. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
dust Posted March 21, 2003 Author Share Posted March 21, 2003 I don't want that high preasure air piped through the cabin and the angle of attack too critical, not enough elevator to pull up larger game, thirty foot drag line is safer or maybe cozy on floats, i wonder if i could call it a cozy then, have to ask nat. I was just wonderin about the lead and the rotary, not being a smart a, didn't suggest brake and turn signal lights, again. Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
Rui Posted March 21, 2003 Share Posted March 21, 2003 John, Do you really plan on using your car as a gas carrier!!??! About a month or so ago there was a thread on the homebuilt usenet group about a guy using an old beater pickup as a gas carrier. Appearantly he was inspired by a story by Jim Wier in KitPlanes(I haven't seen it) where he describes how to add a tank to a trailer and use it as a dedicated fuel carrier. Seems like this would be more practical as you wouldn't have to make 3 trips to fill your plane!!! Quote Rui Lopes Cozy MkIV S/N: 1121 Link to comment Share on other sites More sharing options...
Aaron Posted March 21, 2003 Share Posted March 21, 2003 Originally posted by dust I was just wonderin about the lead and the rotary. Lead's only a problem if you have a catalytic converter or an oxygen sensor. Since we don't need an emissions inspection, and Tracy's EFI doesn't use an oxygen sensor, no worries. I'd imagine that lead actually makes rotaries more reliable (less housing wear) but then I'd be imagining things again Quote Link to comment Share on other sites More sharing options...
marbleturtle Posted March 21, 2003 Share Posted March 21, 2003 > [poets - have at it] Oh... I think I have a new T-shirt idea!... nope... lost it. Quote This ain't rocket surgery! Link to comment Share on other sites More sharing options...
John Slade Posted March 21, 2003 Share Posted March 21, 2003 >Do you really plan on using your car as a gas carrier!!??! Sure. I'll pump a few gals every time I drive over to the airport. This should be more than enough for my local flying. A car tankful should give me about 3 hours flying. Much more convienient than lugging a trailer around. My big problem will be running out of gas in the car on the way home Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Aaron Posted March 23, 2003 Share Posted March 23, 2003 you could always add a removable fuel cell to you car. Build it from fiberglass, shape it like the inside of your trunk. when you're not flying, store it empty in your garage. That way you could always be sure to have full tanks. If I were to use your system, then I know I'd forget to fill up the car on the way to the airport. Quote Link to comment Share on other sites More sharing options...
John Slade Posted March 23, 2003 Share Posted March 23, 2003 The point of my "pump from the car" idea is that it's simple. Nothing to make, nothing to install (except one pipe), nothing to hook up and tow. All I have to do is stop at the gas station and fill the car on the way to the airport. If I forget, it'll take 5 minutes to head out, fill up and return. Let's say the average local flight is 1.5 hrs. That's about 10 - 12 gals. So, If I pump this much each time I go down, or 20 gals every other time, then the plane will stay full. Make sense? Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Aaron Posted March 23, 2003 Share Posted March 23, 2003 Makes sense to me. Quote Link to comment Share on other sites More sharing options...
Rui Posted March 24, 2003 Share Posted March 24, 2003 It makes sense, just never thought of it and sounded weird to me. Don't think it would work for me though, I drive a Civic and it only has about a 50L tank (13-14 US gallons). So are you going to install a pump and pipe into your car, or will you just stick a hose into the tank and pump it out with an external pump? Quote Rui Lopes Cozy MkIV S/N: 1121 Link to comment Share on other sites More sharing options...
John Slade Posted March 24, 2003 Share Posted March 24, 2003 I haven't looked yet, but I think there's a pump in the tank, so all I'll need to do is intercept the fuel pipe, add a valve and turn the ignition on. If not, then I'll install a pump in the trunk (boot). Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
JakeC Posted March 24, 2003 Share Posted March 24, 2003 --Today in the news-- Local motorists were stunned today at the bizarre line of fire leading from the local airport to the home of an eccentric local who neighbors say have been building a "backwards" airplane in his garage for the past several years. When asked about the strange phenomenon, the man simpy waved the smoking end of a fire exingusher at our channel 11 reporters then got in his car and raced twords the direction of the airport" Before he left he was heard mumbling "God I hope this doesn’t get back to them sarcastic **&^^%$# on the CC." - More at 11. . But seriously, I think it sounds like a great idea. I'm hoping that by the time I ever get around to completing an aircraft, Auto gas will be on every airport. Actually by the time I get around to finishing an aircraft, you will probably be pulling up to the charging station instead of the fuel pump . Jake p.s. Will you be putting some kind of inline filter in the system or will you be tapping into the line after the cars fuel filter? Quote www.homebuiltairplanes.com Link to comment Share on other sites More sharing options...
John Slade Posted March 24, 2003 Share Posted March 24, 2003 :D Very good, Jake. Sounds just like me, apart from the bit about it getting back to the CC. If you've seen my web site you know better. I'd announce the event proudly, complete with pictures and links to the TV station archive. I don't think the car would start with fuel pumping from the transfer pipe, and I don't think I'm THAT forgetful, but maybe a warning light on the dash would be a good idea. Damn. I was trying to keep this simple. I think the filter is right by the pump on most autos. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Rui Posted March 24, 2003 Share Posted March 24, 2003 Is the pump you are referring to the EFI pump? Do you think it will put out enough fule to make refueling tolerable. I think I remember you saying that it takes 30 minutes to tranfer fuel from one tank to another on your plane. If thats true then thats the amount time you'll be waiting for the EFI pump in the car to do the same thing... Quote Rui Lopes Cozy MkIV S/N: 1121 Link to comment Share on other sites More sharing options...
John Slade Posted March 24, 2003 Share Posted March 24, 2003 Yes, the car's EFI pump, and yes - it'll probably take 20 - 30 minutes to pump a whole tank. If this becomes a pain I'll install a faster pump. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
No4 Posted March 24, 2003 Share Posted March 24, 2003 My friend pulled up next to me in his old Bedford safari truck at a campsite in Namibia. "Coming for a beer I asked?" "I'll just fill up the running tank", he said. Came back at 1 am full as a boot to find all our kit sitting in 1000 litres of diesel. Quote The Coconut King Link to comment Share on other sites More sharing options...
