zolotiyeruki
381 -
12
Posts posted by zolotiyeruki
On Barnstormers:
QuoteCOZY MK IV • $60,000 • WOW! • Located in Groton CT (KGON) Low hours, well built and ready to take you where you want to go! - 125 hours on the engine and airframe - Well documented, and with a fresh annual - Up to date on all ADs and SBs - Lycoming O360-A1A with an Ellison Throttle Body - Catto 3 blade propeller - Electric nose lift - Garmin 430 / SL30 panel and vacuum gauges - EIS4000 engine monitor - Autopilot - IFR capable You can fly commercially into PVD or BDL, them head down to GON to check her out and go for a flight. Blue skies!!! • Contact Brendan Woolrich , Owner - located Groton, CT United States • Telephone: 8600000000 • Posted June 18, 2021 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Images
Quote
1989 VELOCITY SE,1300T,800SMOH • $107,000 • ACCEPTING OFFERS • Factory built by the founder of Velocity Aircraft, Danny Maher (DM100) and completely refurbish in 2018 by experienced A&P/IA. New Cirrus paint scheme, New Garmin G3X panel from Stein Air, New interior, New electrical system (New wires,switches and CB's), New Cato 3 bladed prop. Garmin equipment includes, G3X, GNT 625 GPS (GPS is IFR certified to LPV mins), Two GTR-20 comm radios (one remote, one panel), GMA-245 audio panel with blue tooth, GTX-45R Transponder with ADSB in and out, G-5 backup horizon,Garmin Auto Pilot. Cruises at 150 Kt/8.3 Gph avgas. Owner is a CFI and can provide checkout. • Contact James Sielis , Owner - located Spencer, MA United States • Telephone: 774-701-0026 • Posted June 14, 2021 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Images
This one does not have pictures:
QuoteVELOCITY SE FG PROJECT • $35,000 • CHECK THIS OUT • Velocity SEFG fast wing gull wing doors elite windows Airframe 95% complete almost ready for primer • Contact Jamie Hicks , Owner - located Cincinnati, OH United States • Telephone: 432-349-7577 • Posted June 9, 2021 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad
Quote
QUICKIE TRI-Q200 • FOR SALE • Quickie Tri-Q200 minus engine, currently registered with 524 hours in logs TTSN. LS1 canard, Velocity nose gear, streamlined wheel pants. Disassembled to improve aerodynamics on glass, body work done by pro car restoration shop. Forward sliding canopy, Patillo cowl inlets. Some minor fiberglass work then re-assembly, mount engine and go flying. Could be flying this summer. Have lots of parts, some extras. No damage history. $8500 OBO • Contact Cj Cj , Owner - located Cave Junction, OR United States • Telephone: 541-592-9045 • Posted June 8, 2021 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Images
I haven't seen this one posted, and apologize if it's already shown up:
https://barnstormers.com/classified-1556145-Long-Eze-unfinished-Project.html
QuoteLONG EZE UNFINISHED PROJECT • FOR SALE BY BUILDER • Structural sections built by an A&P. No engine/instruments. text to phone only. KFXE • Contact Gary Hall , Owner - located N. Lauderdale, FL United States • Telephone: 954-979-9494 • Posted June 6, 2021 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad
A Rotax 915 might be a better option, with 150-ish horsepower. With a pusher, you have to be careful of prop strikes if you move the engine further from the firewall, as Kent mentioned. Tractor aircraft don't get off easy, either--you have to account for the impact of a longer nose on the aerodynamic stability of your airplane, too. It's probably better to try and manage the cg with a lighter engine by moving avionics and such aft as much as possible.
- 1
(disclaimer: I'm not a pilot nor a builder.....yet. That said, I've been doing a lot of research)
With regards to range and fuel efficiency, here are a few thoughts:
1) In general, lower speed = longer range at the expense of time. According to cozyaircraft.com, running at 40% power and 185MPH instead of 75% power and 220MPH will net you a whopping 30% increase in range (from 1,000 miles to 1,300), assuming no head or tail winds
2) In general, higher altitude = higher speed, at the expense of oxygen, cold temperatures, and reduced engine power (unless turbocharged)
3) Turbines are thirsty, thirsty engines. Fast, sure, but very, very thirsty. In a plane the size of a Cozy, you want piston power.
4) Aircraft diesel engines are promising, but also very, very expensive at this time. ac-aero has their Falcon FL200 that's supposedly 75KG and 210(!) HP, but its BFSC of >.39 will probably erase all the range advantages of a diesel. Continental has a whole lineup of diesel engines, but again, $$$$, and they're heavy.
5) Further on the diesel engines, the CD-300 weighs a whopping 550 lbs dry, and would push your empty weight to 1300lbs. That leaves you only 340kg for passengers, bags, and fuel. The stock fuel tanks hold 150kg. If you, your passenger, and your bags consume another 170kg, you'll end up with only 20kg of extra fuel before you hit Max Gross. Fast is nice, but you pay for it three times: first when you buy the engine, second when you can't carry as much fuel because of the engine weight, and third with the higher fuel consumption to go faster. -
All these projects make me envious, wishing I had time to pick one up. If you don't mind me asking, how much did you pay for it?
If/when the day comes that I get to build my own airplane, a rotisserie like that is DEFINITELY in the plans. I can imagine there are a LOT of layups that would be a lot easier that way.
On 3/14/2021 at 6:59 PM, fjk said:
Hey,
Last two (I think both...) Oshkosh Ion was there and were trying to get a buyer for the project. It is a great solution as you remark except that I was really saddened that they aimed it at the "it's easy to fly crowd" which to me is a euphemism for dumbed down. I understand the necessity (market) but stall speed around 85MPH is no a deal breaker for me...
Otherwise it was a really nice ride (probably) as they guy said their focus was on the view - right where I live.
Wow, that's a pretty high stall speed for a conventional layout. Any idea how much they were looking to get in a buyout?
Yeah, I'd love to have a fast airplane with the engine and wings behind me, but there aren't many of those. The closest I've found is Ion Aircraft, and 1) the company is getting sold off (they couldn't get into production) and 2) I don't know how fast it actually goes (there's not much detail on the site).
Wow, that's pretty definitive. Too bad he never published plans for the boomerang
Does that extend to the plans themselves (i.e. the contents of the TERF CD)?
I sent him a DM several days ago, and haven't received a response. I'm new around here, so I thought he might just be ignoring the new guy, but he hasn't read it. He last posted in December, and his profile says he last visited the forums two days ago. His phone number is listed in his profile--have you tried calling him?
Sales I've seen
in For Sale (or for Free)
There's also this Dragonfly posted a week ago:
The photos don't include the wings for some reason
