Barry
127 -
4
Posts posted by Barry
Darn, I thought I might get into a canard magnet supply business.
Kent,
Could you add a magnet at each corner and a metal plate at each corner of the brake? Just enough to latch in place.
"Yikes! $454 for a single CHT bayonet probe! "
Wow. Talk about excessive. I suppose $150 would be fair since it is nicely made and replaces other parts, and is certified. I wonder how much of the $300 excess is the certification process?
"I'm hoping to get back to layups on my Cozy in December..."
Had to read that a 2nd time before remembering you're "down under"
On 10/28/2019 at 9:52 PM, Richard said:
I am building a Berkut without the kit. The fuselage will be carbon triax and made from a one-off CNC foam mold.
$4224.00 for the complete Berkut package with jigs.
More details if you can. Sounds interesting.
"could a 6' 4" person fit in the back? "
For the Long EZE, yes. See my comment here:
https://www.canardzone.com/forums/topic/32064-long-ez-fit-for-taller-people/
"Both were about 6°."
That is pretty far off. Do you see the reason for such a small total?
Looks like a nice project. I'm jealous.
That makes sense.
3 hours ago, Voidhawk9 said:
Cozy, I am pretty sure.
I'm thinking I have read that the Cozy and Long wings are the same. Somebody here knows...
OK, found a pic that's just fine, right on Kent's build thread, page 1. Scroll down and you'll see the access to the pedal assembly through the nose. That thread of Kent's is a treasure trove...
RSD, most canards including the Long EZ and Cozy have access to the pedals through a removable cover on the nose. I think it should be relatively simple to adjust the pedals. However, I have not built or owned either so I could be remembering it wrong. I seem to recall a picture of my feet in Kent Ashton's Long showing the pedal assembly taken through the nose panel, but I cannot find it at the moment.
RSD, let us know why you think you need in flight adjustment...
I do know that when I sat in Kent's Long, the pedals were not quite adjusted for my size (6'4"), but I also learned it would be darned comfortable to fly since even if they were properly adjusted, when flying along I could easily stretch out past the pedals Vs say a Cessna 172 or the like.
Hi Jon,
I think you're right with respect to the Raptor. An aircraft engine should have been used initially. OTOH, I do like the diesel, but not a high RPM diesel requiring reduction. Developing it on a new airframe is crazy.
I was just responding to the question, was one that I remembered. The whole deal is pretty neat, but I'm not expecting it to be a success. You guys all know the score better than I do.
Barry
I don't recall seeing any that are adjustable in flight, but there may be an existing design somewhere.
Some of the infinitely adjustable (within a range) have the actuator cable anchored and sliding through the actuator pedal assembly, moving the pedal linearly for adjustment. I suppose those could be made in flight adjustable in some fashion. It would need to be rather robust and add weight.
Kent had a simple version, click the link, it's the first item on page 8.
Raptor
http://www.raptor-aircraft.com/contact.html
Update, airworthiness certificate was approved Tuesday.
Kent,
Hope your vacationing somewhere and that everything is OK. Haven't seen any posts from you for awhile. Maybe I just missed one.
Barry
Update - I heard from Kent and he is fine. Just vacationing from the site.
Not sure why the whole thing got re-commented, but it works
- 2
Ronnenberg did work on the Voyager project with Dick and he had built multiple Long EZ's. But I understand Burt had nothing to do with the Berkut.
I go back to this "Not being an aerodynamics guy". Quite a few non engineers have built a nice airplane following the plans. And some darn smart people have built and followed the plans precisely. There is a reason for this.
I have not built an airplane, likely never will as I'm just going to run out of time
But I have studied the plans and dream.
Anyway, I hope you get to build a Long EZ to plans or modified.
- 1
"The Long Ez was designed 40 years ago by Burt..."
Yes. I will just note that in that entire time, no one has successfully deviated much from the Rutan design. Those that have worked off of the Rutan design have been fair composite/aero engineers and often worked with Rutan to make the changes.
I have used glass and carbon and I'm building new bodywork for my formula race car now, all carbon. A composite engineer I am not. All the properties of carbon are not always good when used as a direct replacement for something designed in glass. This is the point I would make. Burt designed in glass and moldless. Taking the same design and trying to replace the glass with carbon is not something to be done by the seat of your pants. One, you'll likely never finish, two - which is probably for the best since you'll more likely than not cause yourself harm.
Put it another way, if you are not capable of designing a canard in carbon from a clean sheet of paper, your are not qualified to substantially modify a Long EZ. if you have that skill level then go for it.
"Not being an aerodynamics guy..."
I'm just guessing, you're not a composites engineer either. There are many reasons to stick to the plans created by one of the finest aerodynamic and composites engineers ever to
walkfly this earth. Primarily, so as not to kill yourself or a friend, and two - that you might finish your project.- 1
Says he lowered the gear and taxied off, so I guess it didn't collapse, just forgot to put it down.
Fantastic! Good job.
- 1
Kent's Long-EZ project
Marc,
What type of tubing do you have? It looks like a hard wall of some kind, almost like copper.
Thanks
